Hello,
I am installing EPICS on my linuxbox for the first time. I am following instructions on https://epics-controls.org/resources-and-support/documents/getting-started/.
The part #7 (7. Install StreamDevice (by Dirk Zimoch, PSI)) says makeBaseApp.pl -t support When I ran the command I get a request to write Application name. But there is nothing in instructions about this, so I am not sure what I am supposed to put there. control:~/EPICS/support/stream$ makeBaseApp.pl -t support Name the application(s) to be created. Names given will have "App" appended to them. Application names?
I am not sure who to tell this but part #6 of the instructions has a typo: It should be support instead of spport.
Edit $HOME/EPICS/spport/asyn/configure/RELEASE and set
Thank you!
- Re: Getting started with EPICS Heinz Junkes via Tech-talk
Re: RTEMS+EPICS NFS mount issue Till Straumann via Tech-talk
<2019>
2025
2026
Re: EPICS_AR_PORT Johnson, Andrew N. via Tech-talk
<2019>
2025
2026
ANJ, 17 Nov 2019 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
