1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base missing header files when using INSTALL_LOCATION
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Zimoch Dirk (PSI)" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 2 Oct 2019 06:16:28 -0700
On 10/2/19 2:47 AM, Zimoch Dirk (PSI) wrote:
> Can we please "officially" install those files? I always change my base installation to do so.
I suppose this is more of an option now that PCAS has now been unbundled from Base.
https://github.com/epics-modules/pcas
> Dirk
> On Tue, 2019-10-01 at 07:30 -0700, Michael Davidsaver via Tech-talk wrote:
>> casCtx.h and caHdrLargeArray.h have an odd status.  They have never been
>> considered public API, and are thus not installed.  However, cagateway
>> has long used them.
>> For the debian packages, my solution was to add a special package for just these
>> headers, which is only needed when building cagateway.
>> https://github.com/epicsdeb/epics-base/blob/master/debian/epics-pcas-dev.install
>> On 9/30/19 10:29 PM, Abdalla Ahmad via Tech-talk wrote:
>>> Hi
>>> I wanted to build the CA gateway using our RPM-packaged EPICS base which was mainly build using the INSTALL_LOCATION variable. CA gateway build complained about missing <casCtx.h> which I could not find in the package. I build base 3.15.6 and base 3.14.12.3 with INSTALL_LOCATION and the file was missing, built them both without it and the file was there (obviously). So the question is, is it possible to add the portable CA server (PCAS) library source files to INSTALL_LOCATION?
>>> Side question: Is there a list of PVs that are exposed by the gateway using the –prefix option?
>>> Thanks
>>> Abdalla.
Re: EPICS base missing header files when using INSTALL_LOCATION Ralph Lange via Tech-talk
EPICS base missing header files when using INSTALL_LOCATION Abdalla Ahmad via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Michael Davidsaver via Tech-talk
Re: EPICS base missing header files when using INSTALL_LOCATION Zimoch Dirk (PSI) via Tech-talk
Prev: fast PV transition skipped in EPICS 3.16 Simon Reiter via Tech-talk
Next: Re: EPICS base missing header files when using INSTALL_LOCATION Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS base missing header files when using INSTALL_LOCATION Zimoch Dirk (PSI) via Tech-talk
ANJ, 02 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
