| Thanks for the information. I’ve followed your latter suggestion and things are now running. Perhaps I should push an update to the Caen FastPS support module with this change.
Again, thanks!
Looking over makefiles, if the CALC module is defined in the StreamDevice RELEASE file, the stream.dbd file will contain that scalcout device support line. The CaenFastPS module then includes stream.dbd without also including sCalcoutRecord.dbd (or calcSupport.dbd which grabs all the calc dbd files) which means that the scalcout record is never defined when the dbd is expanded.
You'll either need to: * comment out the CALC module in StreamDevice,
* include the calc module and the needed dbd files into the CaenFastPS module,
* or change the inclusion of stream.dbd to including the file stream-base.dbd instead
- Trying to get new R3.15.7 and synapps 6.1 working. Eric Norum via Tech-talk
- Re: Trying to get new R3.15.7 and synapps 6.1 working. Lang, Keenan C. via Tech-talk
RE: EPICS support for Eurotherm 3508. Li, Ji via Tech-talk
<2019>
2025
2026
Two v7.0.3.1 questions Pierrick M Hanlet via Tech-talk
<2019>
2025
2026
ANJ, 05 Nov 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
