1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS+EPICS NFS mount issue
From: Till Straumann via Tech-talk <[email protected]>
To: Heinz Junkes <[email protected]>, 刘峰瑞 <[email protected]>
Cc: Zhu <[email protected]>, tech-talk <[email protected]>
Date: Fri, 15 Nov 2019 12:15:55 -0800
I believe the SEND failure indicates that there is a network configuration issue
(interface and or routing not set up or invalid NFS server address).
Check your networking setup; make sure you can 'ping' your RTEMS system
from another computer. Double-check the NFS server address and any firewalls etc.
Use wireshark to see if NFS requests make it out of the RTEMS system and if
replies come back etc.
- Till
On 11/15/19 11:58 AM, Heinz Junkes via Tech-talk wrote:
how is the mount point provided?
by motload env?
by bootp?
Is the nfs server running?
What do the logs on the server show?
Heinz
On 15. Nov 2019, at 03:46, 刘峰瑞 via Tech-talk <[email protected]> wrote:
Hi Mr Zhu,
I am a engineer for the RTEMS+EPICS to mvme5500 board.
I meet the same problem of you listed in https://epics.anl.gov/tech-talk/2012/msg00186.php    when I mount the NFS server.
The error infromation is listed below:
RPCIO: SEND failure
Unable to contact NFS server - invalid port? (RPC: Unable to send)
nfsMount - mount: Unknown protocol
How can I solve this problem ?
Best regards,
Fengui Liu
E:   [email protected]
Fw:RTEMS+EPICS NFS mount issue 刘峰瑞 via Tech-talk
Re: RTEMS+EPICS NFS mount issue Heinz Junkes via Tech-talk
Prev: Re: RTEMS+EPICS NFS mount issue Heinz Junkes via Tech-talk
Next: Getting started with EPICS Valentyn Stadnytskyi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: EPICS_AR_PORT Jeong Han Lee via Tech-talk
ANJ, 16 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
