1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Reset counter
From: Simon Reiter via Tech-talk <[email protected]>
To: enum riz <[email protected]>, Tech-talk <[email protected]>
Date: Tue, 12 Nov 2019 13:46:28 +0100
For this LED part, you may think of using a bo record. This allows to stay high
for a fixed time window and set back to low automatically. It would simply look
like this:
record(bo, "led")
  field(HIGH, "2.0")
  field(ZNAM, "0")
  field(ONAM, "1")
In case you want a separate button PV, use another bo record with OUT field to
"led PP" and that's it.
I am not sure about this counter with multiple SCAN fields and the time of 2
seconds, while you're only counting up to 10.
Cheers,
Simon
On Tue, 2019-11-12 at 06:07 +0000, enum riz via Tech-talk wrote:
> Hi Mark
> i made a counter which works fine when i press button it starts and after a
> fixed value it stop.but whenever i press again button it didnot
> work.(Independently it works but when i merge this in my file with other code
> it didnot start with next press button)
> i am sending code please tell me how it will reset and starts again when
> button press. I want a duration of 2 seconds. Led On for 2 second and then
> off.
> record(bi,     "b"){
>  field(SCAN,  ".1 second")
>  field(ZNAM, "0")
>  field(ZNAM, "1")
> record(calcout,  "t"){
>  field(INPA, "b")
>  field(CALC, "A==1?1:0")
> record(calcout,  "counter"){
>  field(VAL, "0")
>  field(INPA, "counter")
>  field(INPB, "1")
>  field(INPC, "t")
>  field(CALC, "C==1&&(A<=9)?(A+B):A")
> record(calcout,  "reset"){
>  field(CALC, "A<=9?A:0")
> record(calcout,  "rst"){
>  field(INPA, "reset")
> record(b0,     "out"){
>  field(OMSL, "closed_loop")
>  field(DOL, "rst")
>  field(ZNAM, "0")
>  field(ZNAM, "1")
Reset counter enum riz via Tech-talk
Prev: Redundancy CCExecInit command problem Tasaddaq Khan via Tech-talk
Next: Re: Reset counter William Layne via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Reset counter enum riz via Tech-talk
ANJ, 12 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
