1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Uploading a file with SFTP from an EPICS driver
To: "'J. Lewis Muir'" <[email protected]>
Date: Mon, 18 Nov 2019 23:34:32 +0000
>    3. Check the ldd output for curl, libcurl.so, and curl_gen for anything
>       that looks suspicious.  Make sure curl_gen is not linked against
>       libgnutls.
>  Can you also list the same for curl?
ldd on curl and curl_gen are identical except that curl_gen has these 3 libraries that curl does not have:
	libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fdd3c745000)
	libm.so.6 => /lib64/libm.so.6 (0x00007fdd3c443000)
	libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fdd3c22d000)
> Yeah, that's because my suggested strace command is no good.  Sorry about that.  Try "strace -CfttTw -s 256 <command>" instead.
I have attached the complete output from strace for both curl and curl_gen.  The main difference is that curl spent 0.105 seconds in "poll" while curl_gen spent 0.494 seconds "poll".  All other functions are trivial.
Note that curl spend a total of 0.12 seconds, which is the same as I see without using strace.  However, curl_gen spent a total of 0.502 seconds, which is significantly longer than the 0.33 seconds without strace.
-----Original Message-----
Sent: Monday, November 18, 2019 2:56 PM
Cc: [email protected]
Subject: Re: Uploading a file with SFTP from an EPICS driver
On 11/18, Mark Rivers wrote:
> Ø  Strange.  Other things you could try:
>    1. Run curl and curl_gen under strace (e.g., "strace -CftT -s 256
>       <command>") and see if you can tell where curl_gen is taking longer
>       than curl.
> This is the final output of strace when running curl_gen:
[snip]
> This is the output of strace when running the curl command:
[snip]
> I don't know how to interpret these because the total elapsed time for
> curl_gen was 0.33 seconds while for the curl command it was 0.12
> seconds.  The tables above seem to show only 2-3 ms?
I added an extra "-t" option to make it print the microseconds.  Without that, you can't see what's going on.
And I added a "-w" option so that the trace timestamp differences are wall clock time, not system time.  This affects the total seconds in the summary table too.  Without it, you were just seeing system time, I think.  With the "-w" option, the summary total in seconds should equal the wall clock running time you have observed.  Note, however, that if the program does any forking where the parent waits for the child to finish, I think that will mess up the summary total since, e.g., the parent could be waiting in a system call for the child to die, and the child could be waiting in a system call for something else, and both of those would be included in the summary total.  So, you could end up with a summary total that is greater than the actual wall clock running time of the program.
Also note that in the trace output, the number at the end of each line in angle brackets (e.g., "<0.000085>") is the elapsed wall clock time spent in the system call which might be easier to look at than taking the difference of the two timestamps.
BTW, I'd be more interested in comparing the trace and less interested in the summary at the end, but if the summary at the end shows anything interesting, then great, at least it didn't get missed.
[snip]
>       libgnutls.
> corvette:motorNewport/newportApp/src>ldd
> ../../../../bin/linux-x86_64/curl_gen
[snip]
Lewis
17:30:56.914712 execve("/home/epics/anaconda3/bin/curl", ["curl", "c", "-k", "-u", "Administrator:Administrator", "-T", "TrajectoryScan.trj", "--verbose", "scp://164.54.160.71/Admin/Public/Trajectories/"], [/* 85 vars */]) = 0 <0.000159>
17:30:56.915159 brk(NULL)               = 0x55c95e020000 <0.000012>
17:30:56.915232 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde741000 <0.000012>
17:30:56.915289 readlink("/proc/self/exe", "/home/epics/anaconda3/bin/curl", 4096) = 30 <0.000033>
17:30:56.915377 access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory) <0.000013>
17:30:56.915444 open("/home/epics/anaconda3/bin/../lib/tls/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:30:56.915497 stat("/home/epics/anaconda3/bin/../lib/tls/x86_64", 0x7ffd7d376ec0) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.915541 open("/home/epics/anaconda3/bin/../lib/tls/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000019>
17:30:56.915591 stat("/home/epics/anaconda3/bin/../lib/tls", 0x7ffd7d376ec0) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.915633 open("/home/epics/anaconda3/bin/../lib/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:30:56.915672 stat("/home/epics/anaconda3/bin/../lib/x86_64", 0x7ffd7d376ec0) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.915710 open("/home/epics/anaconda3/bin/../lib/libcurl.so.4", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:30:56.915752 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\300\0\0\0\0\0\0@\0\0\0\0\0\0\0Pv\t\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\33\0\32\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\310\276\0\0\0\0\0\0\310\276\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\300\0\0\0\0\0\0\0\300\0\0\0\0\0\0\0\300\0\0\0\0\0\0\16\307\5\0\0\0\0\0\16\307\5\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0\220\6\0\0\0\0\0\0\220\6\0\0\0\0\0\0\220\6\0\0\0\0\0\34\230\1\0\0\0\0\0\34\230\1\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\0007\10\0\0\0\0\0\0G\10\0\0\0\0\0"..., 832) = 832 <0.000014>
17:30:56.915807 fstat(3, {st_mode=S_IFREG|0775, st_size=621840, ...}) = 0 <0.000011>
17:30:56.915862 mmap(NULL, 554408, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde6b9000 <0.000015>
17:30:56.915909 mprotect(0x7f9bde6c5000, 491520, PROT_NONE) = 0 <0.000014>
17:30:56.915949 mmap(0x7f9bde6c5000, 380928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f9bde6c5000 <0.000015>
17:30:56.915991 mmap(0x7f9bde722000, 106496, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x69000) = 0x7f9bde722000 <0.000012>
17:30:56.916028 mmap(0x7f9bde73d000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x83000) = 0x7f9bde73d000 <0.000012>
17:30:56.916075 close(3)                = 0 <0.000010>
17:30:56.916120 open("/home/epics/anaconda3/bin/../lib/libz.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000018>
17:30:56.916179 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@0\0\0\0\0\0\0@\0\0\0\0\0\0\0\10\2\2\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\34\0\33\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0H(\0\0\0\0\0\0H(\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0000\0\0\0\0\0\0\0000\0\0\0\0\0\0\0000\0\0\0\0\0\0\0068\1\0\0\0\0\0\0068\1\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0p\1\0\0\0\0\0\0p\1\0\0\0\0\0\0p\1\0\0\0\0\0\214a\0\0\0\0\0\0\214a\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0 \333\1\0\0\0\0\0 \353\1\0\0\0\0\0"..., 832) = 832 <0.000011>
17:30:56.916224 fstat(3, {st_mode=S_IFREG|0775, st_size=133384, ...}) = 0 <0.000010>
17:30:56.916262 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde6b8000 <0.000012>
17:30:56.916304 mmap(NULL, 127000, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde698000 <0.000011>
17:30:56.916338 mmap(0x7f9bde69b000, 81920, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f9bde69b000 <0.000013>
17:30:56.916376 mmap(0x7f9bde6af000, 28672, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x17000) = 0x7f9bde6af000 <0.000011>
17:30:56.916417 mmap(0x7f9bde6b6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1d000) = 0x7f9bde6b6000 <0.000011>
17:30:56.916460 close(3)                = 0 <0.000010>
17:30:56.916496 open("/home/epics/anaconda3/bin/../lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.916536 open("/usr/local/lib/tls/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.916585 stat("/usr/local/lib/tls/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916623 open("/usr/local/lib/tls/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916660 stat("/usr/local/lib/tls", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916697 open("/usr/local/lib/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916733 stat("/usr/local/lib/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916768 open("/usr/local/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:30:56.916812 stat("/usr/local/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 <0.000011>
17:30:56.916854 open("/usr/local/lib64/tls/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916890 stat("/usr/local/lib64/tls/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916925 open("/usr/local/lib64/tls/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916960 stat("/usr/local/lib64/tls", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.916995 open("/usr/local/lib64/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917030 stat("/usr/local/lib64/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917065 open("/usr/local/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917100 stat("/usr/local/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 <0.000010>
17:30:56.917138 open("/usr/local64/lib/tls/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:30:56.917178 stat("/usr/local64/lib/tls/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917214 open("/usr/local64/lib/tls/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.917250 stat("/usr/local64/lib/tls", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917285 open("/usr/local64/lib/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.917323 stat("/usr/local64/lib/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.917361 open("/usr/local64/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:30:56.917413 stat("/usr/local64/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 <0.000012>
17:30:56.917464 open("/usr/local/epics/extensions/lib/linux-x86/tls/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.917504 stat("/usr/local/epics/extensions/lib/linux-x86/tls/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917541 open("/usr/local/epics/extensions/lib/linux-x86/tls/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000019>
17:30:56.917591 stat("/usr/local/epics/extensions/lib/linux-x86/tls", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917630 open("/usr/local/epics/extensions/lib/linux-x86/x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.917667 stat("/usr/local/epics/extensions/lib/linux-x86/x86_64", 0x7ffd7d376e60) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.917709 open("/usr/local/epics/extensions/lib/linux-x86/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.917748 stat("/usr/local/epics/extensions/lib/linux-x86", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0 <0.000011>
17:30:56.917790 open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3 <0.000012>
17:30:56.917827 fstat(3, {st_mode=S_IFREG|0644, st_size=118229, ...}) = 0 <0.000009>
17:30:56.917862 mmap(NULL, 118229, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f9bde67b000 <0.000011>
17:30:56.917898 close(3)                = 0 <0.000009>
17:30:56.917941 open("/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000013>
17:30:56.917979 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\"\0\0\0\0\0\0@\0\0\0\0\0\0\0\340\243\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0'\0&\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0008e\0\0\0\0\0\0008e\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0@m\0\0\0\0\0\0@m \0\0\0\0\0@m \0\0\0\0\0\24\5\0\0\0\0\0\0\370\16\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0pm\0\0\0\0\0\0pm \0\0\0\0\0pm \0\0\0\0\0000\2\0\0\0\0\0\0000\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000010>
17:30:56.918018 fstat(3, {st_mode=S_IFREG|0755, st_size=44448, ...}) = 0 <0.000010>
