1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CAS UDP Errors
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 3 Oct 2019 05:53:24 -0700
On 10/3/19 3:39 AM, Abdalla Ahmad via Tech-talk wrote:
> Hi
> Some IOCs reported the following warning
> CAS: UDP send to ip:port failed: Operation not permitted
> What does this error mean? Does it have anything to do with the CA gateway? Moreover, is there a solid documentation on such error messages reported by the IOC?
This is usually triggered by a firewall rule preventing an outbound UDP packet
to the IP and port# mentioned.
CAS UDP Errors Abdalla Ahmad via Tech-talk
Prev: CAS UDP Errors Abdalla Ahmad via Tech-talk
Next: Re: motor-7-1 make errors Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Set enum strings from SNL David Vine via Tech-talk
ANJ, 03 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
