Hi Thad,
The answer is in your original post.
You showed this output:
dbior "stream"
Driver: stream
StreamDevice 2.7.7 built Oct 24 2019 13:43:29
registered bus interfaces:
DebugInterface
DummyInterface
I get this output on my system:
epics> dbior "stream"
Driver: stream
StreamDevice 2.8.STREAM_PATCHLEVEL built Nov 2 2019 14:06:26
AsynDriverInterface
DebugInterface
DummyInterface
Note that you are missing the AsynDriverInterface. So the problem appears to be the way your built stream. Please check the stream/configure/RELEASE file, etc.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Sent: Thursday, November 7, 2019 10:26 AM
To: Kasemir, Kay <[email protected]>
Cc: Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk <[email protected]>
Subject: RE: Serial port bus connection issue on arm platform
Works fine on the aarch64 and x86 version, so I'd say no.
Thad
From: Tech-talk [[email protected]] on behalf of Kasemir, Kay via Tech-talk [[email protected]]
Sent: Thursday, November 07, 2019 11:17 AM
To: Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
Subject: [Non-DoD Source] Re: Serial port bus connection issue on arm platform
Just a silly idea: Is "SERIALPORT" simply too long for the stream device? I've mostly seen examples like "P1" for ports.
2019/11/07 16:04:56.709466 _main_ Cannot find a bus named 'SERIALPORT' for 'aoa'
- RE: Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
- Serial port bus connection issue on arm platform Seeberger, John T CIV USN NAS PAX MD (USA) via Tech-talk
- Re: Serial port bus connection issue on arm platform Johnson, Andrew N. via Tech-talk
- Re: Serial port bus connection issue on arm platform Kasemir, Kay via Tech-talk
I can't figure out how to change the rate guarantee... Aaron Brown via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