17:30:56.918054 mmap(NULL, 2128952, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde319000 <0.000012>
17:30:56.918090 mprotect(0x7f9bde320000, 2093056, PROT_NONE) = 0 <0.000014>
17:30:56.918127 mmap(0x7f9bde51f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f9bde51f000 <0.000013>
17:30:56.918171 close(3)                = 0 <0.000009>
17:30:56.918207 open("/home/epics/anaconda3/bin/../lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.918245 open("/usr/local/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.918282 open("/usr/local/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.918317 open("/usr/local64/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.918353 open("/usr/local/epics/extensions/lib/linux-x86/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.918390 open("/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3 <0.000012>
17:30:56.918428 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0m\0\0\0\0\0\0@\0\0\0\0\0\0\0X+\2\0\0\0\0\0\0\0\0\0@\0008\0\t\0@\0)\0(\0\6\0\0\0\5\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0\370\1\0\0\0\0\0\0\370\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\3\0\0\0\4\0\0\0P\23\1\0\0\0\0\0P\23\1\0\0\0\0\0P\23\1\0\0\0\0\0\34\0\0\0\0\0\0\0\34\0\0\0\0\0\0\0\20\0\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\354g\1\0\0\0\0\0\354g\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0`k\1\0\0\0\0\0`k!\0\0\0\0\0"..., 832) = 832 <0.000012>
17:30:56.918468 fstat(3, {st_mode=S_IFREG|0755, st_size=144792, ...}) = 0 <0.000011>
17:30:56.918507 mmap(NULL, 2208904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde0fd000 <0.000013>
17:30:56.918545 mprotect(0x7f9bde114000, 2093056, PROT_NONE) = 0 <0.000021>
17:30:56.918593 mmap(0x7f9bde313000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7f9bde313000 <0.000016>
17:30:56.918640 mmap(0x7f9bde315000, 13448, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f9bde315000 <0.000013>
17:30:56.918684 close(3)                = 0 <0.000011>
17:30:56.918723 open("/home/epics/anaconda3/bin/../lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:30:56.918764 open("/usr/local/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.918802 open("/usr/local/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.918840 open("/usr/local64/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.918883 open("/usr/local/epics/extensions/lib/linux-x86/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.918930 open("/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = 3 <0.000015>
17:30:56.918971 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P%\2\0\0\0\0\0@\0\0\0\0\0\0\0H\27!\0\0\0\0\0\0\0\0\0@\0008\0\n\0@\0L\0K\0\6\0\0\0\5\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0000\2\0\0\0\0\0\0000\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\3\0\0\0\4\0\0\0p\341\30\0\0\0\0\0p\341\30\0\0\0\0\0p\341\30\0\0\0\0\0\34\0\0\0\0\0\0\0\34\0\0\0\0\0\0\0\20\0\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0`&\34\0\0\0\0\0`&\34\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0 '\34\0\0\0\0\0 '<\0\0\0\0\0"..., 832) = 832 <0.000012>
17:30:56.919011 fstat(3, {st_mode=S_IFREG|0755, st_size=2173512, ...}) = 0 <0.000010>
17:30:56.919049 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde67a000 <0.000012>
17:30:56.919090 mmap(NULL, 3981792, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bddd30000 <0.000012>
17:30:56.919127 mprotect(0x7f9bddef3000, 2093056, PROT_NONE) = 0 <0.000015>
17:30:56.919166 mmap(0x7f9bde0f2000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c2000) = 0x7f9bde0f2000 <0.000015>
17:30:56.919210 mmap(0x7f9bde0f8000, 16864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f9bde0f8000 <0.000013>
17:30:56.919253 close(3)                = 0 <0.000010>
17:30:56.919298 open("/home/epics/anaconda3/bin/../lib/./tls/x86_64/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:30:56.919368 stat("/home/epics/anaconda3/bin/../lib/./tls/x86_64", 0x7ffd7d376ca0) = -1 ENOENT (No such file or directory) <0.000014>
17:30:56.919421 open("/home/epics/anaconda3/bin/../lib/./tls/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:30:56.919463 stat("/home/epics/anaconda3/bin/../lib/./tls", 0x7ffd7d376ca0) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.919500 open("/home/epics/anaconda3/bin/../lib/./x86_64/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.919536 stat("/home/epics/anaconda3/bin/../lib/./x86_64", 0x7ffd7d376ca0) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.919580 open("/home/epics/anaconda3/bin/../lib/./libssh2.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000013>
17:30:56.919625 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\200\0\0\0\0\0\0@\0\0\0\0\0\0\0\360Q\3\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\33\0\32\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0008v\0\0\0\0\0\0008v\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\200\0\0\0\0\0\0\0\200\0\0\0\0\0\0\0\200\0\0\0\0\0\0J\313\1\0\0\0\0\0J\313\1\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0P\2\0\0\0\0\0\0P\2\0\0\0\0\0\0P\2\0\0\0\0\0H\215\0\0\0\0\0\0H\215\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0 \340\2\0\0\0\0\0 \360\2\0\0\0\0\0"..., 832) = 832 <0.000011>
17:30:56.919664 fstat(3, {st_mode=S_IFREG|0775, st_size=219312, ...}) = 0 <0.000012>
17:30:56.919706 mmap(NULL, 197024, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde649000 <0.000016>
17:30:56.919766 mprotect(0x7f9bde651000, 159744, PROT_NONE) = 0 <0.000016>
17:30:56.919824 mmap(0x7f9bde651000, 118784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x8000) = 0x7f9bde651000 <0.000015>
17:30:56.919880 mmap(0x7f9bde66e000, 36864, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7f9bde66e000 <0.000014>
17:30:56.919932 mmap(0x7f9bde678000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2e000) = 0x7f9bde678000 <0.000017>
17:30:56.919993 close(3)                = 0 <0.000010>
17:30:56.920041 open("/home/epics/anaconda3/bin/../lib/./libssl.so.1.1", O_RDONLY|O_CLOEXEC) = 3 <0.000017>
17:30:56.920104 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\360\1\0\0\0\0\0@\0\0\0\0\0\0\0\0@\n\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\34\0\33\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\310\343\1\0\0\0\0\0\310\343\1\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\360\1\0\0\0\0\0\0\360\1\0\0\0\0\0\0\360\1\0\0\0\0\0\232\234\4\0\0\0\0\0\232\234\4\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0\220\6\0\0\0\0\0\0\220\6\0\0\0\0\0\0\220\6\0\0\0\0\0004\214\1\0\0\0\0\0004\214\1\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\240'\10\0\0\0\0\0\2407\10\0\0\0\0\0"..., 832) = 832 <0.000016>
17:30:56.920177 fstat(3, {st_mode=S_IFREG|0775, st_size=673536, ...}) = 0 <0.000015>
17:30:56.920227 mmap(NULL, 588096, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde5b9000 <0.000010>
17:30:56.920262 mprotect(0x7f9bde5d8000, 409600, PROT_NONE) = 0 <0.000011>
17:30:56.920296 mmap(0x7f9bde5d8000, 303104, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1f000) = 0x7f9bde5d8000 <0.000011>
17:30:56.920331 mmap(0x7f9bde622000, 102400, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x69000) = 0x7f9bde622000 <0.000010>
17:30:56.920365 mmap(0x7f9bde63c000, 53248, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x82000) = 0x7f9bde63c000 <0.000010>
17:30:56.920407 close(3)                = 0 <0.000010>
17:30:56.920459 open("/home/epics/anaconda3/bin/../lib/./libcrypto.so.1.1", O_RDONLY|O_CLOEXEC) = 3 <0.000012>
17:30:56.920502 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\300\7\0\0\0\0\0@\0\0\0\0\0\0\0\20\3551\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0#\0\"\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\241\7\0\0\0\0\0\0\241\7\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\260\7\0\0\0\0\0\0\260\7\0\0\0\0\0\0\260\7\0\0\0\0\0\316K\31\0\0\0\0\0\316K\31\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0\0!\0\0\0\0\0\0\0!\0\0\0\0\0\0\0!\0\0\0\0\0\270\222\10\0\0\0\0\0\270\222\10\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\340\227)\0\0\0\0\0\340\247)\0\0\0\0\0"..., 832) = 832 <0.000011>
17:30:56.920557 fstat(3, {st_mode=S_IFREG|0775, st_size=3274192, ...}) = 0 <0.000015>
17:30:56.920627 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde5b8000 <0.000011>
17:30:56.920670 mmap(NULL, 2924520, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bdda66000 <0.000011>
17:30:56.920704 mmap(0x7f9bddae1000, 1658880, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7b000) = 0x7f9bddae1000 <0.000013>
17:30:56.920741 mmap(0x7f9bddc76000, 565248, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x210000) = 0x7f9bddc76000 <0.000011>
17:30:56.920784 mmap(0x7f9bddd00000, 184320, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x299000) = 0x7f9bddd00000 <0.000020>
17:30:56.920858 mmap(0x7f9bddd2d000, 12264, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f9bddd2d000 <0.000022>
17:30:56.920931 close(3)                = 0 <0.000011>
17:30:56.920978 open("/home/epics/anaconda3/bin/../lib/./libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:30:56.921020 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\320\0\0\0\0\0\0@\0\0\0\0\0\0\0(\243\5\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\35\0\34\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\306\0\0\0\0\0\0\0\306\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\320\0\0\0\0\0\0\0\320\0\0\0\0\0\0\0\320\0\0\0\0\0\0b\25\3\0\0\0\0\0b\25\3\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0\360\3\0\0\0\0\0\0\360\3\0\0\0\0\0\0\360\3\0\0\0\0\0@\271\0\0\0\0\0\0@\271\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\270\264\4\0\0\0\0\0\270\304\4\0\0\0\0\0"..., 832) = 832 <0.000011>
17:30:56.921063 fstat(3, {st_mode=S_IFREG|0664, st_size=371304, ...}) = 0 <0.000011>
17:30:56.921115 mmap(NULL, 322224, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde569000 <0.000012>
17:30:56.921152 mprotect(0x7f9bde576000, 258048, PROT_NONE) = 0 <0.000011>
17:30:56.921186 mmap(0x7f9bde576000, 204800, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x7f9bde576000 <0.000012>
17:30:56.921234 mmap(0x7f9bde5a8000, 49152, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3f000) = 0x7f9bde5a8000 <0.000026>
17:30:56.921301 mmap(0x7f9bde5b5000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4b000) = 0x7f9bde5b5000 <0.000016>
17:30:56.921352 close(3)                = 0 <0.000011>
17:30:56.921392 open("/home/epics/anaconda3/bin/../lib/./libkrb5.so.3", O_RDONLY|O_CLOEXEC) = 3 <0.000015>
17:30:56.921434 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@P\2\0\0\0\0\0@\0\0\0\0\0\0\0000\220\20\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\35\0\34\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\320I\2\0\0\0\0\0\320I\2\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0P\2\0\0\0\0\0\0P\2\0\0\0\0\0\0P\2\0\0\0\0\0\252\301\5\0\0\0\0\0\252\301\5\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0 \10\0\0\0\0\0\0 \10\0\0\0\0\0\0 \10\0\0\0\0\0\314\205\4\0\0\0\0\0\314\205\4\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\260\255\f\0\0\0\0\0\260\275\f\0\0\0\0\0"..., 832) = 832 <0.000010>
17:30:56.921473 fstat(3, {st_mode=S_IFREG|0664, st_size=1087344, ...}) = 0 <0.000010>
17:30:56.921515 mmap(NULL, 898064, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bdd98a000 <0.000013>
17:30:56.921571 mmap(0x7f9bdd9af000, 380928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x25000) = 0x7f9bdd9af000 <0.000014>
17:30:56.921616 mmap(0x7f9bdda0c000, 299008, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x82000) = 0x7f9bdda0c000 <0.000012>
17:30:56.921652 mmap(0x7f9bdda55000, 69632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xca000) = 0x7f9bdda55000 <0.000016>
