1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory
To: 'Valentyn Stadnytskyi' <[email protected]>
Cc: "'[email protected]'" <[email protected]>
Date: Mon, 18 Nov 2019 13:11:52 +0000
I found my problem.  I was executing the commands from the documentation with copy and paste, pasting multiple commands at a time.  That worked OK except for the makeBaseApp.pl command that did interactive input.  It was swallowing the subsequent chmod and make commands and putting them in the st.cmd.
Once I executed those commands one at a time the problem was fixed.
The st.cmd command still contains {} rather than (), but that appears to be fine?
(base) [epics@corvette ioctestIoc]$ more st.cmd
#!../../bin/linux-x86_64/testIoc
#- You may have to change testIoc to something else
#- everywhere it appears in this file
< envPaths
cd "${TOP}"
dbLoadDatabase "dbd/testIoc.dbd"
testIoc_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadTemplate "db/user.substitutions"
dbLoadRecords "db/testIocVersion.db", "user=epics"
dbLoadRecords "db/dbSubExample.db", "user=epics"
#- Set this to see messages from mySub
#var mySubDebug 1
#- Run this to trace the stages of iocInit
#traceIocInit
cd "${TOP}/iocBoot/${IOC}"
iocInit
## Start any sequence programs
#seq sncExample, "user=epics"
But now executing the st.cmd works fine.
(base) [epics@corvette ioctestIoc]$ ./st.cmd
< envPaths
epicsEnvSet("IOC","ioctestIoc")
epicsEnvSet("TOP","/home/epics/EPICS/TEST/testIoc")
epicsEnvSet("EPICS_BASE","/home/epics/EPICS/epics-base")
cd "/home/epics/EPICS/TEST/testIoc"
#var mySubDebug 1
#traceIocInit
cd "/home/epics/EPICS/TEST/testIoc/iocBoot/ioctestIoc"
iocInit
Starting iocInit
## EPICS R7.0.3.2-DEV
## Rev. R7.0.3.1-18-g3c0d4ccf4931b696c82a
cas warning: Configured TCP port was unavailable.
cas warning: Using dynamically assigned TCP port 42058,
cas warning: but now two or more servers share the same UDP port.
cas warning: Depending on your IP kernel this server may not be
cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
2019-11-18T07:05:16.036 Using dynamically assigned TCP port 38220.
epics>
Is there a difference between {} and () around macros?  I have only used the former.
Sent: Monday, November 18, 2019 6:53 AM
Cc: Michael Davidsaver <[email protected]>; [email protected]
I can confirm what Valentyn reports.  I just followed the exact instructions in the link he references below.  I used copy and paste from the document to be sure I did not make any typos.
I found 2 problems:
The second makeBaseApp command asks a question about the name of the IOC to boot:
(base) [epics@corvette testIoc]$ makeBaseApp.pl -i -t example testIoc
Using target architecture linux-x86_64 (only one available)
The following applications are available:
    testIoc
What application should the IOC(s) boot?
The default uses the IOC's name, even if not listed above.
Application name?
The instructions do not mention this, but I think they should.
More importantly, this is the st.cmd file generated.
chmod u+x st.cmdstIoc_64/make
chmod u+x st.cmd to something else
< envPaths
cd "${TOP}"
chmod u+x st.cmd.dbd"ake
make_cd_iocBoot_ioctestIoc_chmod_u_x_st_cmd_registerRecordDeviceDriver pdbbase
chmod u+x st.cmdVersion.db", "user=epics"
#var mySubDebug 1
#traceIocInit
iocInit
< envPaths
cd "${TOP}"
#var mySubDebug 1
#traceIocInit
iocInit
Note that as Valentyn says, it uses {} rather than () around macro parameters and so an attempt to follow the next step in the instructions leads to this error:
cd: bad interpreter: No such file or directory
In EPICS/epics-base/templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common contains this:
#!../../bin/_ARCH_/_APPNAME_
#- You may have to change _APPNAME_ to something else
< envPaths
cd "${TOP}"
dbLoadDatabase "dbd/_APPNAME_.dbd"
_CSAFEAPPNAME__registerRecordDeviceDriver pdbbase
#dbLoadRecords("db/xxx.db","user=_USER_")
iocInit
#seq sncxxx,"user=_USER_"
So the template file contains {} rather than ().  But I don’t know enough perl to know if this is the problem, or if makeBaseApp.pl is supposed to be replacing those {} with ()?
Sent: Sunday, November 17, 2019 9:40 PM
Subject: Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory
Thank you Mark!
On a similar note:
If one does everything according to these instructions from https://epics-controls.org/resources-and-support/documents/getting-started/
mkdir -p $HOME/EPICS/TEST/testIoc
cd $HOME/EPICS/TEST/testIoc
makeBaseApp.pl -t example testIoc
make
cd iocBoot/ioctestIoc
chmod u+x st.cmd
You get a st.cmd file with curly brackets instead of parenthesis for {TOP} and {IOC}. I don’t know where this is generated and where to report the bug. See the file below. This is minor but for someone who does it for the first time and never seen EPICS shell but be a big slowdown.
~/EPICS/IOCs/testIoc/iocBoot/ioctestIoc$ more st.cmd
< envPaths
cd "${TOP}"
dbLoadRecords "db/testIocVersion.db", "user=femtoland"
dbLoadRecords "db/dbSubExample.db", "user=femtoland"
#var mySubDebug 1
#traceIocInit
iocInit
#seq sncExample, "user=femtoland"
On Nov 17, 2019, at 9:27 PM, Mark Rivers <[email protected]> wrote:
I helped Valentyn fix this today. It was a simple problem with testIoc vs testIOC. Changing the case fixed it.
Sent from my iPhone
On Nov 17, 2019, at 9:17 PM, Michael Davidsaver via Tech-talk <[email protected]> wrote:
On 11/17/19 12:06 PM, Valentyn Stadnytskyi via Tech-talk wrote:
:~/EPICS/epics-base/test/testIoc/iocBoot/ioctestIoc$ ./st.cmd
-bash: ./st.cmd: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory
What happens if you instead run the following from the same directory?
$ ../../bin/linux-x86_64/testIOC st.cmd
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Johnson, Andrew N. via Tech-talk
../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Valentyn Stadnytskyi via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Michael Davidsaver via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Valentyn Stadnytskyi via Tech-talk
RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Prev: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Next: RE: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: ../../bin/linux-x86_64/testIOC: bad interpreter: No such file or directory Johnson, Andrew N. via Tech-talk
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
