1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Uploading a file with SFTP from an EPICS driver
From: "J. Lewis Muir via Tech-talk" <[email protected]>
Date: Thu, 14 Nov 2019 10:05:40 -0600
On 11/14, Mark Rivers via Tech-talk wrote:
> So on Linux running the "curl" command via a call to system() is actually almost 3 times faster than calling either of the libraries directly.  This surprises me.
That makes no sense.  There must be something different about how you're
using libcurl vs. curl.  Have you tried curl's "--libcurl <file>"
option?  I would try that.  Basically, take the curl command line that
works, and then add the "--libcurl <file>" option to it, and it will
emit C source code for a program using libcurl that does the same thing.
Compare that with how you're using libcurl.
Lewis
Re: Uploading a file with SFTP from an EPICS driver Michael Davidsaver via Tech-talk
RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Prev: RE: Uploading a file with SFTP from an EPICS driver Freddie Akeroyd - UKRI STFC via Tech-talk
Next: Re: Uploading a file with SFTP from an EPICS driver Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 14 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
