1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Re: write a CA client by API in Eclipse
To: "johnson, andrew n." <[email protected]>
Cc: [email protected]
Date: Wed, 2 Oct 2019 12:28:11 +0800 (GMT+08:00)
    i have tried for many times. i found that the useful libs are not libca.so and libCom.so. i can't work well with the two libs(because it shows that it can't find the lib,even if the libs exist). then i found that the actual libs are "libca.so.3.15.6" and "libCom.so.3.15.6".when i add them to the directory it can build and work well.
    when the program is running, the console shows:
    searching ...
**** The executable "caRepeater" couldn't be located
**** because of errno = "No such file or directory".
**** You may need to modify your PATH environment variable.
**** Unable to start "CA Repeater" process.
some channels not found yet
reading ...
some values not received
Beam current (not found): 6.95269e-310
Gap          (not found): 2.0737e-317
    i don't find some documents about the caRepeater. i don't konw if i can ignore the error.
-----原始邮件-----
发件人:"Johnson, Andrew N." <[email protected]>
发送时间:2019-10-01 00:18:18 (星期二)
收件人: "肖麟阁" <[email protected]>, "[email protected]" <[email protected]>
抄送:
主题: Re: write a CA client by API in Eclipse
On 9/30/19 7:33 AM, 肖麟阁 via Tech-talk wrote:
I try to run it, but errors come out like following:
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:43: undefined reference to `ca_task_initialize'
        makefile:29: recipe for target 'testEPICS' failed
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:46: undefined reference to `ca_search_and_connect'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:50: undefined reference to `ca_search_and_connect'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:55: undefined reference to `ca_pend_io'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:88: undefined reference to `ca_message'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:113: undefined reference to `ca_array_get'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:117: undefined reference to `ca_array_get'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:122: undefined reference to `ca_pend_io'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:144: undefined reference to `ca_message'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:157: undefined reference to `ca_state'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:165: undefined reference to `ca_state'
        /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:169: undefined reference to `ca_task_exit'
        collect2: error: ld returned 1 exit status
        make: *** [testEPICS] Error 1
        "make all" terminated with exit code 2. Build might be incomplete.
Those error messages are from the linker, you need to tell it to link your program with the two libraries, so assuming you're using your own build script the linker needs the additional parameters '-lCa -lCom' and it might need others telling it where to find those libraries such as '-L/path/to/your/library/directory'
    by the way, someone else tell me that i just need libCa.so, libCom and some .h files to write a CA Client. is that true?
That is true. The EPICS build system provides a common framework that was designed to make building client programs easier, but you are not required to use it.
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: write a CA client by API in Eclipse Jemian, Pete R. via Tech-talk
Re: write a CA client by API in Eclipse J. Lewis Muir via Tech-talk
write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Re: write a CA client by API in Eclipse Johnson, Andrew N. via Tech-talk
Prev: Job Opening at Lyncean Technologies Terri Lahey via Tech-talk
Next: RE: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: write a CA client by API in Eclipse Johnson, Andrew N. via Tech-talk
Next: Re: write a CA client by API in Eclipse Jemian, Pete R. via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
