1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: UDP server in model 3 motor driver
To: <[email protected]>
Date: Thu, 24 Oct 2019 11:19:05 +0100
I'm currently writing a motor driver and I'm not sure on the best way to implement a particular aspect of it. The main control link to the hardware is via TCP/IP, on startup the driver registers parameters of interest on the controller and the controller then sends all subscribed information out via UDP broadcasts. I think I need to create a udp server on the IOC, so far I am doing the following:
IOC boot script:
#TCP port for control, this works
drvAsynIPPortConfigure("PCS1_CTRL", "192.168.113.10:51512", 100, 0, 0)
asynOctetSetInputEos("PCS1_CTRL", 0, "\r\n")
asynOctetSetOutputEos("PCS1_CTRL", 0, "\r\n")
# Configure UDP port for Walter and Bai streams
drvAsynIPServerPortConfigure(PCS1_UDP,"192.168.113.12:51513 udp", 10, 0, 0, 0)
# Configure Walter and Bai PCS8000 controller
pcsControllerConfig(PCS1, 0, 2, 20, 20)
# Configure Walter and Bai PCS8000 Axis
pcsAxisConfig(PCS1, 1)
pcsAxisConfig(PCS1, 2)
Driver constructor(class pcsController: public asynMotorController ):
    /* Connect to pcsController controller TCP for control */
    status = pasynOctetSyncIO->connect(lowLevelPortName, 0, &pasynUserController_, NULL);
    pasynUserUDPStream = pasynManager->createAsynUser(0,0);
    status = pasynManager->connectDevice(pasynUserUDPStream, streamPortName,0);
    pasynInterface = pasynManager->findInterface(pasynUserUDPStream, asynOctetType, 1);
    pasynOctet = (asynOctet *) pasynInterface->pinterface;
    octetPvt=pasynInterface->drvPvt;
Driver poll():
status = pasynOctet->read(octetPvt, pasynUserUDPStream, rxBuffer, 65535 - 1,
                              &nBytesIn, &eomReason);
In the poll() method or perhaps a separate thread elsewhere I know I will have to update the asyn parameters manually and call callParamCallbacks() to get the record to update. Am I going about this the right way?
Thanks in advance
Lee
Re: UDP server in model 3 motor driver Peterson, Kevin M. via Tech-talk
Prev: Re: clarification on PV name max length Johnson, Andrew N. via Tech-talk
Next: Re: UDP server in model 3 motor driver Peterson, Kevin M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 24 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