17:30:56.921712 close(3)                = 0 <0.000010>
17:30:56.921754 open("/home/epics/anaconda3/bin/../lib/./libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:30:56.921795 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@`\0\0\0\0\0\0@\0\0\0\0\0\0\0\20\21\2\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\35\0\34\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\360\\\0\0\0\0\0\0\360\\\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0`\0\0\0\0\0\0\0`\0\0\0\0\0\0\0`\0\0\0\0\0\0n\345\0\0\0\0\0\0n\345\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0P\1\0\0\0\0\0\0P\1\0\0\0\0\0\0P\1\0\0\0\0\0\310J\0\0\0\0\0\0\310J\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\270\250\1\0\0\0\0\0\270\270\1\0\0\0\0\0"..., 832) = 832 <0.000010>
17:30:56.921833 fstat(3, {st_mode=S_IFREG|0664, st_size=137296, ...}) = 0 <0.000009>
17:30:56.921868 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde568000 <0.000011>
17:30:56.921905 mmap(NULL, 122896, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde549000 <0.000011>
17:30:56.921939 mprotect(0x7f9bde54f000, 86016, PROT_NONE) = 0 <0.000012>
17:30:56.921974 mmap(0x7f9bde54f000, 61440, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f9bde54f000 <0.000013>
17:30:56.922011 mmap(0x7f9bde55e000, 20480, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f9bde55e000 <0.000017>
17:30:56.922057 mmap(0x7f9bde564000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1a000) = 0x7f9bde564000 <0.000011>
17:30:56.922097 mmap(0x7f9bde567000, 16, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f9bde567000 <0.000010>
17:30:56.922135 close(3)                = 0 <0.000009>
17:30:56.922170 open("/home/epics/anaconda3/bin/../lib/./libcom_err.so.3", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:30:56.922209 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@ \0\0\0\0\0\0@\0\0\0\0\0\0\0hS\0\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\34\0\33\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\230\20\0\0\0\0\0\0\230\20\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0 \0\0\0\0\0\0\0 \0\0\0\0\0\0\0 \0\0\0\0\0\0z\16\0\0\0\0\0\0z\16\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0000\0\0\0\0\0\0\0000\0\0\0\0\0\0\0000\0\0\0\0\0\0\270\5\0\0\0\0\0\0\270\5\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0\250<\0\0\0\0\0\0\250L\0\0\0\0\0\0"..., 832) = 832 <0.000010>
17:30:56.922245 fstat(3, {st_mode=S_IFREG|0664, st_size=23144, ...}) = 0 <0.000009>
17:30:56.922279 mmap(NULL, 20688, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bde543000 <0.000013>
17:30:56.922322 mmap(0x7f9bde545000, 4096, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f9bde545000 <0.000012>
17:30:56.922360 mmap(0x7f9bde546000, 4096, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f9bde546000 <0.000017>
17:30:56.922406 mmap(0x7f9bde547000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f9bde547000 <0.000012>
17:30:56.922449 close(3)                = 0 <0.000009>
17:30:56.922488 open("/home/epics/anaconda3/bin/../lib/././tls/x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.922526 stat("/home/epics/anaconda3/bin/../lib/././tls/x86_64", 0x7ffd7d376b20) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922569 open("/home/epics/anaconda3/bin/../lib/././tls/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922610 stat("/home/epics/anaconda3/bin/../lib/././tls", 0x7ffd7d376b20) = -1 ENOENT (No such file or directory) <0.000009>
17:30:56.922644 open("/home/epics/anaconda3/bin/../lib/././x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922678 stat("/home/epics/anaconda3/bin/../lib/././x86_64", 0x7ffd7d376b20) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922713 open("/home/epics/anaconda3/bin/../lib/././libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:30:56.922751 stat("/home/epics/anaconda3/bin/../lib/./.", {st_mode=S_IFDIR|0775, st_size=36864, ...}) = 0 <0.000016>
17:30:56.922797 open("/home/epics/anaconda3/bin/../lib/./libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:30:56.922837 open("/home/epics/anaconda3/bin/../lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922872 open("/usr/local/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922907 open("/usr/local/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922941 open("/usr/local64/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.922975 open("/usr/local/epics/extensions/lib/linux-x86/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.923011 open("/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000013>
17:30:56.923049 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\16\0\0\0\0\0\0@\0\0\0\0\0\0\0\0E\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0!\0 \0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\330\37\0\0\0\0\0\0\330\37\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0X-\0\0\0\0\0\0X- \0\0\0\0\0X- \0\0\0\0\0@\3\0\0\0\0\0\0\330\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\210-\0\0\0\0\0\0\210- \0\0\0\0\0\210- \0\0\0\0\0\20\2\0\0\0\0\0\0\20\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000010>
17:30:56.923087 fstat(3, {st_mode=S_IFREG|0755, st_size=19776, ...}) = 0 <0.000011>
17:30:56.923128 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bdd989000 <0.000013>
17:30:56.923172 mmap(NULL, 2109744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bdd785000 <0.000013>
17:30:56.923209 mprotect(0x7f9bdd787000, 2097152, PROT_NONE) = 0 <0.000014>
17:30:56.923245 mmap(0x7f9bdd987000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f9bdd987000 <0.000011>
17:30:56.923287 close(3)                = 0 <0.000010>
17:30:56.923323 open("/home/epics/anaconda3/bin/../lib/././libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:30:56.923362 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@@\0\0\0\0\0\0@\0\0\0\0\0\0\0p\1\1\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\35\0\34\0\1\0\0\0\4\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0H2\0\0\0\0\0\0H2\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\222Q\0\0\0\0\0\0\222Q\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\4\0\0\0\0\240\0\0\0\0\0\0\0\240\0\0\0\0\0\0\0\240\0\0\0\0\0\0,\37\0\0\0\0\0\0,\37\0\0\0\0\0\0\0\20\0\0\0\0\0\0\1\0\0\0\6\0\0\0X\312\0\0\0\0\0\0X\332\0\0\0\0\0\0"..., 832) = 832 <0.000016>
17:30:56.923423 fstat(3, {st_mode=S_IFREG|0664, st_size=67760, ...}) = 0 <0.000012>
17:30:56.923477 mmap(NULL, 57992, PROT_READ, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bdd776000 <0.000019>
17:30:56.923541 mprotect(0x7f9bdd77a000, 36864, PROT_NONE) = 0 <0.000024>
17:30:56.923598 mmap(0x7f9bdd77a000, 24576, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4000) = 0x7f9bdd77a000 <0.000015>
17:30:56.923640 mmap(0x7f9bdd780000, 8192, PROT_READ, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xa000) = 0x7f9bdd780000 <0.000012>
17:30:56.923677 mmap(0x7f9bdd783000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xc000) = 0x7f9bdd783000 <0.000012>
17:30:56.923723 close(3)                = 0 <0.000009>
17:30:56.923771 open("/home/epics/anaconda3/bin/../lib/././libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:30:56.923825 open("/home/epics/anaconda3/bin/../lib/./libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.923864 open("/home/epics/anaconda3/bin/../lib/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.923901 open("/usr/local/lib/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.923938 open("/usr/local/lib64/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.923975 open("/usr/local64/lib/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.924012 open("/usr/local/epics/extensions/lib/linux-x86/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.924053 open("/lib64/libresolv.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:30:56.924094 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@9\0\0\0\0\0\0@\0\0\0\0\0\0\0\340\230\1\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\"\0!\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\254R\1\0\0\0\0\0\254R\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0HU\1\0\0\0\0\0HU!\0\0\0\0\0HU!\0\0\0\0\0\214\f\0\0\0\0\0\0\2704\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\210]\1\0\0\0\0\0\210]!\0\0\0\0\0\210]!\0\0\0\0\0\20\2\0\0\0\0\0\0\20\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:30:56.924148 fstat(3, {st_mode=S_IFREG|0755, st_size=106848, ...}) = 0 <0.000010>
17:30:56.924187 mmap(NULL, 2198016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f9bdd55d000 <0.000013>
17:30:56.924224 mprotect(0x7f9bdd573000, 2093056, PROT_NONE) = 0 <0.000015>
17:30:56.924262 mmap(0x7f9bdd772000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f9bdd772000 <0.000015>
17:30:56.924305 mmap(0x7f9bdd774000, 6656, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f9bdd774000 <0.000013>
17:30:56.924346 close(3)                = 0 <0.000010>
17:30:56.924385 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bdd55c000 <0.000011>
17:30:56.924451 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bdd55b000 <0.000013>
17:30:56.924507 mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bdd559000 <0.000011>
17:30:56.924545 arch_prctl(ARCH_SET_FS, 0x7f9bdd559740) = 0 <0.000011>
17:30:56.924658 mprotect(0x7f9bde0f2000, 16384, PROT_READ) = 0 <0.000013>
17:30:56.924702 mprotect(0x7f9bdd772000, 4096, PROT_READ) = 0 <0.000011>
17:30:56.924742 mprotect(0x7f9bde313000, 4096, PROT_READ) = 0 <0.000017>
17:30:56.924792 mprotect(0x7f9bdd987000, 4096, PROT_READ) = 0 <0.000012>
17:30:56.925112 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffd7d377450) = -1 ENOENT (No such file or directory) <0.000014>
17:30:56.925172 mprotect(0x7f9bddd00000, 176128, PROT_READ) = 0 <0.000012>
17:30:56.925251 mprotect(0x7f9bdd783000, 4096, PROT_READ) = 0 <0.000010>
17:30:56.925295 mprotect(0x7f9bde547000, 4096, PROT_READ) = 0 <0.000010>
17:30:56.925417 mprotect(0x7f9bde564000, 8192, PROT_READ) = 0 <0.000011>
17:30:56.925633 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffd7d377450) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.925789 mprotect(0x7f9bdda55000, 61440, PROT_READ) = 0 <0.000012>
17:30:56.925964 mprotect(0x7f9bde5b5000, 8192, PROT_READ) = 0 <0.000011>
17:30:56.926249 mprotect(0x7f9bde63c000, 36864, PROT_READ) = 0 <0.000012>
17:30:56.926341 mprotect(0x7f9bde678000, 4096, PROT_READ) = 0 <0.000010>
17:30:56.926377 mprotect(0x7f9bde51f000, 4096, PROT_READ) = 0 <0.000014>
17:30:56.926422 mprotect(0x7f9bde6b6000, 4096, PROT_READ) = 0 <0.000010>
17:30:56.926482 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffd7d377450) = -1 ENOENT (No such file or directory) <0.000010>
17:30:56.926635 mprotect(0x7f9bde73d000, 12288, PROT_READ) = 0 <0.000011>
17:30:56.926702 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffd7d377450) = -1 ENOENT (No such file or directory) <0.000011>
17:30:56.926771 mprotect(0x55c95c6cf000, 16384, PROT_READ) = 0 <0.000014>
17:30:56.926812 mprotect(0x7f9bde742000, 4096, PROT_READ) = 0 <0.000012>
17:30:56.926847 munmap(0x7f9bde67b000, 118229) = 0 <0.000018>
17:30:56.926892 set_tid_address(0x7f9bdd559a10) = 30847 <0.000014>
17:30:56.926943 set_robust_list(0x7f9bdd559a20, 24) = 0 <0.000009>
17:30:56.926980 rt_sigaction(SIGRTMIN, {0x7f9bde1037e0, [], SA_RESTORER|SA_SIGINFO, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:56.927023 rt_sigaction(SIGRT_1, {0x7f9bde103870, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:56.927057 rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0 <0.000011>
17:30:56.927105 getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0 <0.000009>
17:30:56.927195 pipe([3, 4])            = 0 <0.000012>
17:30:56.927232 close(3)                = 0 <0.000010>
17:30:56.927264 close(4)                = 0 <0.000011>
