1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Uploading a file with SFTP from an EPICS driver
From: "J. Lewis Muir via Tech-talk" <[email protected]>
Date: Fri, 15 Nov 2019 13:04:43 -0600
On 11/15, Mark Rivers wrote:
> Thanks for the suggestion.  Now things get REALLY weird.
Indeed. :-)
> I did what you said, and ran curl with --libcurl.  I timed the command:
[snip]
> The performance was the same, 0.33 seconds, much slower than running the curl command itself!
Strange.  Other things you could try:
1. Run curl and curl_gen under strace (e.g., "strace -CftT -s 256
   <command>") and see if you can tell where curl_gen is taking longer
   than curl.
2. Check the compiler optimization level curl_gen is compiled at just
   in case it's weak compared to what I presume the curl executable was
   compiled at.  (I doubt this is the cause.)
3. Check the ldd output for curl, libcurl.so, and curl_gen for anything
   that looks suspicious.  Make sure curl_gen is not linked against
   libgnutls.
4. You usually build EPICS and modules from an NFS file system,
   right?  Is that the case here?  If so, try copying curl_gen (and any
   dependencies) to a non-network file system and running it there.
Lewis
RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Prev: Re: EPICS_AR_PORT Jeong Han Lee via Tech-talk
Next: Re: EPICS_AR_PORT Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Next: RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
