1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: build stream
From: =?gb18030?b?t+fQ0Muu?= via Tech-talk <[email protected]>
To: "=?gb18030?b?dGVjaC10YWxr?=" <[email protected]>
Date: Sun, 3 Nov 2019 23:16:44 +0800
Hi all,
   I met some simple question when I using stream and asyn.
   I want to add the stream in my example, created by makeBaseApp.pl.
   I have added the two lines in application Makefile.
PROD_LIBS += stream
PROD_LIBS += asyn
  but failed when add these:
include "base.dbd"
include "stream.dbd"
include "asyn.dbd"
  It said these when I add them in src of src/exampleApp.
 dbdExpand.pl: Can't find file 'stream.dbd'
  while reading 'stream.dbd' to create 'example1.dbd'
  Your Makefile may need this dependency rule:
    $(COMMON_DIR)/example1.dbd: $(COMMON_DIR)/stream.dbd
 dbdExpand.pl: Can't find file 'asyn.dbd'
   What should I do.
Feng W
Prev: RE: No TCP server started Mark Rivers via Tech-talk
Next: Re: No TCP server started Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS Base-3.15.7 and EPICS 7.0.3.1 Released Williams Jr., Ernest L. via Tech-talk
Next: execute python from st.cmd Sandeep Kumar Malu - UKRI STFC via Tech-talk
ANJ, 04 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
