1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory
From: Valentyn Stadnytskyi via Tech-talk <[email protected]>
Date: Sun, 17 Nov 2019 21:40:28 -0600
Thank you Mark!
On a similar note:
If one does everything according to these instructions from https://epics-controls.org/resources-and-support/documents/getting-started/
mkdir -p $HOME/EPICS/TEST/testIoc
cd $HOME/EPICS/TEST/testIoc
makeBaseApp.pl -t example testIoc
makeBaseApp.pl -i -t example testIoc
make
cd iocBoot/ioctestIoc
chmod u+x st.cmd
You get a st.cmd file with curly brackets instead of parenthesis for {TOP} and {IOC}. I don’t know where this is generated and where to report the bug. See the file below. This is minor but for someone who does it for the first time and never seen EPICS shell but be a big slowdown.
~/EPICS/IOCs/testIoc/iocBoot/ioctestIoc$ more st.cmd
#!../../bin/linux-x86_64/testIoc
#- You may have to change testIoc to something else
#- everywhere it appears in this file
< envPaths
cd "${TOP}"
dbLoadDatabase "dbd/testIoc.dbd"
testIoc_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/testIocVersion.db", "user=femtoland"
dbLoadRecords "db/dbSubExample.db", "user=femtoland"
#- Set this to see messages from mySub
#var mySubDebug 1
#- Run this to trace the stages of iocInit
#traceIocInit
cd "${TOP}/iocBoot/${IOC}"
iocInit
## Start any sequence programs
#seq sncExample, "user=femtoland"
On Nov 17, 2019, at 9:27 PM, Mark Rivers <[email protected]> wrote:
I helped Valentyn fix this today. It was a simple problem with testIoc vs testIOC. Changing the case fixed it.
Sent from my iPhone
On Nov 17, 2019, at 9:17 PM, Michael Davidsaver via Tech-talk <[email protected]> wrote:
On 11/17/19 12:06 PM, Valentyn Stadnytskyi via Tech-talk wrote:
:~/EPICS/epics-base/test/testIoc/iocBoot/ioctestIoc$ ./st.cmd
-bash: ./st.cmd: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory
What happens if you instead run the following from the same directory?
$ ../../bin/linux-x86_64/testIOC st.cmd
RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Valentyn Stadnytskyi via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Michael Davidsaver via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Prev: Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Next: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
