1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] ai records with data covering many decades
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>, Bo Jakobsen <[email protected]>
Date: Mon, 18 Nov 2019 14:51:05 +0000
Hi:
> ..PV for a pressure gauge which by nature covers many decades of values.
> I wanted to set up MEDM and ADEL values before starting to log the values to our archiver.
> Output is in exponential format, and i would like to monitor on e.g. 1 decimal independent of the exponent, it this possible.
I'm not aware of a good solution for efficiently displaying or archiving log-scale-type-PVs via MDEL respectively ADEL.
As you say, end users would like to see updates based on for example changes of "0.1", no matter if that's "0.1E-3" or "0.1E-5" on a log scale plot of vacuum pressure readings.
Sometimes the MDEL/ADEL is set to say "0.1E-5" because the reading happened to be in the E-5 range at the time, and then the vacuum improves to the E-6 range and MDEL/ADEL suppresses all updates.
So the only practical solution for archiving is to set ADEL=0, and store the value every few seconds to limit the amount of data. That's OK for the longer-term histor, but with vacuum readings you tend to care about some detail in vacuum excursions which start as a sharp spike, followed by exponential decay. With just a value every few seconds, you miss the initial spike detail.
Kay
Re: [EXTERNAL] ai records with data covering many decades Jemian, Pete R. via Tech-talk
ai records with data covering many decades Bo Jakobsen via Tech-talk
Prev: ai records with data covering many decades Bo Jakobsen via Tech-talk
Next: Re: Uploading a file with SFTP from an EPICS driver Torsten Bögershausen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] ai records with data covering many decades Jemian, Pete R. via Tech-talk
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