17:30:56.927296 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bddd662f0}, {SIG_DFL, [], 0}, 8) = 0 <0.000009>
17:30:56.927364 brk(NULL)               = 0x55c95e020000 <0.000009>
17:30:56.927394 brk(0x55c95e041000)     = 0x55c95e041000 <0.000010>
17:30:56.927426 brk(NULL)               = 0x55c95e041000 <0.000009>
17:30:56.927493 futex(0x7f9bddd2e838, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000010>
17:30:56.927525 futex(0x7f9bddd2e82c, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000010>
17:30:56.927558 futex(0x7f9bddd2e824, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000012>
17:30:56.927618 futex(0x7f9bddd2cc8c, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000010>
17:30:56.927666 futex(0x7f9bddd2e6e4, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.927707 futex(0x7f9bddd2e67c, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.927741 futex(0x7f9bddd2e670, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.928445 futex(0x7f9bddd2e81c, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.928476 futex(0x7f9bddd2e7d8, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.928509 futex(0x7f9bddd2e7d0, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.928544 getuid()                = 849601092 <0.000016>
17:30:56.928585 geteuid()               = 849601092 <0.000009>
17:30:56.928616 getgid()                = 849600513 <0.000009>
17:30:56.928645 getegid()               = 849600513 <0.000009>
17:30:56.928690 open("/home/epics/anaconda3/ssl/openssl.cnf", O_RDONLY) = 3 <0.000013>
17:30:56.928742 fstat(3, {st_mode=S_IFREG|0664, st_size=10909, ...}) = 0 <0.000009>
17:30:56.928778 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde697000 <0.000011>
17:30:56.928826 read(3, "#\n# OpenSSL example configuration file.\n# This is mostly being used for generation of certificate requests.\n#\n\n# Note that you can include other files from the main configuration\n# file using the .include directive.\n#.include filename\n\n# This definition st"..., 4096) = 4096 <0.000019>
17:30:56.928938 read(3, "# WARNING: ancient versions of Netscape crash on BMPStrings or UTF8Strings.\nstring_mask = utf8only\n\n# req_extensions = v3_req # The extensions to add to a certificate request\n\n[ req_distinguished_name ]\ncountryName\t\t\t= Country Name (2 letter code)\ncountryN"..., 4096) = 4096 <0.000009>
17:30:56.929032 read(3, "es of the usage of nsCertType. If it is omitted\n# the certificate can be used for anything *except* object signing.\n\n# This is OK for an SSL server.\n# nsCertType\t\t\t= server\n\n# For an object signing certificate this would be used.\n# nsCertType = objsign\n\n# "..., 4096) = 2717 <0.000010>
17:30:56.929091 read(3, "", 4096)       = 0 <0.000010>
17:30:56.929125 close(3)                = 0 <0.000011>
17:30:56.929158 munmap(0x7f9bde697000, 4096) = 0 <0.000015>
17:30:56.929227 socket(AF_INET6, SOCK_DGRAM, IPPROTO_IP) = 3 <0.000012>
17:30:56.929267 close(3)                = 0 <0.000013>
17:30:56.929309 futex(0x7f9bddd2e918, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.929443 futex(0x7f9bddd2e810, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000010>
17:30:56.929509 futex(0x7f9bddd2e808, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000010>
17:30:56.929585 brk(NULL)               = 0x55c95e041000 <0.000010>
17:30:56.929620 brk(0x55c95e062000)     = 0x55c95e062000 <0.000010>
17:30:56.929677 open("/home/epics/.curlrc", O_RDONLY) = -1 ENOENT (No such file or directory) <0.000012>
17:30:56.929747 open("TrajectoryScan.trj", O_RDONLY) = 3 <0.000013>
17:30:56.929807 fstat(3, {st_mode=S_IFREG|0664, st_size=5149, ...}) = 0 <0.000015>
17:30:56.929911 ioctl(0, TIOCGWINSZ, {ws_row=44, ws_col=154, ws_xpixel=0, ws_ypixel=0}) = 0 <0.000012>
17:30:56.930001 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bddd662f0}, 8) = 0 <0.000013>
17:30:56.930052 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:56.930105 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000015>
17:30:56.930165 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:56.930260 mmap(NULL, 8392704, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x7f9bdcd58000 <0.000011>
17:30:56.930302 mprotect(0x7f9bdcd58000, 4096, PROT_NONE) = 0 <0.000011>
17:30:56.930336 clone(strace: Process 30848 attached
child_stack=0x7f9bdd557fb0, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x7f9bdd5589d0, tls=0x7f9bdd558700, child_tidptr=0x7f9bdd5589d0) = 30848 <0.000045>
[pid 30848] 17:30:56.930406 set_robust_list(0x7f9bdd5589e0, 24 <unfinished ...>
[pid 30847] 17:30:56.930428 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.930448 <... set_robust_list resumed> ) = 0 <0.000025>
[pid 30847] 17:30:56.930461 <... write resumed> ) = 1 <0.000024>
[pid 30847] 17:30:56.930479 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.930498 socket(AF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0 <unfinished ...>
[pid 30847] 17:30:56.930518 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.930535 <... socket resumed> ) = 4 <0.000025>
[pid 30847] 17:30:56.930545 write(2, "%", 1% <unfinished ...>
[pid 30848] 17:30:56.930574 connect(4, {sa_family=AF_LOCAL, sun_path="/var/run/nscd/socket"}, 110 <unfinished ...>
[pid 30847] 17:30:56.930593 <... write resumed> ) = 1 <0.000037>
[pid 30848] 17:30:56.930608 <... connect resumed> ) = -1 ENOENT (No such file or directory) <0.000021>
[pid 30847] 17:30:56.930620 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.930640 close(4 <unfinished ...>
[pid 30847] 17:30:56.930650 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.930665 <... close resumed> ) = 0 <0.000019>
[pid 30847] 17:30:56.930675 write(2, "T", 1T <unfinished ...>
[pid 30848] 17:30:56.930697 socket(AF_LOCAL, SOCK_STREAM|SOCK_CLOEXEC|SOCK_NONBLOCK, 0 <unfinished ...>
[pid 30847] 17:30:56.930738 <... write resumed> ) = 1 <0.000050>
[pid 30848] 17:30:56.930752 <... socket resumed> ) = 4 <0.000029>
[pid 30847] 17:30:56.930768 write(2, "o", 1 <unfinished ...>
o[pid 30848] 17:30:56.930783 connect(4, {sa_family=AF_LOCAL, sun_path="/var/run/nscd/socket"}, 110 <unfinished ...>
[pid 30847] 17:30:56.930803 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.930818 <... connect resumed> ) = -1 ENOENT (No such file or directory) <0.000025>
[pid 30847] 17:30:56.930829 write(2, "t", 1t <unfinished ...>
[pid 30848] 17:30:56.930848 close(4 <unfinished ...>
[pid 30847] 17:30:56.930888 <... write resumed> ) = 1 <0.000044>
[pid 30848] 17:30:56.930907 <... close resumed> ) = 0 <0.000040>
[pid 30847] 17:30:56.930929 write(2, "a", 1a <unfinished ...>
[pid 30848] 17:30:56.930955 mmap(NULL, 134217728, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS|MAP_NORESERVE, -1, 0 <unfinished ...>
[pid 30847] 17:30:56.930975 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.930990 <... mmap resumed> ) = 0x7f9bd4d58000 <0.000026>
[pid 30847] 17:30:56.931001 write(2, "l", 1l <unfinished ...>
[pid 30848] 17:30:56.931020 munmap(0x7f9bd4d58000, 53116928 <unfinished ...>
[pid 30847] 17:30:56.931036 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.931050 <... munmap resumed> ) = 0 <0.000024>
[pid 30847] 17:30:56.931060 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.931078 munmap(0x7f9bdc000000, 13991936 <unfinished ...>
[pid 30847] 17:30:56.931093 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.931110 <... munmap resumed> ) = 0 <0.000026>
[pid 30847] 17:30:56.931120 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.931139 mprotect(0x7f9bd8000000, 135168, PROT_READ|PROT_WRITE <unfinished ...>
[pid 30847] 17:30:56.931151 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.931166 <... mprotect resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.931175 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.931196 open("/etc/nsswitch.conf", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.931211 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.931226 <... open resumed> ) = 4 <0.000020>
[pid 30847] 17:30:56.931236 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.931256 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.931267 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.931282 <... fstat resumed> {st_mode=S_IFREG|0644, st_size=1717, ...}) = 0 <0.000019>
[pid 30847] 17:30:56.931295 write(2, "%", 1% <unfinished ...>
[pid 30848] 17:30:56.931315 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0 <unfinished ...>
[pid 30847] 17:30:56.931327 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.931342 <... mmap resumed> ) = 0x7f9bde697000 <0.000019>
[pid 30847] 17:30:56.931351 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.931371 read(4,  <unfinished ...>
[pid 30847] 17:30:56.931382 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.931396 <... read resumed> "#\n# /etc/nsswitch.conf\n#\n# An example Name Service Switch config file. This file should be\n# sorted with the most-used services at the beginning.\n#\n# The entry '[NOTFOUND=return]' means that the search for an\n# entry should stop if the search in the previo"..., 4096) = 1717 <0.000019>
[pid 30847] 17:30:56.931409 write(2, "R", 1R <unfinished ...>
[pid 30848] 17:30:56.931436 read(4,  <unfinished ...>
[pid 30847] 17:30:56.931448 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.931463 <... read resumed> "", 4096) = 0 <0.000019>
[pid 30847] 17:30:56.931473 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.931493 close(4 <unfinished ...>
[pid 30847] 17:30:56.931504 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.931519 <... close resumed> ) = 0 <0.000019>
[pid 30847] 17:30:56.931528 write(2, "c", 1c <unfinished ...>
[pid 30848] 17:30:56.931548 munmap(0x7f9bde697000, 4096 <unfinished ...>
[pid 30847] 17:30:56.931565 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.931587 <... munmap resumed> ) = 0 <0.000033>
[pid 30847] 17:30:56.931603 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.931622 stat("/etc/resolv.conf",  <unfinished ...>
[pid 30847] 17:30:56.931641 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.931656 <... stat resumed> {st_mode=S_IFREG|0644, st_size=104, ...}) = 0 <0.000025>
[pid 30847] 17:30:56.931668 write(2, "i", 1i <unfinished ...>
[pid 30848] 17:30:56.931688 open("/etc/host.conf", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.931702 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.931717 <... open resumed> ) = 4 <0.000020>
[pid 30847] 17:30:56.931727 write(2, "v", 1v <unfinished ...>
[pid 30848] 17:30:56.931747 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.931757 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.931772 <... fstat resumed> {st_mode=S_IFREG|0644, st_size=9, ...}) = 0 <0.000019>
[pid 30847] 17:30:56.931784 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.931804 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0 <unfinished ...>
[pid 30847] 17:30:56.931816 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.931831 <... mmap resumed> ) = 0x7f9bde697000 <0.000020>
[pid 30847] 17:30:56.931841 write(2, "d", 1d <unfinished ...>
[pid 30848] 17:30:56.931861 read(4,  <unfinished ...>
[pid 30847] 17:30:56.931871 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.931887 <... read resumed> "multi on\n", 4096) = 9 <0.000021>
[pid 30847] 17:30:56.931898 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.931917 read(4,  <unfinished ...>
[pid 30847] 17:30:56.931927 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.931942 <... read resumed> "", 4096) = 0 <0.000019>
[pid 30847] 17:30:56.931953 write(2, "%", 1% <unfinished ...>
[pid 30848] 17:30:56.931972 close(4 <unfinished ...>
[pid 30847] 17:30:56.931983 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.931998 <... close resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.932008 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.932028 munmap(0x7f9bde697000, 4096 <unfinished ...>
