1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Set enum strings from SNL
To: [email protected]
Date: Thu, 3 Oct 2019 12:15:47 -0700
Hi all,
is there a way to set the enum strings (ZRST, etc) of mbbi and mbbo from a SNL program?
David
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
PNG image
RE: Set enum strings from SNL Mark Rivers via Tech-talk
Prev: Re: motor-7-1 make errors Ernesto Paiser via Tech-talk
Next: RE: Set enum strings from SNL Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: CAS UDP Errors Michael Davidsaver via Tech-talk
ANJ, 03 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
