1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS base missing header files when using INSTALL_LOCATION
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Tue, 1 Oct 2019 05:29:22 +0000
Hi
I wanted to build the CA gateway using our RPM-packaged EPICS base which was mainly build using the INSTALL_LOCATION variable. CA gateway build complained about missing <casCtx.h> which I could not find in the package. I build base 3.15.6 and base 3.14.12.3 with INSTALL_LOCATION and the file was missing, built them both without it and the file was there (obviously). So the question is, is it possible to add the portable CA server (PCAS) library source files to INSTALL_LOCATION?
Side question: Is there a list of PVs that are exposed by the gateway using the –prefix option?
Thanks
Abdalla.
Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
Prev: Re: write a CA client by API in Eclipse Johnson, Andrew N. via Tech-talk
Next: FW: error binding socket Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: CA Repeater Re: [EXTERNAL] Re: write a CA client by API in Eclipse Kasemir, Kay via Tech-talk
Next: Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