[pid 30847] 17:30:56.932038 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.932054 <... munmap resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.932064 write(2, "X", 1X <unfinished ...>
[pid 30848] 17:30:56.932084 futex(0x7f9bde0faa30, FUTEX_WAKE_PRIVATE, 2147483647 <unfinished ...>
[pid 30847] 17:30:56.932095 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.932110 <... futex resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.932120 write(2, "f", 1f <unfinished ...>
[pid 30848] 17:30:56.932139 open("/etc/resolv.conf", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932152 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.932167 <... open resumed> ) = 4 <0.000019>
[pid 30847] 17:30:56.932176 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.932196 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.932206 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.932221 <... fstat resumed> {st_mode=S_IFREG|0644, st_size=104, ...}) = 0 <0.000019>
[pid 30847] 17:30:56.932233 write(2, "r", 1r <unfinished ...>
[pid 30848] 17:30:56.932253 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0 <unfinished ...>
[pid 30847] 17:30:56.932265 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.932280 <... mmap resumed> ) = 0x7f9bde697000 <0.000019>
[pid 30847] 17:30:56.932289 write(2, "d", 1d <unfinished ...>
[pid 30848] 17:30:56.932310 read(4,  <unfinished ...>
[pid 30847] 17:30:56.932320 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.932335 <... read resumed> "# Generated by NetworkManager\nsearch cars.aps.anl.gov\nnameserver 164.54.162.61\nnameserver 164.54.160.45\n", 4096) = 104 <0.000020>
[pid 30847] 17:30:56.932347 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.932365 read(4,  <unfinished ...>
[pid 30847] 17:30:56.932383 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.932392 <... read resumed> "", 4096) = 0 <0.000020>
[pid 30847] 17:30:56.932407 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.932422 close(4 <unfinished ...>
[pid 30847] 17:30:56.932444 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.932453 <... close resumed> ) = 0 <0.000021>
[pid 30847] 17:30:56.932469 write(2, "A", 1A <unfinished ...>
[pid 30848] 17:30:56.932484 munmap(0x7f9bde697000, 4096 <unfinished ...>
[pid 30847] 17:30:56.932499 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.932514 <... munmap resumed> ) = 0 <0.000023>
[pid 30847] 17:30:56.932523 write(2, "v", 1v <unfinished ...>
[pid 30848] 17:30:56.932543 open("/home/epics/anaconda3/bin/../lib/libnss_files.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932556 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.932581 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000030>
[pid 30847] 17:30:56.932593 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.932611 open("/usr/local/lib/libnss_files.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932632 <... write resumed> ) = 1 <0.000028>
[pid 30848] 17:30:56.932641 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000021>
[pid 30847] 17:30:56.932657 write(2, "r", 1r <unfinished ...>
[pid 30848] 17:30:56.932672 open("/usr/local/lib64/libnss_files.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932691 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.932700 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000021>
[pid 30847] 17:30:56.932716 write(2, "a", 1a <unfinished ...>
[pid 30848] 17:30:56.932731 open("/usr/local64/lib/libnss_files.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932750 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.932759 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000021>
[pid 30847] 17:30:56.932775 write(2, "g", 1g <unfinished ...>
[pid 30848] 17:30:56.932790 open("/usr/local/epics/extensions/lib/linux-x86/libnss_files.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932809 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.932818 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000021>
[pid 30847] 17:30:56.932834 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.932848 open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.932867 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.932876 <... open resumed> ) = 4 <0.000021>
[pid 30847] 17:30:56.932892 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.932906 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.932924 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.932933 <... fstat resumed> {st_mode=S_IFREG|0644, st_size=118229, ...}) = 0 <0.000021>
[pid 30847] 17:30:56.932951 write(2, "S", 1S <unfinished ...>
[pid 30848] 17:30:56.932966 mmap(NULL, 118229, PROT_READ, MAP_PRIVATE, 4, 0 <unfinished ...>
[pid 30847] 17:30:56.932984 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.932993 <... mmap resumed> ) = 0x7f9bde67b000 <0.000021>
[pid 30847] 17:30:56.933010 write(2, "p", 1p <unfinished ...>
[pid 30848] 17:30:56.933025 close(4 <unfinished ...>
[pid 30847] 17:30:56.933042 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.933051 <... close resumed> ) = 0 <0.000021>
[pid 30847] 17:30:56.933064 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.933084 open("/lib64/libnss_files.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.933097 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.933113 <... open resumed> ) = 4 <0.000020>
[pid 30847] 17:30:56.933122 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.933143 read(4,  <unfinished ...>
[pid 30847] 17:30:56.933153 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.933168 <... read resumed> "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320!\0\0\0\0\0\0@\0\0\0\0\0\0\0\250\352\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0!\0 \0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\314\262\0\0\0\0\0\0\314\262\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\200\275\0\0\0\0\0\0\200\275 \0\0\0\0\0\200\275 \0\0\0\0\0\330\3\0\0\0\0\0\0\370j\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\240\275\0\0\0\0\0\0\240\275 \0\0\0\0\0\240\275 \0\0\0\0\0\20\2\0\0\0\0\0\0\20\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000019>
[pid 30847] 17:30:56.933186 write(2, "d", 1d <unfinished ...>
[pid 30848] 17:30:56.933207 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.933217 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.933232 <... fstat resumed> {st_mode=S_IFREG|0755, st_size=62184, ...}) = 0 <0.000020>
[pid 30847] 17:30:56.933244 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933264 mmap(NULL, 2173048, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0 <unfinished ...>
[pid 30847] 17:30:56.933276 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.933291 <... mmap resumed> ) = 0x7f9bdcb45000 <0.000019>
[pid 30847] 17:30:56.933300 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933320 mprotect(0x7f9bdcb51000, 2093056, PROT_NONE <unfinished ...>
[pid 30847] 17:30:56.933331 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.933346 <... mprotect resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.933356 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933373 mmap(0x7f9bdcd50000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0xb000 <unfinished ...>
[pid 30847] 17:30:56.933392 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.933407 <... mmap resumed> ) = 0x7f9bdcd50000 <0.000024>
[pid 30847] 17:30:56.933417 write(2, "T", 1T <unfinished ...>
[pid 30848] 17:30:56.933436 mmap(0x7f9bdcd52000, 22648, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0 <unfinished ...>
[pid 30847] 17:30:56.933448 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.933463 <... mmap resumed> ) = 0x7f9bdcd52000 <0.000019>
[pid 30847] 17:30:56.933473 write(2, "i", 1i <unfinished ...>
[pid 30848] 17:30:56.933491 close(4 <unfinished ...>
[pid 30847] 17:30:56.933510 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.933518 <... close resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.933531 write(2, "m", 1m <unfinished ...>
[pid 30848] 17:30:56.933551 mprotect(0x7f9bdcd50000, 4096, PROT_READ <unfinished ...>
[pid 30847] 17:30:56.933569 <... write resumed> ) = 1 <0.000026>
[pid 30848] 17:30:56.933586 <... mprotect resumed> ) = 0 <0.000028>
[pid 30847] 17:30:56.933596 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.933616 munmap(0x7f9bde67b000, 118229 <unfinished ...>
[pid 30847] 17:30:56.933627 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.933642 <... munmap resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.933652 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933672 open("/etc/hosts", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.933687 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.933702 <... open resumed> ) = 4 <0.000020>
[pid 30847] 17:30:56.933712 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933732 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.933742 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.933757 <... fstat resumed> {st_mode=S_IFREG|0644, st_size=158, ...}) = 0 <0.000020>
[pid 30847] 17:30:56.933770 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933790 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0 <unfinished ...>
[pid 30847] 17:30:56.933802 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.933816 <... mmap resumed> ) = 0x7f9bde697000 <0.000019>
[pid 30847] 17:30:56.933826 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.933846 read(4,  <unfinished ...>
[pid 30847] 17:30:56.933857 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.933872 <... read resumed> "127.0.0.1   localhost localhost.localdomain localhost4 localhost4.localdomain4\n::1         localhost localhost.localdomain localhost6 localhost6.localdomain6\n", 4096) = 158 <0.000019>
[pid 30847] 17:30:56.933884 write(2, "T", 1T <unfinished ...>
[pid 30848] 17:30:56.933903 read(4,  <unfinished ...>
[pid 30847] 17:30:56.933914 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.933933 <... read resumed> "", 4096) = 0 <0.000024>
[pid 30847] 17:30:56.933944 write(2, "i", 1i <unfinished ...>
[pid 30848] 17:30:56.933961 close(4 <unfinished ...>
[pid 30847] 17:30:56.933981 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.933989 <... close resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.934006 write(2, "m", 1m <unfinished ...>
[pid 30848] 17:30:56.934021 munmap(0x7f9bde697000, 4096 <unfinished ...>
[pid 30847] 17:30:56.934037 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.934051 <... munmap resumed> ) = 0 <0.000024>
[pid 30847] 17:30:56.934061 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.934078 open("/home/epics/anaconda3/bin/../lib/libnss_dns.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934097 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.934113 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000025>
[pid 30847] 17:30:56.934123 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934143 open("/usr/local/lib/libnss_dns.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934157 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.934172 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000020>
[pid 30847] 17:30:56.934182 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934202 open("/usr/local/lib64/libnss_dns.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934214 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.934229 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000019>
[pid 30847] 17:30:56.934239 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934259 open("/usr/local64/lib/libnss_dns.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934272 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.934287 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000019>
