1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: Uploading a file with SFTP from an EPICS driver
From: Freddie Akeroyd - UKRI STFC via Tech-talk <[email protected]>
Date: Thu, 14 Nov 2019 15:58:12 +0000
Hi Mark,
If you did need a libcurl library for windows there is one that uses the EPICS build system at https://github.com/ISISComputingGroup/EPICS-curl by default it will expect the OpenSSL built from https://github.com/ISISComputingGroup/EPICS-OpenSSL but can probably use one downloaded from elsewhere too
Freddie
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: 14 November 2019 14:39
To: [email protected]
Subject: Uploading a file with SFTP from an EPICS driver
Folks,
I am working on the driver for the Newport XPS motor controllers.  These controllers can execute Position-Velocity-Time (PVT) trajectory scans which are complex multi-axis coordinated motion along a user-defined path in 8-space.  The trajectory is defined in a text file, which the EPICS driver creates and then uploads to the controller.  The older XPS-C8 and XPS-Q8 controllers support FTP for the upload.  I have a small C implementation of FTP which the driver uses.  This C code is standalone, it only needs to call the standard socket functions.
The new XPS-D8 controller does not support FTP, it only supports SFTP/SCP.  I need a solution to be able to do SFTP transfers from within my C++ EPICS driver.  I want the solution to work on both Linux and Windows, and ideally on vxWorks as well.
I have tried 3 solutions, and measured the time that each solution required to upload a 5KB file. The results surprised me, and I am curious if anyone can explain them.
The code for the 3 solutions is in the attached xpsSFTPUpload.cpp and the test program is testSFTPUpload.cpp.
Solution 1.  Use libssh2.  This is selected if CONFIG_SITE defines HAVE_LIBSSH2=YES.
Execution time = 326 ms
Solution 2.  Use libcurl with the curl_easy API.  This is selected if CONFIG_SITE defines HAVE_LIBCURL=YES.
Execution time = 323 ms
Solution 3. Run the “curl” program with the C system() call.  The driver builds the text of the curl command and runs it with the system() call. This is selected if CONFIG_SITE does not define HAVE_LIBSSH2=YES or HAVE_LIBCURL=YES.
Execution time (Linux) = 126 ms
Execution time (Windows) = 270 ms
So on Linux running the “curl” command via a call to system() is actually almost 3 times faster than calling either of the libraries directly.  This surprises me.
Note that I actually prefer to use Solution 3 because it is easy to implement on Windows.  There are several sites that provide downloads of a pre-built “curl” executable.  However, I have not been able to find any site that provides the libssh2 or libcurl libraries in a form that can be called from Visual Studio.  They are built with mingw and give errors when I try to link with Visual Studio.  Note that because of the performance measurements above I am not motivated to pursue the library solution either, since it seems to be significantly slower.
Ideally I would like this driver to work on vxWorks as well, but I don’t see any solution for doing sftp from within a C program on vxWorks?
Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Prev: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Next: Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 14 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
