Mark,
configMenu in autosave provides some of the functionality you need:
https://epics.anl.gov/bcda/synApps/autosave/autoSaveRestore_R5-6-1.html#configMenu
It doesn't, however provide this functionality:
> Logic that monitors the current readback of the device record.
> Whenever the position is close to (within some specified deadband)
> of the numeric value in one of the numeric/string pairs, it copies
> the associated string to the one that describes the current readback.
> When the readback is NOT close to one of the numeric values, it will
> write something like "Invalid position" to the description string.
If configMenu is used to put the device into a specific state, the
currName value is correct. If the device is changed manually, the
currName value is incorrect.
Note: while it is easy to add a named config via a channel-access
client, the only way to delete a config is to delete the .cfg file.
Kevin
On 10/21/19 1:04 PM, Davis, Mark via Tech-talk wrote:
> Hi all,
> I have a new task that I figured those of you with much more
> experience crafting clever record logic could help with:
> The components that need to be supported:
> A record for some device to which setpoints stored in other records
> are to be written (e.g. a motor record).
> A string value that provides a description of the current readback of
> the device record.
> Pairs of numeric and string values. For each pair, the number
> represents one of the setpoints an operator can chose to have written
> to the device record and the string represents a user-readable
> description of what the associated number represents (e.g. the
> thickness or type of material to place in the path of the beam, the
> size of a whole in a metal plate, etc).
> The operators can change the string (and possibly the numeric) values
> whenever they want. Changes must be persistent (i.e. changes are
> saved to a file and restored when the IOC restarts, probably using
> autosave).
> And of course it has to be relatively simple for the person
> configuring the IOC to change the # of numeric/string pairs
> supported for a device.
> No doubt I can cobble something together that will do the job, but I
> figured someone out there will have already dealt with a similar
> need and can provide something much simpler, more flexible, and less
> cumbersome than what I am likely to create on my first attempt.
> Any tips or suggestions would be much appreciated.
> Thanks, Mark Davis NSCL/FRIB
- Re: record logic tips Davis, Mark via Tech-talk
- record logic tips Davis, Mark via Tech-talk
RE: using epics-base with yocto Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Re: [EXTERNAL] record logic tips Pearson, Matthew R. via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
