1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base missing header files when using INSTALL_LOCATION
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 2 Oct 2019 12:04:22 -0400
On Wed, 2 Oct 2019 at 09:17, Michael Davidsaver via Tech-talk <[email protected]> wrote:
On 10/2/19 2:47 AM, Zimoch Dirk (PSI) wrote:
> Can we please "officially" install those files? I always change my base installation to do so.
I suppose this is more of an option now that PCAS has now been unbundled from Base.
https://github.com/epics-modules/pcas
Actually, this has been done in the PCAS module a while ago:
This thread is about older versions of Base. (And I wonder why Dirk is "always" installing old Base versions.)
I don't think it is worth adding the change to the mentioned released Base versions 3.14.12.3 and 3.15.6, especially as the 3.14 series is closed and it is possible to compile the PCAS module against older Base versions (please consider the note in the PCAS readme).
Cheers,
~Ralph
Re: EPICS base missing header files when using INSTALL_LOCATION J. Lewis Muir via Tech-talk
EPICS base missing header files when using INSTALL_LOCATION Abdalla Ahmad via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Zimoch Dirk (PSI) via Tech-talk
Prev: Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
Next: Re: write a CA client by API in Eclipse J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: EPICS base missing header files when using INSTALL_LOCATION J. Lewis Muir via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