[pid 30847] 17:30:56.934297 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934316 open("/usr/local/epics/extensions/lib/linux-x86/libnss_dns.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934329 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.934344 <... open resumed> ) = -1 ENOENT (No such file or directory) <0.000020>
[pid 30847] 17:30:56.934354 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934373 open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934386 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.934401 <... open resumed> ) = 4 <0.000019>
[pid 30847] 17:30:56.934410 write(2, "T", 1T <unfinished ...>
[pid 30848] 17:30:56.934428 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.934447 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.934456 <... fstat resumed> {st_mode=S_IFREG|0644, st_size=118229, ...}) = 0 <0.000020>
[pid 30847] 17:30:56.934474 write(2, "i", 1i <unfinished ...>
[pid 30848] 17:30:56.934489 mmap(NULL, 118229, PROT_READ, MAP_PRIVATE, 4, 0 <unfinished ...>
[pid 30847] 17:30:56.934508 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.934517 <... mmap resumed> ) = 0x7f9bde67b000 <0.000022>
[pid 30847] 17:30:56.934532 write(2, "m", 1m <unfinished ...>
[pid 30848] 17:30:56.934546 close(4 <unfinished ...>
[pid 30847] 17:30:56.934571 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.934581 <... close resumed> ) = 0 <0.000028>
[pid 30847] 17:30:56.934595 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.934615 open("/lib64/libnss_dns.so.2", O_RDONLY|O_CLOEXEC <unfinished ...>
[pid 30847] 17:30:56.934629 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.934644 <... open resumed> ) = 4 <0.000020>
[pid 30847] 17:30:56.934654 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934671 read(4,  <unfinished ...>
[pid 30847] 17:30:56.934691 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.934700 <... read resumed> "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\20\0\0\0\0\0\0@\0\0\0\0\0\0\0\20t\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0!\0 \0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0xO\0\0\0\0\0\0xO\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0p]\0\0\0\0\0\0p] \0\0\0\0\0p] \0\0\0\0\0\210\3\0\0\0\0\0\0\220\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\220]\0\0\0\0\0\0\220] \0\0\0\0\0\220] \0\0\0\0\0 \2\0\0\0\0\0\0 \2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000020>
[pid 30847] 17:30:56.934723 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.934739 fstat(4,  <unfinished ...>
[pid 30847] 17:30:56.934756 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.934765 <... fstat resumed> {st_mode=S_IFREG|0755, st_size=31824, ...}) = 0 <0.000021>
[pid 30847] 17:30:56.934784 write(2, "C", 1C <unfinished ...>
[pid 30848] 17:30:56.934799 mmap(NULL, 2121984, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0 <unfinished ...>
[pid 30847] 17:30:56.934838 <... write resumed> ) = 1 <0.000041>
[pid 30848] 17:30:56.934852 <... mmap resumed> ) = 0x7f9bdc93e000 <0.000029>
[pid 30847] 17:30:56.934869 write(2, "u", 1u <unfinished ...>
[pid 30848] 17:30:56.934885 mprotect(0x7f9bdc943000, 2097152, PROT_NONE <unfinished ...>
[pid 30847] 17:30:56.934902 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.934917 <... mprotect resumed> ) = 0 <0.000025>
[pid 30847] 17:30:56.934927 write(2, "r", 1r <unfinished ...>
[pid 30848] 17:30:56.934947 mmap(0x7f9bdcb43000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x5000 <unfinished ...>
[pid 30847] 17:30:56.934960 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.934974 <... mmap resumed> ) = 0x7f9bdcb43000 <0.000020>
[pid 30847] 17:30:56.934984 write(2, "r", 1r <unfinished ...>
[pid 30848] 17:30:56.935012 close(4 <unfinished ...>
[pid 30847] 17:30:56.935031 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.935039 <... close resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.935051 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.935069 mprotect(0x7f9bdcb43000, 4096, PROT_READ <unfinished ...>
[pid 30847] 17:30:56.935085 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.935099 <... mprotect resumed> ) = 0 <0.000023>
[pid 30847] 17:30:56.935108 write(2, "n", 1n <unfinished ...>
[pid 30848] 17:30:56.935128 munmap(0x7f9bde67b000, 118229 <unfinished ...>
[pid 30847] 17:30:56.935139 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.935154 <... munmap resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.935164 write(2, "t", 1t) = 1 <0.000012>
[pid 30847] 17:30:56.935199 write(2, "\n", 1
 <unfinished ...>
[pid 30848] 17:30:56.935217 socket(AF_INET, SOCK_DGRAM|SOCK_CLOEXEC|SOCK_NONBLOCK, IPPROTO_IP <unfinished ...>
[pid 30847] 17:30:56.935233 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.935248 <... socket resumed> ) = 4 <0.000023>
[pid 30847] 17:30:56.935257 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935277 connect(4, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, 16 <unfinished ...>
[pid 30847] 17:30:56.935300 <... write resumed> ) = 1 <0.000032>
[pid 30848] 17:30:56.935315 <... connect resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.935324 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935345 poll([{fd=4, events=POLLOUT}], 1, 0 <unfinished ...>
[pid 30847] 17:30:56.935362 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.935378 <... poll resumed> ) = 1 ([{fd=4, revents=POLLOUT}]) <0.000020>
[pid 30847] 17:30:56.935390 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935407 sendmmsg(4,  <unfinished ...>
[pid 30847] 17:30:56.935423 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.935438 <... sendmmsg resumed> {{{msg_name(0)=NULL, msg_iov(1)=[{"\231\243\1\0\0\1\0\0\0\0\0\0\1c\4cars\3aps\3anl\3gov\0\0\1\0\1", 36}], msg_controllen=0, msg_flags=0}, 36}, {{msg_name(0)=NULL, msg_iov(1)=[{"\32\324\1\0\0\1\0\0\0\0\0\0\1c\4cars\3aps\3anl\3gov\0\0\34\0\1", 36}], msg_controllen=0, msg_flags=0}, 36}}, 2, MSG_NOSIGNAL) = 2 <0.000024>
[pid 30847] 17:30:56.935460 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935478 poll([{fd=4, events=POLLIN}], 1, 5000 <unfinished ...>
[pid 30847] 17:30:56.935495 <... write resumed> ) = 1 <0.000024>
[pid 30847] 17:30:56.935520 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.935554 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.935599 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.935632 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.935664 write(2, " ", 1 ) = 1 <0.000013>
[pid 30847] 17:30:56.935700 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.935732 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935769 <... poll resumed> ) = 1 ([{fd=4, revents=POLLIN}]) <0.000276>
[pid 30847] 17:30:56.935791 <... write resumed> ) = 1 <0.000041>
[pid 30848] 17:30:56.935813 ioctl(4, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.935827 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935850 <... ioctl resumed> , [106]) = 0 <0.000027>
[pid 30847] 17:30:56.935862 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.935880 recvfrom(4,  <unfinished ...>
[pid 30847] 17:30:56.935894 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935915 <... recvfrom resumed> "\231\243\205\203\0\1\0\0\0\1\0\0\1c\4cars\3aps\3anl\3gov\0\0\1\0\1\4cars\3aps\3anl\3gov\0\0\6\0\1\0\1Q\200\0*\5cars1\300$\4root\6oxygen\300)\0$\323\6\0\0\7\10\0\0\2X\0\22u\0\0\1Q\200", 2048, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, [16]) = 106 <0.000024>
[pid 30847] 17:30:56.935933 <... write resumed> ) = 1 <0.000030>
[pid 30848] 17:30:56.935954 poll([{fd=4, events=POLLIN}], 1, 4999 <unfinished ...>
[pid 30847] 17:30:56.935970 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.935993 <... poll resumed> ) = 1 ([{fd=4, revents=POLLIN}]) <0.000026>
[pid 30847] 17:30:56.936005 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.936022 ioctl(4, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.936036 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936053 <... ioctl resumed> , [106]) = 0 <0.000020>
[pid 30847] 17:30:56.936068 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.936086 recvfrom(4,  <unfinished ...>
[pid 30847] 17:30:56.936099 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936121 <... recvfrom resumed> "\32\324\205\203\0\1\0\0\0\1\0\0\1c\4cars\3aps\3anl\3gov\0\0\34\0\1\4cars\3aps\3anl\3gov\0\0\6\0\1\0\1Q\200\0*\5cars1\300$\4root\6oxygen\300)\0$\323\6\0\0\7\10\0\0\2X\0\22u\0\0\1Q\200", 65536, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, [16]) = 106 <0.000026>
[pid 30847] 17:30:56.936139 <... write resumed> ) = 1 <0.000028>
[pid 30848] 17:30:56.936158 close(4 <unfinished ...>
[pid 30847] 17:30:56.936170 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936193 <... close resumed> ) = 0 <0.000025>
[pid 30847] 17:30:56.936203 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.936222 socket(AF_INET, SOCK_DGRAM|SOCK_CLOEXEC|SOCK_NONBLOCK, IPPROTO_IP <unfinished ...>
[pid 30847] 17:30:56.936236 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936256 <... socket resumed> ) = 4 <0.000023>
[pid 30847] 17:30:56.936272 <... write resumed> ) = 1 <0.000026>
[pid 30848] 17:30:56.936282 connect(4, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, 16 <unfinished ...>
[pid 30847] 17:30:56.936303 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936320 <... connect resumed> ) = 0 <0.000027>
[pid 30847] 17:30:56.936336 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.936346 poll([{fd=4, events=POLLOUT}], 1, 0 <unfinished ...>
[pid 30847] 17:30:56.936367 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936381 <... poll resumed> ) = 1 ([{fd=4, revents=POLLOUT}]) <0.000022>
[pid 30847] 17:30:56.936400 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.936410 sendmmsg(4,  <unfinished ...>
[pid 30847] 17:30:56.936428 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936451 <... sendmmsg resumed> {{{msg_name(0)=NULL, msg_iov(1)=[{"\276\310\1\0\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 19}], msg_controllen=0, msg_flags=MSG_DONTWAIT|MSG_EOR|MSG_WAITALL|MSG_SYN|MSG_RST|MSG_ERRQUEUE|MSG_NOSIGNAL|MSG_WAITFORONE|MSG_BATCH|MSG_CMSG_CLOEXEC|0x9d500010}, 19}, {{msg_name(0)=NULL, msg_iov(1)=[{"\256\317\1\0\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 19}], msg_controllen=0, msg_flags=0}, 19}}, 2, MSG_NOSIGNAL) = 2 <0.000032>
[pid 30847] 17:30:56.936478 <... write resumed> ) = 1 <0.000038>
[pid 30848] 17:30:56.936496 poll([{fd=4, events=POLLIN}], 1, 5000 <unfinished ...>
[pid 30847] 17:30:56.936511 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.936544 write(2, " ", 1 ) = 1 <0.000017>
[pid 30847] 17:30:56.936589 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.936623 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.936655 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.936688 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.936723 write(2, " ", 1 ) = 1 <0.000013>
[pid 30847] 17:30:56.936758 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936778 <... poll resumed> ) = 1 ([{fd=4, revents=POLLIN}]) <0.000270>
[pid 30847] 17:30:56.936789 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.936804 ioctl(4, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.936816 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936832 <... ioctl resumed> , [19]) = 0 <0.000018>
[pid 30847] 17:30:56.936849 <... write resumed> ) = 1 <0.000025>
[pid 30848] 17:30:56.936858 recvfrom(4,  <unfinished ...>
[pid 30847] 17:30:56.936875 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936889 <... recvfrom resumed> "\276\310\201\202\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 2048, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, [16]) = 19 <0.000021>
[pid 30847] 17:30:56.936909 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.936919 poll([{fd=4, events=POLLIN}], 1, 4999 <unfinished ...>
