1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 18 Nov 2019 16:36:11 +0000
Hi Mark,
On 11/18/19 7:11 AM, Mark Rivers via Tech-talk wrote:
The st.cmd command still contains {} rather than (), but that appears to be fine?
Yes. Most EPICS tools use the macLib code from libCom to expand macros, and by default that recognizes both $(macro) and ${macro} as macros. IIRC there was disagreement between author of shell scripts, which use ${macro}, and of Makefiles, which use $(macro), as to which syntax to use, so both were provided to avoid arguments. There was even an idea to make those characters configurable by the application, but that was never actually implemented.
- Andrew
Complexity comes for free, Simplicity you have to work for.
../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Valentyn Stadnytskyi via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Michael Davidsaver via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Valentyn Stadnytskyi via Tech-talk
RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Prev: Re: Uploading a file with SFTP from an EPICS driver Torsten Bögershausen via Tech-talk
Next: Re: [EXTERNAL] ai records with data covering many decades Jemian, Pete R. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Next: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
