I'm on a linux SL7.6 machine and am using v7.0.3.1.
I don't understand the epicsRegisterFunction macro. I've used aSubRecords dozens of times
with C files, but now that I'm attempting to use it in a C++ file, I cannot get the macro to
do its magic. At the bottom of my xxx.cpp file with all the correct headers, I have the code:
extern "C" {
short PVdata(struct aSubRecord*);
short PVdata(struct aSubRecord *pvData) {
return 0; // this will eventually be real code
extern "C" {
epicsRegisterFunction(PVdata);
This results in:
/home/epics/epicsDEV/base/include/epicsExport.h:37:22: warning: ISO C++ forbids casting between pointer-to-function and pointer-to-object [-Wpedantic]
epicsExportRegistrar(register_func_ ## func)
/home/epics/epicsDEV/base/include/epicsExport.h:32:72: note: in definition of macro 'epicsExportRegistrar'
epicsShareFunc REGISTRAR EPICS_EXPORT_PFUNC(func) = (REGISTRAR)(void*)&func
../acnetPV.cpp:167:3: note: in expansion of macro 'epicsRegisterFunction'
Am I misusing epicsRegisterFunction() somehow?
As a second issue, I get some weird warning messages:
In file included from /home/epics/epicsDEV/base/include/epicsStdlib.h:20:0,
from acnetPV_registerRecordDeviceDriver.cpp:9:
/home/epics/epicsDEV/base/include/epicsTypes.h:44:14: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
typedef long long epicsInt64;
/home/epics/epicsDEV/base/include/epicsTypes.h:45:23: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
typedef unsigned long long epicsUInt64;
In file included from acnetPV_registerRecordDeviceDriver.cpp:9:0:
/home/epics/epicsDEV/base/include/epicsStdlib.h:39:43: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
epicsParseLLong(const char *str, long long *to, int base, char **units);
/home/epics/epicsDEV/base/include/epicsStdlib.h:41:53: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
epicsParseULLong(const char *str, unsigned long long *to, int base, char **units);
In file included from /home/epics/epicsDEV/base/include/registryCommon.h:15:0,
from acnetPV_registerRecordDeviceDriver.cpp:12:
/home/epics/epicsDEV/base/include/dbJLink.h:69:48: warning: ISO C++ 1998 does not support 'long long' [-Wlong-long]
jlif_result (*parse_integer)(jlink *, long long num);
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
- RE: Two v7.0.3.1 questions Mark Rivers via Tech-talk
RE: EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
RE: StreamDevice - disable INVALID/CALC alarm for @mismatch O'Hea, James (DLSLtd, RAL, LSCI) via Tech-talk
<2019>
2025
2026
Re: Trying to get new R3.15.7 and synapps 6.1 working. Eric Norum via Tech-talk
<2019>
2025
2026
ANJ, 05 Nov 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
