May be out of the blue:
Does it make sense to make a trace with Wireshark/Ethereal/tcpdump
to find out if we loose time doing ssl negotioans,
key exchange, reverse lookups and other network related
stuff ?
On 18/11/19 15:03, Mark Rivers via Tech-talk wrote:
Hi Lewis,
Ø Strange. Other things you could try:
1. Run curl and curl_gen under strace (e.g., "strace -CftT -s 256
<command>") and see if you can tell where curl_gen is taking longer
than curl.
This is the final output of strace when running curl_gen:
07:55:27 +++ exited with 0 +++
% time seconds usecs/call calls errors syscall
34.38 0.000722 3 224 186 open
17.76 0.000373 4 102 mmap
13.00 0.000273 4 70 mprotect
7.05 0.000148 3 57 23 recvfrom
5.76 0.000121 3 39 fstat
4.95 0.000104 3 40 read
4.90 0.000103 5 22 poll
3.57 0.000075 2 39 close
2.38 0.000050 3 16 sendto
2.10 0.000044 2 24 write
0.90 0.000019 19 1 getsockopt
0.67 0.000014 2 7 brk
0.52 0.000011 4 3 munmap
0.48 0.000010 0 23 18 stat
0.29 0.000006 3 2 2 statfs
0.24 0.000005 1 4 2 access
0.19 0.000004 1 3 fcntl
0.14 0.000003 1 3 rt_sigaction
0.14 0.000003 3 1 getsockname
0.14 0.000003 3 1 getpeername
0.10 0.000002 2 1 rt_sigprocmask
0.10 0.000002 2 1 getrlimit
0.05 0.000001 1 1 lseek
0.05 0.000001 1 1 getuid
0.05 0.000001 1 1 arch_prctl
0.05 0.000001 1 1 set_tid_address
0.05 0.000001 1 1 set_robust_list
0.00 0.000000 0 1 socket
0.00 0.000000 0 1 1 connect
0.00 0.000000 0 3 setsockopt
0.00 0.000000 0 1 execve
0.00 0.000000 0 1 gettid
0.00 0.000000 0 1 futex
100.00 0.002100 696 232 total
This is the output of strace when running the curl command:
07:55:53 +++ exited with 0 +++
57.74 0.001797 4 453 write
8.16 0.000254 5 55 21 recvfrom
7.33 0.000228 4 54 rt_sigaction
5.82 0.000181 10 18 poll
3.47 0.000108 7 16 sendto
2.96 0.000092 3 28 mprotect
2.12 0.000066 1 72 51 open
1.90 0.000059 3 22 read
1.83 0.000057 1 67 mmap
1.74 0.000054 4 15 futex
1.35 0.000042 2 25 close
1.06 0.000033 4 8 brk
0.64 0.000020 7 3 munmap
0.61 0.000019 1 30 25 stat
0.55 0.000017 1 21 fstat
0.32 0.000010 3 3 fcntl
0.26 0.000008 4 2 socket
0.26 0.000008 8 1 1 connect
0.22 0.000007 2 4 setsockopt
0.19 0.000006 3 2 1 access
0.16 0.000005 5 1 pipe
0.13 0.000004 4 1 select
0.13 0.000004 4 1 getsockopt
0.10 0.000003 3 1 lseek
0.10 0.000003 3 1 rt_sigprocmask
0.10 0.000003 3 1 getsockname
0.10 0.000003 3 1 getpeername
0.10 0.000003 3 1 arch_prctl
0.10 0.000003 3 1 set_tid_address
0.10 0.000003 3 1 set_robust_list
0.06 0.000002 2 1 ioctl
0.06 0.000002 2 1 getrlimit
0.06 0.000002 2 1 getuid
0.06 0.000002 2 1 getgid
0.06 0.000002 2 1 geteuid
0.06 0.000002 2 1 getegid
0.00 0.000000 0 1 readlink
100.00 0.003112 917 99 total
I don't know how to interpret these because the total elapsed time for curl_gen was 0.33 seconds while for the curl command it was 0.12 seconds. The tables above seem to show only 2-3 ms?
2. Check the compiler optimization level curl_gen is compiled at just
in case it's weak compared to what I presume the curl executable was
compiled at. (I doubt this is the cause.)
That cannot be the problem. All of the elapsed time in curl_gen is spent in the single call to curl_perform, which is not in curl_gen, but rather in the libcurl package.