[pid 30847] 17:30:56.936939 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.936952 <... poll resumed> ) = 1 ([{fd=4, revents=POLLIN}]) <0.000021>
[pid 30847] 17:30:56.936969 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.936978 ioctl(4, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.936995 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.937010 <... ioctl resumed> , [19]) = 0 <0.000020>
[pid 30847] 17:30:56.937026 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.937036 recvfrom(4,  <unfinished ...>
[pid 30847] 17:30:56.937052 write(2, "D", 1D <unfinished ...>
[pid 30848] 17:30:56.937066 <... recvfrom resumed> "\256\317\201\202\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 65536, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, [16]) = 19 <0.000021>
[pid 30847] 17:30:56.937085 <... write resumed> ) = 1 <0.000026>
[pid 30848] 17:30:56.937095 socket(AF_INET, SOCK_DGRAM|SOCK_CLOEXEC|SOCK_NONBLOCK, IPPROTO_IP <unfinished ...>
[pid 30847] 17:30:56.937112 write(2, "l", 1l <unfinished ...>
[pid 30848] 17:30:56.937131 <... socket resumed> ) = 5 <0.000026>
[pid 30847] 17:30:56.937139 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.937154 connect(5, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.160.45")}, 16 <unfinished ...>
[pid 30847] 17:30:56.937168 write(2, "o", 1o <unfinished ...>
[pid 30848] 17:30:56.937186 <... connect resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.937195 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.937210 poll([{fd=5, events=POLLOUT}], 1, 0 <unfinished ...>
[pid 30847] 17:30:56.937223 write(2, "a", 1a <unfinished ...>
[pid 30848] 17:30:56.937242 <... poll resumed> ) = 1 ([{fd=5, revents=POLLOUT}]) <0.000020>
[pid 30847] 17:30:56.937252 <... write resumed> ) = 1 <0.000023>
[pid 30848] 17:30:56.937267 sendmmsg(5,  <unfinished ...>
[pid 30847] 17:30:56.937278 write(2, "d", 1d <unfinished ...>
[pid 30848] 17:30:56.937294 <... sendmmsg resumed> {{{msg_name(0)=NULL, msg_iov(1)=[{"\276\310\1\0\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 19}], msg_controllen=0, msg_flags=MSG_DONTWAIT|MSG_EOR|MSG_WAITALL|MSG_SYN|MSG_RST|MSG_ERRQUEUE|MSG_NOSIGNAL|MSG_WAITFORONE|MSG_BATCH|MSG_CMSG_CLOEXEC|0x9d500010}, 19}, {{msg_name(0)=NULL, msg_iov(1)=[{"\256\317\1\0\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 19}], msg_controllen=0, msg_flags=0}, 19}}, 2, MSG_NOSIGNAL) = 2 <0.000017>
[pid 30847] 17:30:56.937324 <... write resumed> ) = 1 <0.000039>
[pid 30848] 17:30:56.937335 poll([{fd=5, events=POLLIN}], 1, 5000 <unfinished ...>
[pid 30847] 17:30:56.937364 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.937405 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.937444 write(2, "U", 1U) = 1 <0.000012>
[pid 30847] 17:30:56.937491 write(2, "p", 1p) = 1 <0.000010>
[pid 30847] 17:30:56.937525 write(2, "l", 1l) = 1 <0.000011>
[pid 30847] 17:30:56.937558 write(2, "o", 1o) = 1 <0.000012>
[pid 30847] 17:30:56.937605 write(2, "a", 1a) = 1 <0.000016>
[pid 30847] 17:30:56.937653 write(2, "d", 1d) = 1 <0.000011>
[pid 30847] 17:30:56.937695 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.937728 write(2, " ", 1 ) = 1 <0.000010>
[pid 30847] 17:30:56.937761 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.937794 write(2, "T", 1T) = 1 <0.000010>
[pid 30848] 17:30:56.937827 <... poll resumed> ) = 1 ([{fd=5, revents=POLLIN}]) <0.000483>
[pid 30847] 17:30:56.937840 write(2, "o", 1o <unfinished ...>
[pid 30848] 17:30:56.937860 ioctl(5, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.937871 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.937886 <... ioctl resumed> , [19]) = 0 <0.000019>
[pid 30847] 17:30:56.937897 write(2, "t", 1t <unfinished ...>
[pid 30848] 17:30:56.937917 recvfrom(5,  <unfinished ...>
[pid 30847] 17:30:56.937927 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.937942 <... recvfrom resumed> "\276\310\201\202\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 2048, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.160.45")}, [16]) = 19 <0.000019>
[pid 30847] 17:30:56.937957 write(2, "a", 1a <unfinished ...>
[pid 30848] 17:30:56.937977 poll([{fd=5, events=POLLIN}], 1, 4999 <unfinished ...>
[pid 30847] 17:30:56.937989 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.938003 <... poll resumed> ) = 1 ([{fd=5, revents=POLLIN}]) <0.000018>
[pid 30847] 17:30:56.938014 write(2, "l", 1l <unfinished ...>
[pid 30848] 17:30:56.938033 recvfrom(5,  <unfinished ...>
[pid 30847] 17:30:56.938044 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.938058 <... recvfrom resumed> "\256\317\201\202\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 65536, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.160.45")}, [16]) = 19 <0.000019>
[pid 30847] 17:30:56.938072 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.938090 poll([{fd=4, events=POLLOUT}], 1, 0 <unfinished ...>
[pid 30847] 17:30:56.938110 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.938119 <... poll resumed> ) = 1 ([{fd=4, revents=POLLOUT}]) <0.000020>
[pid 30847] 17:30:56.938135 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.938150 sendmmsg(4,  <unfinished ...>
[pid 30847] 17:30:56.938164 <... write resumed> ) = 1 <0.000019>
[pid 30848] 17:30:56.938178 <... sendmmsg resumed> {{{msg_name(0)=NULL, msg_iov(1)=[{"\276\310\1\0\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 19}], msg_controllen=0, msg_flags=MSG_DONTWAIT|MSG_EOR|MSG_WAITALL|MSG_SYN|MSG_RST|MSG_ERRQUEUE|MSG_NOSIGNAL|MSG_WAITFORONE|MSG_BATCH|MSG_CMSG_CLOEXEC|0x9d500010}, 19}, {{msg_name(0)=NULL, msg_iov(1)=[{"\256\317\1\0\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 19}], msg_controllen=0, msg_flags=0}, 19}}, 2, MSG_NOSIGNAL) = 2 <0.000023>
[pid 30847] 17:30:56.938199 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.938219 poll([{fd=4, events=POLLIN}], 1, 5000 <unfinished ...>
[pid 30847] 17:30:56.938233 <... write resumed> ) = 1 <0.000024>
[pid 30847] 17:30:56.938250 write(2, "S", 1S) = 1 <0.000011>
[pid 30847] 17:30:56.938285 write(2, "p", 1p) = 1 <0.000013>
[pid 30847] 17:30:56.938320 write(2, "e", 1e) = 1 <0.000011>
[pid 30847] 17:30:56.938353 write(2, "n", 1n) = 1 <0.000011>
[pid 30847] 17:30:56.938386 write(2, "t", 1t) = 1 <0.000010>
[pid 30847] 17:30:56.938418 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.938451 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.938475 <... poll resumed> ) = 1 ([{fd=4, revents=POLLIN}]) <0.000243>
[pid 30847] 17:30:56.938487 <... write resumed> ) = 1 <0.000028>
[pid 30848] 17:30:56.938501 ioctl(4, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.938517 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.938535 <... ioctl resumed> , [19]) = 0 <0.000021>
[pid 30847] 17:30:56.938546 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.938569 recvfrom(4,  <unfinished ...>
[pid 30847] 17:30:56.938585 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.938606 <... recvfrom resumed> "\276\310\201\202\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 2048, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, [16]) = 19 <0.000021>
[pid 30847] 17:30:56.938621 <... write resumed> ) = 1 <0.000027>
[pid 30848] 17:30:56.938635 poll([{fd=4, events=POLLIN}], 1, 4999 <unfinished ...>
[pid 30847] 17:30:56.938648 write(2, "L", 1L <unfinished ...>
[pid 30848] 17:30:56.938667 <... poll resumed> ) = 1 ([{fd=4, revents=POLLIN}]) <0.000019>
[pid 30847] 17:30:56.938678 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.938693 recvfrom(4,  <unfinished ...>
[pid 30847] 17:30:56.938704 write(2, "e", 1e <unfinished ...>
[pid 30848] 17:30:56.938724 <... recvfrom resumed> "\256\317\201\202\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 65536, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.162.61")}, [16]) = 19 <0.000021>
[pid 30847] 17:30:56.938738 <... write resumed> ) = 1 <0.000026>
[pid 30848] 17:30:56.938752 poll([{fd=5, events=POLLOUT}], 1, 0 <unfinished ...>
[pid 30847] 17:30:56.938765 write(2, "f", 1f <unfinished ...>
[pid 30848] 17:30:56.938796 <... poll resumed> ) = 1 ([{fd=5, revents=POLLOUT}]) <0.000026>
[pid 30847] 17:30:56.938821 <... write resumed> ) = 1 <0.000048>
[pid 30848] 17:30:56.938838 sendmmsg(5,  <unfinished ...>
[pid 30847] 17:30:56.938850 write(2, "t", 1t <unfinished ...>
[pid 30848] 17:30:56.938867 <... sendmmsg resumed> {{{msg_name(0)=NULL, msg_iov(1)=[{"\276\310\1\0\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 19}], msg_controllen=0, msg_flags=MSG_DONTWAIT|MSG_EOR|MSG_WAITALL|MSG_SYN|MSG_RST|MSG_ERRQUEUE|MSG_NOSIGNAL|MSG_WAITFORONE|MSG_BATCH|MSG_CMSG_CLOEXEC|0x9d500010}, 19}, {{msg_name(0)=NULL, msg_iov(1)=[{"\256\317\1\0\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 19}], msg_controllen=0, msg_flags=0}, 19}}, 2, MSG_NOSIGNAL) = 2 <0.000019>
[pid 30847] 17:30:56.938894 <... write resumed> ) = 1 <0.000037>
[pid 30848] 17:30:56.938904 poll([{fd=5, events=POLLIN}], 1, 5000 <unfinished ...>
[pid 30847] 17:30:56.938922 write(2, " ", 1 ) = 1 <0.000013>
[pid 30847] 17:30:56.938956 write(2, " ", 1 ) = 1 <0.000011>
[pid 30847] 17:30:56.938994 write(2, "S", 1S) = 1 <0.000016>
[pid 30847] 17:30:56.939052 write(2, "p", 1p) = 1 <0.000016>
[pid 30847] 17:30:56.939133 write(2, "e", 1e) = 1 <0.000015>
[pid 30847] 17:30:56.939182 write(2, "e", 1e) = 1 <0.000048>
[pid 30847] 17:30:56.939260 write(2, "d", 1d) = 1 <0.000012>
[pid 30847] 17:30:56.939298 write(2, "\n", 1
 <unfinished ...>
[pid 30848] 17:30:56.939324 <... poll resumed> ) = 1 ([{fd=5, revents=POLLIN}]) <0.000407>
[pid 30847] 17:30:56.939337 <... write resumed> ) = 1 <0.000029>
[pid 30848] 17:30:56.939348 ioctl(5, FIONREAD <unfinished ...>
[pid 30847] 17:30:56.939366 write(2, "\r", 1
 <unfinished ...>
[pid 30848] 17:30:56.939380 <... ioctl resumed> , [19]) = 0 <0.000018>
[pid 30847] 17:30:56.939394 <... write resumed> ) = 1 <0.000022>
[pid 30848] 17:30:56.939402 recvfrom(5,  <unfinished ...>
[pid 30847] 17:30:56.939415 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.939431 <... recvfrom resumed> "\276\310\201\202\0\1\0\0\0\0\0\0\1c\0\0\1\0\1", 2048, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.160.45")}, [16]) = 19 <0.000019>
[pid 30847] 17:30:56.939448 <... write resumed> ) = 1 <0.000026>
[pid 30848] 17:30:56.939461 poll([{fd=5, events=POLLIN}], 1, 4999 <unfinished ...>
[pid 30847] 17:30:56.939473 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.939487 <... poll resumed> ) = 1 ([{fd=5, revents=POLLIN}]) <0.000015>
[pid 30847] 17:30:56.939502 <... write resumed> ) = 1 <0.000024>
[pid 30848] 17:30:56.939510 recvfrom(5,  <unfinished ...>
[pid 30847] 17:30:56.939526 write(2, "0", 10 <unfinished ...>
[pid 30848] 17:30:56.939538 <... recvfrom resumed> "\256\317\201\202\0\1\0\0\0\0\0\0\1c\0\0\34\0\1", 65536, 0, {sa_family=AF_INET, sin_port=htons(53), sin_addr=inet_addr("164.54.160.45")}, [16]) = 19 <0.000017>
[pid 30847] 17:30:56.939565 <... write resumed> ) = 1 <0.000034>
[pid 30848] 17:30:56.939579 close(4 <unfinished ...>
[pid 30847] 17:30:56.939594 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.939609 <... close resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.939622 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.939629 close(5 <unfinished ...>
[pid 30847] 17:30:56.939644 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.939658 <... close resumed> ) = 0 <0.000020>
[pid 30847] 17:30:56.939669 <... write resumed> ) = 1 <0.000020>
[pid 30848] 17:30:56.939683 madvise(0x7f9bdcd58000, 8368128, MADV_DONTNEED <unfinished ...>
[pid 30847] 17:30:56.939693 write(2, " ", 1  <unfinished ...>
[pid 30848] 17:30:56.939708 <... madvise resumed> ) = 0 <0.000016>
[pid 30847] 17:30:56.939720 <... write resumed> ) = 1 <0.000021>
[pid 30848] 17:30:56.939728 exit(0)     = ?
