1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: EPICS on windows10 Debian Shell
From: Alfio Rizzo via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Wed, 2 Oct 2019 04:35:53 +0000
Hi
The macros are defined the same as any GCC Linux/Unix compiler,
I have already checked this before.
See file in attachment
Best
Alfio
-----Original Message-----
Sent: Wednesday, October 2, 2019 2:22 AM
To: Alfio Rizzo <[email protected]>
Cc: [email protected]
Subject: Re: EPICS on windows10 Debian Shell
On 10/1/19 8:55 AM, Alfio Rizzo via Tech-talk wrote:
> As it should be, the OS macro is defined as __linux__ not as _WIN32,
> since the compiler is NOT MinGW or CYGWIN, but GNU as I said before.
> So, then it comes issue I had was this UDP socket biding issue,
> since binding is still handled a la Windows.
> So the problem is in the source file blockingUDPTransport.cpp
> where the macro _WIN32 is not used consistently in my case.
Can you check what macros this compiler pre-defines?
My usual reference doesn't cover this new variation.
https://sourceforge.net/p/predef/wiki/Home/
> cpp -dM /dev/null > wsl_predefined.h
Attachment: wsl_predefined
Description: wsl_predefined
EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Re: EPICS on windows10 Debian Shell Michael Davidsaver via Tech-talk
Prev: Re: Re: write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Next: Re: write a CA client by API in Eclipse Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS on windows10 Debian Shell Michael Davidsaver via Tech-talk
Next: Job Opening at Lyncean Technologies Terri Lahey via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
