1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Reset counter
From: William Layne via Tech-talk <[email protected]>
To: enum riz <[email protected]>
Cc: Tech-talk <[email protected]>
Date: Tue, 12 Nov 2019 07:57:35 -0500
It looks like you are missing an "OUT" field in your "calcout" records. This field indicates where you would like to place your output.
On Tue, Nov 12, 2019, 1:07 AM enum riz via Tech-talk <[email protected]> wrote:
Hi Mark
i made a counter which works fine when i press button it starts and after a fixed value it stop.but whenever i press again button it didnot work.(Independently it works but when i merge this in my file with other code it didnot start with next press button)
i am sending code please tell me how it will reset and starts again when button press. I want a duration of 2 seconds. Led On for 2 second and then off.
record(bi,     "b"){
 field(SCAN,  ".1 second")
 field(ZNAM, "0")
 field(ZNAM, "1")
record(calcout,  "t"){
 field(INPA, "b")
 field(CALC, "A==1?1:0")
record(calcout,  "counter"){
 field(VAL, "0")
 field(INPA, "counter")
 field(INPB, "1")
 field(INPC, "t")
 field(CALC, "C==1&&(A<=9)?(A+B):A")
record(calcout,  "reset"){
 field(CALC, "A<=9?A:0")
record(calcout,  "rst"){
 field(INPA, "reset")
record(b0,     "out"){
 field(OMSL, "closed_loop")
 field(DOL, "rst")
 field(ZNAM, "0")
 field(ZNAM, "1")
Reset counter enum riz via Tech-talk
Prev: Re: Reset counter Simon Reiter via Tech-talk
Next: Re: Reset counter Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
