1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Serial port bus connection issue on arm platform
From: "Seeberger, John T CIV USN NAS PAX MD \(USA\) via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Thu, 7 Nov 2019 18:01:39 +0000
Thank you Mark and group for your support. Apparently when I recompiled epics for arm32 I inadvertently commented out
ASYN=$(SUPPORT)/asyn-R4-33
from the configure/RELEASE
I think I was having some link errors which may have been due to the build order.
This problem is solved. Thanks
One thing I was wondering would there be away to build and have both linux-arm32, and linux-arm64 platforms. Rather then just linux-arm.
Thad
Sent: Thursday, November 07, 2019 11:37 AM
To: Seeberger, John T CIV USN NAS PAX MD (USA); Kasemir, Kay
Cc: [email protected]
Subject: [Non-DoD Source] RE: Serial port bus connection issue on arm platform
Hi Thad,
The answer is in your original post.
You showed this output:
dbior "stream"
Driver: stream
  StreamDevice 2.7.7 built Oct 24 2019 13:43:29
  registered bus interfaces:
    DebugInterface
    DummyInterface
I get this output on my system:
epics> dbior "stream"
Driver: stream
  StreamDevice 2.8.STREAM_PATCHLEVEL built Nov  2 2019 14:06:26
    AsynDriverInterface
    DebugInterface
    DummyInterface
Note that you are missing the AsynDriverInterface.  So the problem appears to be the way your built stream.  Please check the stream/configure/RELEASE file, etc.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Sent: Thursday, November 7, 2019 10:26 AM
To: Kasemir, Kay <[email protected]>
Cc: Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk <[email protected]>
Works fine on the aarch64 and x86 version, so I'd say no.
Thad
From: Tech-talk [[email protected]] on behalf of Kasemir, Kay via Tech-talk [[email protected]]
Sent: Thursday, November 07, 2019 11:17 AM
To: Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Subject: [Non-DoD Source] Re: Serial port bus connection issue on arm platform
Just a silly idea: Is "SERIALPORT" simply too long for the stream device? I've mostly seen examples like "P1" for ports.
2019/11/07 16:04:56.709466 _main_ Cannot find a bus named 'SERIALPORT' for 'aoa'
Re: Serial port bus connection issue on arm platform Johnson, Andrew N. via Tech-talk
Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
RE: Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Re: Serial port bus connection issue on arm platform Kasemir, Kay via Tech-talk
RE: Serial port bus connection issue on arm platform Mark Rivers via Tech-talk
Prev: I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
Next: Re: I can't figure out how to change the rate guarantee... Bruno Martins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: Serial port bus connection issue on arm platform Mark Rivers via Tech-talk
Next: Re: Serial port bus connection issue on arm platform Johnson, Andrew N. via Tech-talk
ANJ, 07 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
