casCtx.h and caHdrLargeArray.h have an odd status. They have never been
considered public API, and are thus not installed. However, cagateway
has long used them.
For the debian packages, my solution was to add a special package for just these
headers, which is only needed when building cagateway.
https://github.com/epicsdeb/epics-base/blob/master/debian/epics-pcas-dev.install
On 9/30/19 10:29 PM, Abdalla Ahmad via Tech-talk wrote:
> Hi
> I wanted to build the CA gateway using our RPM-packaged EPICS base which was mainly build using the INSTALL_LOCATION variable. CA gateway build complained about missing <casCtx.h> which I could not find in the package. I build base 3.15.6 and base 3.14.12.3 with INSTALL_LOCATION and the file was missing, built them both without it and the file was there (obviously). So the question is, is it possible to add the portable CA server (PCAS) library source files to INSTALL_LOCATION?
> Side question: Is there a list of PVs that are exposed by the gateway using the –prefix option?
> Thanks
> Abdalla.
- Re: EPICS base missing header files when using INSTALL_LOCATION Zimoch Dirk (PSI) via Tech-talk
- EPICS base missing header files when using INSTALL_LOCATION Abdalla Ahmad via Tech-talk
FW: error binding socket Alfio Rizzo via Tech-talk
EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
