1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: CA Repeater Re: [EXTERNAL] Re: write a CA client by API in Eclipse
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "'[email protected]'" <[email protected]>
Date: Wed, 2 Oct 2019 16:44:50 +0000
>>     i don't find some documents about the caRepeater. i don't konw if i can ignore the error.
>For an explanation of what caRepeater is, see the The CA Repeater
>section of the CA Reference Manual
>  https://epics.anl.gov/base/R3-15/6-docs/CAref.html#Repeater
In short, you can mostly ignore the CARepeater.
Without the CARepeater, you can connect just fine to running IOCs and get data.
It's only about channels that cannot connect because some IOC is offine, and the IOC has been offline for a long time, and now the IOC starts up. In that case, the CARepeater will help the client to connect quickly. Without the CARepeater, the client might take a long time to connect to that newly started IOC.
-Kay
write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Re: write a CA client by API in Eclipse Johnson, Andrew N. via Tech-talk
Re: Re: write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Re: write a CA client by API in Eclipse J. Lewis Muir via Tech-talk
Prev: Re: write a CA client by API in Eclipse J. Lewis Muir via Tech-talk
Next: Re: EPICS base missing header files when using INSTALL_LOCATION J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: EPICS base missing header files when using INSTALL_LOCATION Abdalla Ahmad via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
