1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: fast PV transition skipped in EPICS 3.16
From: Simon Reiter via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 14 Oct 2019 17:50:40 +0200
Hi all,
I had a closer look into this.
To start from scratch I used makeBaseApp.pl to create a fresh IOC. I removed
everything except the sequence.
The sequence has 3 states, which are just following each other w/o any
condition. In every state, the only PV used and provided by the IOC itself is
set to a new value with SYNC and a log message with time in sec and usec is
printed.
I am monitoring the PV with camonitor and the following is a comparison of
camonitor and the log of the ioc:
cur:S  17:02:37.313890 NOTREADY     | 37.313911 Entered state NOTREADY.
cur:S  17:02:37.313913 LOADING      | 37.313934 Entered state LOADING.
cur:S  17:02:37.313939 UNLOADING    | 37.313961 Entered state UNLOADING.
cur:S  17:02:37.313968 NOTREADY     | 37.314003 Entered state NOTREADY.
                                    | 37.314026 Entered state LOADING.
                                    | 37.314049 Entered state UNLOADING.
                                    | 37.314068 Entered state NOTREADY.
                                    | 37.314095 Entered state LOADING.
cur:S  17:02:37.314098 UNLOADING    | 37.314121 Entered state UNLOADING.
cur:S  17:02:37.314124 NOTREADY     | 37.314140 Entered state NOTREADY.
cur:S  17:02:37.314146 LOADING      | 37.314163 Entered state LOADING.
cur:S  17:02:37.314169 UNLOADING    | 37.314186 Entered state UNLOADING.
cur:S  17:02:37.314192 NOTREADY     | 37.314213 Entered state NOTREADY.
For the first roughly 2000 cycles it is synchron and then updates of the PV are
missing. This time in the example above 4 transitions are missing. The next one
in my example was again 4 transitions, after that 6 transitions.
I tested the behavior with seq v2.2.7 and EPICS 3.16 and EPICS 3.14 on a
CentOS7.
Let me know, in case you need more information to debug the problem.
Best regards,
Simon
On Wed, 2019-10-02 at 14:57 +0200, Simon Reiter via Tech-talk wrote:
> -------- Forwarded Message --------
> From: Simon Reiter <[email protected]>
> Subject: fast PV transition skipped?
> Date: Tue, 1 Oct 2019 11:55:29 +0200
> Hi,
> I am observing a strange behavior with EPICS 3.16 and the sequencer v2.2.7.
> But
> I fear
> it origins in base. So this is, what is used:
> 1. I set a mbbo PV "main:req" from 1 to 3(e.g. by caput)
> 2. A calcout PV pushed to a dfanout (input as CPP)
> 3. dfanouts pushes to second mbbo "sub:req"
> 4. sequencer reacts onto second mbbo and changes its state correctly rom 1 ->
> 2
> (visible via logging)
> 5. a thrid mbbo "sub:cur" is set by the sequencer (using SYNC and usleep(100)
> 6. I set the first mbbo PV "main:req" back to 1
> 7. repeat of step 2 and 3
> 8. sequencer needs to go from state 2 to state 4 before going back to state 1
> (also visible via logging)
> But in case I do step 1 and 6 too close to each other, step 8 seems to not
> push
> the state correctly. The logging inside the IOC shows me that the state was
> included in the transistions.
> This is my logging via camonitor:
> caput main:req 3 && caput main:req 1
> --- works ---
> sub:req       2019-10-01 09:37:20.373428 3
> sub:req       2019-10-01 09:37:20.410165 1
> sub:cur       2019-10-01 09:37:20.374262 2
> sub:cur       2019-10-01 09:37:20.410946 4
> sub:cur       2019-10-01 09:37:20.411308 1
> --- fails ---
> sub:req       2019-10-01 09:37:50.956651 3
> sub:req       2019-10-01 09:37:50.993201 1
> sub:cur       2019-10-01 09:37:50.957223 2
> sub:cur       2019-10-01 09:37:50.994039 1
> Currently I have not yet stripped my project to a very small version and
> there
> is more than just 1 sub in total.
> In addition to this I have a copy (simple calcout with CPP as input) of
> sub:cur
> in a separate IOC on a different host (actually ppc). I observed that this PV
> is not updated properly as well sometimes:
> sub:cur       2019-09-30 17:45:23.270295 2
> copy:sub:cur  2019-09-30 17:45:23.270986 2
> sub:cur       2019-09-30 17:45:25.280127 3
> sub:cur       2019-09-30 17:45:25.280533 1
> copy:sub:cur  2019-09-30 17:45:25.281447 1
> With EPICS 3.14 this does not occur.
> Any idea, what might have changed and where this problem is connected to?
> Best regards,
> Simon
record(mbbo, "cur:S")
  field(ZRVL, "0")
  field(ONVL, "1")
  field(TWVL, "2")
  field(THVL, "3")
  field(FRVL, "4")
  field(FVVL, "5")
  field(SXVL, "6")
  field(SVVL, "7")
  field(EIVL, "8")
  field(ELVL, "11")
  field(ZRST, "UNKNOWN")
  field(ONST, "NOTREADY")
  field(TWST, "READY")
  field(THST, "RUNNING")
  field(FRST, "LOADING")
  field(FVST, "UNLOADING")
  field(SXST, "STARTING")
  field(SVST, "STOPPING")
  field(EIST, "ABORTING")
  field(ELST, "ERROR")
  field(VAL,  "0")
  field(PINI, "YES")
program sncExample
option +c; /* wait for db connections */
option +r; /* make functions reentrant, multiple instances */
option -d; /* toggle runtime debugging messages */
option +W; /* extra warnings. */
int pv_cur;
assign pv_cur to "cur:S";
enum {
    State_UNKNOWN   =  0,
    State_NOTREADY  =  1,
    State_LOADING   =  4,
    State_UNLOADING =  5,
float now() {
    struct timeval tv;
    gettimeofday(&tv, NULL);
    return tv.tv_sec % 60 + (float) (tv.tv_usec) / 1e6;
ss ss1 {
    state S_NOTREADY {
        entry {
            pv_cur = State_NOTREADY;
            pvPut(pv_cur, SYNC);
            printf("%02.6f Entered state %s.\n", now(), "NOTREADY");
        when() {
        } state S_LOADING
    state S_LOADING {
        entry {
            pv_cur = State_LOADING;
            printf("%02.6f Entered state %s.\n", now(), "LOADING");
        when() {
        } state S_UNLOADING
    state S_UNLOADING {
        entry {
            pv_cur = State_UNLOADING;
            printf("%02.6f Entered state %s.\n", now(), "UNLOADING");
        when() {
        } state S_NOTREADY
Re: fast PV transition skipped in EPICS 3.16 Johnson, Andrew N. via Tech-talk
fast PV transition skipped in EPICS 3.16 Simon Reiter via Tech-talk
Prev: Re: [EXTERNAL] updating ADAndor from RHEL6 to RHEL7 Lutes, Troy E. via Tech-talk
Next: Asyn port driver generate parameters Tynan Ford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: fast PV transition skipped in EPICS 3.16 Simon Reiter via Tech-talk
Next: Re: fast PV transition skipped in EPICS 3.16 Johnson, Andrew N. via Tech-talk
ANJ, 14 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
