1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Reset counter
To: enum riz <[email protected]>
Date: Tue, 12 Nov 2019 13:43:02 +0000
Hi Enum,
Which record is the "button" you are pressing?
Please explain the intended logic in your database, i.e. please describe each record is intended to do.  You are scanning all of the records at 0.1 second which does not seem correct.
If you just want to turn an LED on for 2 seconds and then turn it off I don't see why you need a counter that is updating an integer count at all.  For example the "seq" record in EPICS base can set an output record to 1 (turning on the LED), wait for 2 seconds, and then turn it off.  Each time you process that record it will do that.
From: Tech-talk <[email protected]> on behalf of enum riz via Tech-talk <[email protected]>
Sent: Tuesday, November 12, 2019 12:07 AM
To: Tech-talk
Subject: Reset counter
Hi Mark
i made a counter which works fine when i press button it starts and after a fixed value it stop.but whenever i press again button it didnot work.(Independently it works but when i merge this in my file with other code it didnot start with next press button)
i am sending code please tell me how it will reset and starts again when button press. I want a duration of 2 seconds. Led On for 2 second and then off.
record(bi,     "b"){
 field(SCAN,  ".1 second")
 field(ZNAM, "0")
 field(ZNAM, "1")
record(calcout,  "t"){
 field(INPA, "b")
 field(CALC, "A==1?1:0")
record(calcout,  "counter"){
 field(VAL, "0")
 field(INPA, "counter")
 field(INPB, "1")
 field(INPC, "t")
 field(CALC, "C==1&&(A<=9)?(A+B):A")
record(calcout,  "reset"){
 field(CALC, "A<=9?A:0")
record(calcout,  "rst"){
 field(INPA, "reset")
record(b0,     "out"){
 field(OMSL, "closed_loop")
 field(DOL, "rst")
 field(ZNAM, "0")
 field(ZNAM, "1")
Re: [EXTERNAL] Re: Reset counter Steven M. Hartman via Tech-talk
Reset counter enum riz via Tech-talk
Prev: Re: Reset counter William Layne via Tech-talk
Next: Re: [EXTERNAL] Re: Reset counter Steven M. Hartman via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
