1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS_AR_PORT
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Fri, 15 Nov 2019 19:08:27 +0000
I think it's safe to drop some long-unused environment parameters from the 7.0 branch, EPICS_CMD_PROTO_PORT and EPICS_AR_PORT being the obvious ones. I will commit that change.
The EPICS_IOC_LOG_FILE_{NAME,LIMIT,COMMAND} parameters will be deleted when we throw out the iocLogServer code (but not the EPICS_IOC_LOG_{INET,PORT} parameters which are used by the log client code).
- Andrew
On 11/15/19 11:06 AM, Jeong Han Lee via Tech-talk wrote:
Hi Ralph,
  I saw that port within ioc shell while I am debugging the iocStats error message related TIMEZONE, the recent. And it may be forgotten in two decades. The definition I can find in epics-base/modules/libcom/src/env/envDefs.h
  HTH,
  Han
On 11/15/19 12:36 PM, Jeong Han Lee wrote:
Hi Ralph,
   Thank you. I may test the old AR archiver :)
   Best,
   Han
On 11/15/19 10:47 AM, Ralph Lange via Tech-talk wrote:
On Fri, 15 Nov 2019 at 10:42, Jeong Han Lee via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
       Does anyone know about EPICS_AR_PORT?
       I cannot find any information about it, and Timo didn't know it
    also :)
That's configuration for the old AR archiver.
https://epics.anl.gov/extensions/ar/index.php
In which code cemetery did you find that? How deep?
Cheers,
~Ralph
Complexity comes for free, Simplicity you have to work for.
EPICS_AR_PORT Jeong Han Lee via Tech-talk
Re: EPICS_AR_PORT Ralph Lange via Tech-talk
Re: EPICS_AR_PORT Jeong Han Lee via Tech-talk
Prev: Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Next: Re: RTEMS+EPICS NFS mount issue Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS_AR_PORT Jeong Han Lee via Tech-talk
Next: Getting started with EPICS Valentyn Stadnytskyi via Tech-talk
ANJ, 16 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
