1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: areaDetector-R3-4, Stats Plugin - Histogram
To: 'John Dobbins' <[email protected]>
Date: Mon, 18 Nov 2019 21:23:32 +0000
Hi John,
I was able to reproduce that behavior with the simDetector and with an AVT Manta camera.  I have found and fixed an off-by-1 error in the histogram calculation.  I have pushed to the master branch on Github.  It fixed the problem for me with both the simDetector and the Manta.  Please give it a try when you can.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Monday, November 18, 2019 12:35 PM
To: [email protected]
Subject: areaDetector-R3-4, Stats Plugin - Histogram
All,
I happened to be looking at an Histogram in the areaDetector-R3-4 Stats Plug-in  with Base-3.15.5, linux-x86_64, and I notice that bin 129 is always zero for all out cameras. We are using Allied Vision model Mako G-319B. I haven't checked if this is a camera issue. Does anyone else see this?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
areaDetector-R3-4, Stats Plugin - Histogram John Dobbins via Tech-talk
Prev: Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Next: RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: areaDetector-R3-4, Stats Plugin - Histogram John Dobbins via Tech-talk
Next: RE: [EXTERNAL] ai records with data covering many decades [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
