Folks,
asyn R4-37 is now available.
asyn is available on github here:
https://github.com/epics-modules/asyn
tar and zip files are available here:
https://github.com/epics-modules/asyn/releases
Soon you will be able to find links to the new documentation and release notes here:
http://www.aps.anl.gov/epics/modules/soft/asyn
These are from the R4-37 release notes:
- Added new 64-bit integer support
- asynDriver adds new asynInt64, asynInt64SyncIO, and asynInt64Array interfaces.
- asynDriver.h now does the typedef of epicsInt64 and epicsUInt64 when __STDC_VERSION__ < 199901L on EPICS 3.14.
This allows the Int64 interfaces to be built as long as the compiler supports the long long and unsigned long long data types.
- devEpics.dbd is now constructed at build time rather than being a static file. This enables Int64 device support to only be included on EPICS 3.16.1 and later.
- asynPortDriver adds support for 64-bit integers:
- New parameter types asynParamInt64 and asynParamInt64Array.
- New methods setInteger64Param(), getInteger64Param(), readInt64(), writeInt64(), getBounds64(), readInt64Array(), writeInt64Array(), doCallbacksInt64Array().
- New masks for constructor asynInt64Mask, asynInt64ArrayMask.
- testErrors test application
Changes to driver, database and medm screens to test the Int64 interfaces. This uses the 64-bit device support which must be commented of out st.cmd if running on EPICS versions prior to 3.16.1.
- New FTDI driver
This driver allows much greater control over USB ports for serial communication than the standard Linux /dev/ttyUSBx driver. Thanks to Bruno Martins for this.
- devEpics
Fixes to only print an error message when the status of a write or read operation changes, not each time there is an error. Thanks to Ben Franksen for this.
- asynRecord
Fixes to allow changing the HOSTINFO for the asynIPPort driver when the port is not connected. Thanks to Krisztián Löki for this.
- Many files
Changes to avoid compiler warnings.
Re: record logic tips Davis, Mark via Tech-talk
Re: record logic tips Mooney, Tim M. via Tech-talk
<2019>
2025
2026
RE: using epics-base with yocto Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
modbus Write operation Vishnu Patel via Tech-talk
<2019>
2025
2026
