1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Trying to get new R3.15.7 and synapps 6.1 working.
To: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 4 Nov 2019 15:12:03 -0800
My attempts at upgrading to a newer version of EPICS base and support modules have foundered.  I downloaded and built base-3-15.7, synapps-6., and the latest StreamDevice.  No (major) problems there.  I had to comment out the Oriel motor support because there appears to be no OrielRegister.h but other than that everything built.
But when trying to build one of my support modules and test IOCs I get odd complaints about scalcout record support:
make[3]: Entering directory `/eda/epics/R3.15.7/modules/instrument/CaenFastPS/CaenFastPSapp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I/eda/epics/R3.15.7/modules/soft/StreamDevice/include   -I/eda/epics/R3.15.7/modules/soft/synapps/synApps_6_1/support/asyn-R4-36/include -I/eda/epics/R3.15.7/base/include/compiler/gcc -I/eda/epics/R3.15.7/base/include/os/Linux -I/eda/epics/R3.15.7/base/include        -MM -MF CaenFastPSMain.d  ../CaenFastPSMain.cpp
Creating dbd file CaenFastPS.dbd
perl -CSD /eda/epics/R3.15.7/base/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../dbd -I/eda/epics/R3.15.7/modules/soft/StreamDevice/dbd -I/eda/epics/R3.15.7/modules/soft/synapps/synApps_6_1/support/asyn-R4-36/dbd -I/eda/epics/R3.15.7/base/dbd -o CaenFastPS.dbd base.dbd stream.dbd asynRecord.dbd drvAsynIPPort.dbd
Device using unknown record type 'scalcout', declaration created
And the resulting application dbd file contains:
device(longout, CONSTANT, devLoSoft, "Soft Channel")
device(longout, CONSTANT, devLoSoftCallback, "Async Soft Channel")
device(longout, INST_IO, devlongoutStream, "stream")
recordtype(scalcout) {
device(scalcout, INST_IO, devscalcoutStream, "stream")
The empty scalcout record declaration breaks things when the test IOC starts up:
cd "/eda/epics/R3.15.7/modules/instrument/CaenFastPS"
# Register all support components
dbLoadDatabase "dbd/CaenFastPS.dbd"
Declaration of recordtype(scalcout) preceeded full definition.
Error at or before "}" in file "dbd/CaenFastPS.dbd" line 13241
CaenFastPS_registerRecordDeviceDriver pdbbase
registerRecordDeviceDriver failed aSub
registerRecordDeviceDriver failed ai
registerRecordDeviceDriver failed stringin
registerRecordDeviceDriver failed sub
Suggestions?
Eric Norum
[email protected]
Re: Trying to get new R3.15.7 and synapps 6.1 working. Lang, Keenan C. via Tech-talk
Prev: Re: Why should I care about breakpoint table monotonicity? Andrew Johnson via Tech-talk
Next: Re: Trying to get new R3.15.7 and synapps 6.1 working. Lang, Keenan C. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: StreamDevice - disable INVALID/CALC alarm for @mismatch O'Hea, James (DLSLtd, RAL, LSCI) via Tech-talk
ANJ, 05 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