3. Check the ldd output for curl, libcurl.so, and curl_gen for anything
that looks suspicious. Make sure curl_gen is not linked against
libgnutls.
corvette:motorNewport/newportApp/src>ldd ../../../../bin/linux-x86_64/curl_gen
linux-vdso.so.1 => (0x00007ffe0e3dc000)
libcurl.so.4 => /lib64/libcurl.so.4 (0x00007f0faff52000)
libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f0fafc4b000)
libm.so.6 => /lib64/libm.so.6 (0x00007f0faf949000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f0faf733000)
libc.so.6 => /lib64/libc.so.6 (0x00007f0faf366000)
libidn.so.11 => /lib64/libidn.so.11 (0x00007f0faf133000)
libssh2.so.1 => /lib64/libssh2.so.1 (0x00007f0faef06000)
libssl3.so => /lib64/libssl3.so (0x00007f0faecb4000)
libsmime3.so => /lib64/libsmime3.so (0x00007f0faea8d000)
libnss3.so => /lib64/libnss3.so (0x00007f0fae760000)
libnssutil3.so => /lib64/libnssutil3.so (0x00007f0fae531000)
libplds4.so => /lib64/libplds4.so (0x00007f0fae32d000)
libplc4.so => /lib64/libplc4.so (0x00007f0fae128000)
libnspr4.so => /lib64/libnspr4.so (0x00007f0fadeea000)
libpthread.so.0 => /lib64/libpthread.so.0 (0x00007f0fadcce000)
libdl.so.2 => /lib64/libdl.so.2 (0x00007f0fadaca000)
libgssapi_krb5.so.2 => /lib64/libgssapi_krb5.so.2 (0x00007f0fad87d000)
libkrb5.so.3 => /lib64/libkrb5.so.3 (0x00007f0fad594000)
libk5crypto.so.3 => /lib64/libk5crypto.so.3 (0x00007f0fad361000)
libcom_err.so.2 => /lib64/libcom_err.so.2 (0x00007f0fad15d000)
liblber-2.4.so.2 => /lib64/liblber-2.4.so.2 (0x00007f0facf4e000)
libldap-2.4.so.2 => /lib64/libldap-2.4.so.2 (0x00007f0faccf9000)
libz.so.1 => /lib64/libz.so.1 (0x00007f0facae3000)
/lib64/ld-linux-x86-64.so.2 (0x00007f0fb01bc000)
libssl.so.10 => /lib64/libssl.so.10 (0x00007f0fac871000)
libcrypto.so.10 => /lib64/libcrypto.so.10 (0x00007f0fac40e000)
librt.so.1 => /lib64/librt.so.1 (0x00007f0fac206000)
libkrb5support.so.0 => /lib64/libkrb5support.so.0 (0x00007f0fabff6000)
libkeyutils.so.1 => /lib64/libkeyutils.so.1 (0x00007f0fabdf2000)
libresolv.so.2 => /lib64/libresolv.so.2 (0x00007f0fabbd9000)
libsasl2.so.3 => /lib64/libsasl2.so.3 (0x00007f0fab9bc000)
libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f0fab795000)
libcrypt.so.1 => /lib64/libcrypt.so.1 (0x00007f0fab55e000)
libpcre.so.1 => /lib64/libpcre.so.1 (0x00007f0fab2fc000)
libfreebl3.so => /lib64/libfreebl3.so (0x00007f0fab0f9000)
4. You usually build EPICS and modules from an NFS file system,
right? Is that the case here? If so, try copying curl_gen (and any
dependencies) to a non-network file system and running it there.
This test was run on corvette, which is our Linux file server. So the programs are on the local file system, not NFS.
-----Original Message-----
Sent: Friday, November 15, 2019 1:05 PM
To: Mark Rivers <[email protected]>
Cc: [email protected]
Subject: Re: Uploading a file with SFTP from an EPICS driver
On 11/15, Mark Rivers wrote:
Thanks for the suggestion. Now things get REALLY weird.
Indeed. :-)
I did what you said, and ran curl with --libcurl. I timed the command:
[snip]
The performance was the same, 0.33 seconds, much slower than running the curl command itself!
than curl.
libgnutls.
Lewis
- Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
- Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
- RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Re: [EXTERNAL] ai records with data covering many decades Kasemir, Kay via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Johnson, Andrew N. via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
