1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: write a CA client by API in Eclipse
From: "Jemian, Pete R. via Tech-talk" <[email protected]>
Date: Wed, 2 Oct 2019 07:33:26 +0000
It is common to make soft links from the file with the version number,
such as:
(base) mintadmin@mint-vm:.../lib/linux-x86_64$ ll libCom*
-r--r--r-- 1 mintadmin mintadmin 4.3M Sep  2 09:55 libCom.a
lrwxrwxrwx 1 mintadmin mintadmin   16 Sep  2 09:55 libCom.so ->
libCom.so.3.17.5*
-r-xr-xr-x 1 mintadmin mintadmin 2.0M Sep  2 09:55 libCom.so.3.17.5*
(base) mintadmin@mint-vm:.../lib/linux-x86_64$ ll libca.*
-r--r--r-- 1 mintadmin mintadmin 5.7M Sep  2 09:57 libca.a
lrwxrwxrwx 1 mintadmin mintadmin   15 Sep  2 09:57 libca.so ->
libca.so.4.13.4*
-r-xr-xr-x 1 mintadmin mintadmin 2.7M Sep  2 09:57 libca.so.4.13.4*
When the directory contains more than one version, the soft link should
link the preferred version.
Hope this helps.
Pete
On 2019-10-01 11:28 PM, 肖麟阁 via Tech-talk wrote:
> Hi,
>      i have tried for many times. i found that the useful libs are not
> libca.so and libCom.so. i can't work well with the two libs(because it
> shows that it can't find the lib,even if the libs exist). then i found
> that the actual libs are "libca.so.3.15.6" and "libCom.so.3.15.6".when i
> add them to the directory it can build and work well.
>      when the program is running, the console shows:
>      searching ...
> **** The executable "caRepeater" couldn't be located
> **** because of errno = "No such file or directory".
> **** You may need to modify your PATH environment variable.
> **** Unable to start "CA Repeater" process.
> some channels not found yet
> reading ...
> some values not received
> Beam current (not found): 6.95269e-310
> Gap          (not found): 2.0737e-317
>      i don't find some documents about the caRepeater. i don't konw if i
> can ignore the error.
>     -----原始邮件-----
>     *发件人:*"Johnson, Andrew N." <[email protected]>
>     *发送时间:*2019-10-01 00:18:18 (星期二)
>     *收件人:* "肖麟阁" <[email protected]>, "[email protected]"
>     <[email protected]>
>     *抄送:*
>     *主题:* Re: write a CA client by API in Eclipse
>     Hi,
>     On 9/30/19 7:33 AM, 肖麟阁 via Tech-talk wrote:
>>     I try to run it, but errors come out like following:
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:43:
>>     undefined reference to `ca_task_initialize'
>>             makefile:29: recipe for target 'testEPICS' failed
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:46:
>>     undefined reference to `ca_search_and_connect'
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:50:
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:55:
>>     undefined reference to `ca_pend_io'
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:88:
>>     undefined reference to `ca_message'
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:113:
>>     undefined reference to `ca_array_get'
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:117:
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:122:
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:144:
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:157:
>>     undefined reference to `ca_state'
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:165:
>>             /home/xlg/eclipse-workspace/testEPICS/Debug/../main.c:169:
>>     undefined reference to `ca_task_exit'
>>             collect2: error: ld returned 1 exit status
>>             make: *** [testEPICS] Error 1
>>             "make all" terminated with exit code 2. Build might be
>>     incomplete.
>     Those error messages are from the linker, you need to tell it to
>     link your program with the two libraries, so assuming you're using
>     your own build script the linker needs the additional parameters
>     '-lCa -lCom' and it might need others telling it where to find those
>     libraries such as '-L/path/to/your/library/directory'
>>         by the way, someone else tell me that i just need libCa.so,
>>     libCom and some .h files to write a CA Client. is that true?
>     That is true. The EPICS build system provides a common framework
>     that was designed to make building client programs easier, but you
>     are not required to use it.
>     - Andrew
>     Complexity comes for free, Simplicity you have to work for.
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Re: write a CA client by API in Eclipse Johnson, Andrew N. via Tech-talk
Re: Re: write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Prev: RE: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
Next: Re: EPICS base missing header files when using INSTALL_LOCATION Zimoch Dirk (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Re: write a CA client by API in Eclipse 肖麟阁 via Tech-talk
Next: Re: write a CA client by API in Eclipse J. Lewis Muir via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