[pid 30847] 17:30:56.939741 write(2, " ", 1 ) = 1 <0.000016>
[pid 30848] 17:30:56.939769 +++ exited with 0 +++
17:30:56.939780 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.939806 write(2, "0", 10)        = 1 <0.000010>
17:30:56.939835 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.939863 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.939891 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.939918 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.939946 write(2, "0", 10)        = 1 <0.000009>
17:30:56.939974 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940002 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940029 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940057 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940085 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940119 write(2, "0", 10)        = 1 <0.000010>
17:30:56.940146 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940189 write(2, " ", 1 )        = 1 <0.000016>
17:30:56.940235 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940264 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940291 write(2, "0", 10)        = 1 <0.000010>
17:30:56.940319 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940346 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940374 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940401 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940428 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940456 write(2, "0", 10)        = 1 <0.000009>
17:30:56.940483 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940510 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940538 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940571 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940605 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940633 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940660 write(2, "0", 10)        = 1 <0.000009>
17:30:56.940687 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940714 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940742 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940769 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940796 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940823 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.940851 write(2, "0", 10)        = 1 <0.000009>
17:30:56.940878 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.940905 write(2, "-", 1-)        = 1 <0.000010>
17:30:56.940933 write(2, "-", 1-)        = 1 <0.000042>
17:30:56.941006 write(2, ":", 1:)        = 1 <0.000018>
17:30:56.941066 write(2, "-", 1-)        = 1 <0.000011>
17:30:56.941107 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941137 write(2, ":", 1:)        = 1 <0.000009>
17:30:56.941166 write(2, "-", 1-)        = 1 <0.000012>
17:30:56.941206 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941238 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.941265 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941297 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941323 write(2, ":", 1:)        = 1 <0.000009>
17:30:56.941352 write(2, "-", 1-)        = 1 <0.000020>
17:30:56.941398 write(2, "-", 1-)        = 1 <0.000016>
17:30:56.941446 write(2, ":", 1:)        = 1 <0.000024>
17:30:56.941516 write(2, "-", 1-)        = 1 <0.000019>
17:30:56.941572 write(2, "-", 1-)        = 1 <0.000010>
17:30:56.941608 write(2, " ", 1 )        = 1 <0.000012>
17:30:56.941645 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941674 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941701 write(2, ":", 1:)        = 1 <0.000011>
17:30:56.941739 write(2, "-", 1-)        = 1 <0.000013>
17:30:56.941771 write(2, "-", 1-)        = 1 <0.000010>
17:30:56.941799 write(2, ":", 1:)        = 1 <0.000009>
17:30:56.941827 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941854 write(2, "-", 1-)        = 1 <0.000009>
17:30:56.941882 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.941909 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.941937 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.941963 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.941990 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.942017 write(2, "0", 10)        = 1 <0.000009>
17:30:56.942045 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000008>
17:30:56.942078 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000008>
17:30:56.942106 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000007>
17:30:56.942140 write(2, "*", 1*)        = 1 <0.000010>
17:30:56.942168 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.942195 write(2, "Could not resolve host: c\n", 26Could not resolve host: c
) = 26 <0.000009>
17:30:56.942229 write(2, "*", 1*)        = 1 <0.000009>
17:30:56.942256 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.942283 write(2, "Closing connection 0\n", 21Closing connection 0
) = 21 <0.000010>
17:30:56.942315 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000008>
17:30:56.942344 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000008>
17:30:56.942372 write(2, "c", 1c)        = 1 <0.000010>
17:30:56.942400 write(2, "u", 1u)        = 1 <0.000009>
17:30:56.942427 write(2, "r", 1r)        = 1 <0.000009>
17:30:56.942454 write(2, "l", 1l)        = 1 <0.000010>
17:30:56.942481 write(2, ":", 1:)        = 1 <0.000009>
17:30:56.942508 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.942536 write(2, "(", 1()        = 1 <0.000009>
17:30:56.942568 write(2, "6", 16)        = 1 <0.000010>
17:30:56.942599 write(2, ")", 1))        = 1 <0.000009>
17:30:56.942627 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.942654 write(2, "C", 1C)        = 1 <0.000009>
17:30:56.942681 write(2, "o", 1o)        = 1 <0.000009>
17:30:56.942708 write(2, "u", 1u)        = 1 <0.000009>
17:30:56.942735 write(2, "l", 1l)        = 1 <0.000009>
17:30:56.942762 write(2, "d", 1d)        = 1 <0.000009>
17:30:56.942788 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.942815 write(2, "n", 1n)        = 1 <0.000009>
17:30:56.942844 write(2, "o", 1o)        = 1 <0.000009>
17:30:56.942871 write(2, "t", 1t)        = 1 <0.000009>
17:30:56.942898 write(2, " ", 1 )        = 1 <0.000020>
17:30:56.942939 write(2, "r", 1r)        = 1 <0.000009>
17:30:56.942968 write(2, "e", 1e)        = 1 <0.000009>
17:30:56.942995 write(2, "s", 1s)        = 1 <0.000019>
17:30:56.943033 write(2, "o", 1o)        = 1 <0.000010>
17:30:56.943061 write(2, "l", 1l)        = 1 <0.000010>
17:30:56.943090 write(2, "v", 1v)        = 1 <0.000010>
17:30:56.943120 write(2, "e", 1e)        = 1 <0.000009>
17:30:56.943148 write(2, " ", 1 )        = 1 <0.000010>
17:30:56.943176 write(2, "h", 1h)        = 1 <0.000010>
17:30:56.943204 write(2, "o", 1o)        = 1 <0.000010>
17:30:56.943232 write(2, "s", 1s)        = 1 <0.000014>
17:30:56.943264 write(2, "t", 1t)        = 1 <0.000009>
17:30:56.943294 write(2, ":", 1:)        = 1 <0.000010>
17:30:56.943321 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.943349 write(2, "c", 1c)        = 1 <0.000009>
17:30:56.943377 write(2, "\n", 1
)       = 1 <0.000009>
17:30:56.943405 close(3)                = 0 <0.000010>
17:30:56.943446 ioctl(1, TCGETS, 0x7ffd7d378200) = -1 ENOTTY (Inappropriate ioctl for device) <0.000008>
17:30:56.943495 ioctl(0, TIOCGWINSZ, {ws_row=44, ws_col=154, ws_xpixel=0, ws_ypixel=0}) = 0 <0.000014>
17:30:56.943538 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000008>
17:30:56.943572 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:56.943605 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000008>
17:30:56.943632 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000008>
17:30:56.943684 socket(AF_INET, SOCK_STREAM, IPPROTO_IP) = 3 <0.000013>
17:30:56.943720 write(2, "*", 1*)        = 1 <0.000013>
17:30:56.943754 write(2, " ", 1 )        = 1 <0.000011>
17:30:56.943783 write(2, "  Trying 164.54.160.71...\n", 26  Trying 164.54.160.71...
) = 26 <0.000011>
17:30:56.943814 setsockopt(3, SOL_TCP, TCP_NODELAY, [1], 4) = 0 <0.000009>
17:30:56.943844 write(2, "*", 1*)        = 1 <0.000010>
17:30:56.943873 write(2, " ", 1 )        = 1 <0.000009>
17:30:56.943902 write(2, "TCP_NODELAY set\n", 16TCP_NODELAY set
) = 16 <0.000009>
17:30:56.943929 setsockopt(3, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0 <0.000008>
17:30:56.943958 setsockopt(3, SOL_TCP, TCP_KEEPIDLE, [60], 4) = 0 <0.000008>
17:30:56.943984 setsockopt(3, SOL_TCP, TCP_KEEPINTVL, [60], 4) = 0 <0.000008>
17:30:56.944012 fcntl(3, F_GETFL)       = 0x2 (flags O_RDWR) <0.000009>
17:30:56.944039 fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0 <0.000008>
17:30:56.944065 connect(3, {sa_family=AF_INET, sin_port=htons(22), sin_addr=inet_addr("164.54.160.71")}, 16) = -1 EINPROGRESS (Operation now in progress) <0.000019>
17:30:56.944110 poll([{fd=3, events=POLLOUT|POLLWRNORM}], 1, 0) = 0 (Timeout) <0.000009>
17:30:56.944139 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000008>
17:30:56.944167 poll([{fd=3, events=POLLOUT}], 1, 200) = 1 ([{fd=3, revents=POLLOUT}]) <0.000009>
17:30:56.944197 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000008>
17:30:56.944225 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000008>
17:30:56.944251 poll([{fd=3, events=POLLOUT|POLLWRNORM}], 1, 0) = 1 ([{fd=3, revents=POLLOUT|POLLWRNORM}]) <0.000008>
17:30:56.944280 getsockopt(3, SOL_SOCKET, SO_ERROR, [0], [4]) = 0 <0.000009>
17:30:56.944309 getpeername(3, {sa_family=AF_INET, sin_port=htons(22), sin_addr=inet_addr("164.54.160.71")}, [16]) = 0 <0.000008>
17:30:56.944337 getsockname(3, {sa_family=AF_INET, sin_port=htons(41248), sin_addr=inet_addr("164.54.160.82")}, [16]) = 0 <0.000008>
17:30:56.944369 write(2, "*", 1*)        = 1 <0.000019>
17:30:56.944419 write(2, " ", 1 )        = 1 <0.000011>
17:30:56.944461 write(2, "Connected to 164.54.160.71 (164.54.160.71) port 22 (#1)\n", 56Connected to 164.54.160.71 (164.54.160.71) port 22 (#1)
) = 56 <0.000011>
17:30:56.944500 brk(NULL)               = 0x55c95e062000 <0.000009>
17:30:56.944531 brk(0x55c95e08f000)     = 0x55c95e08f000 <0.000010>
17:30:56.944590 fcntl(3, F_GETFL)       = 0x802 (flags O_RDWR|O_NONBLOCK) <0.000009>
17:30:56.944630 sendto(3, "SSH-2.0-libssh2_1.8.0\r\n", 23, MSG_NOSIGNAL, NULL, 0) = 23 <0.000015>
17:30:56.944671 recvfrom(3, 0x7ffd7d376d87, 1, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:56.944708 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:56.944741 poll([{fd=3, events=POLLIN}], 1, 200) = 1 ([{fd=3, revents=POLLIN}]) <0.010200>
17:30:56.954989 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000012>
17:30:56.955043 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000011>
17:30:56.955085 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000012>
17:30:56.955130 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955165 recvfrom(3, "H", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955199 recvfrom(3, "-", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955232 recvfrom(3, "2", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000013>
17:30:56.955267 recvfrom(3, ".", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955301 recvfrom(3, "0", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955334 recvfrom(3, "-", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955367 recvfrom(3, "O", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955400 recvfrom(3, "p", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955433 recvfrom(3, "e", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000010>
17:30:56.955466 recvfrom(3, "n", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000034>
17:30:56.955524 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955555 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000011>
17:30:56.955598 recvfrom(3, "H", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955630 recvfrom(3, "_", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955660 recvfrom(3, "7", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955690 recvfrom(3, ".", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955720 recvfrom(3, "5", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:30:56.955751 recvfrom(3, "\r", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955781 recvfrom(3, "\n", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:30:56.955827 futex(0x7f9bddd2e988, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000013>
17:30:56.955881 open("/dev/random", O_RDONLY) = 4 <0.000014>
17:30:56.955920 select(5, [4], NULL, NULL, NULL) = 1 (in [4]) <0.000010>
17:30:56.955961 close(4)                = 0 <0.000009>
17:30:56.955991 open("/dev/urandom", O_RDONLY) = 4 <0.000010>
17:30:56.956023 fstat(4, {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 9), ...}) = 0 <0.000009>
17:30:56.956055 read(4, ".)\2\214\32\0334l\235\2550\200B\225\204d\271\26z\313%jM#?jZ\327\242v\5\214", 32) = 32 <0.000010>
17:30:56.956102 futex(0x7f9bddd2e958, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:30:56.956147 sendto(3, "\0\0\2\344\n\24\370d4g\337\352\177\32\301\264\353\212\7*\33g\0\0\0~diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1\0\0\0\17ssh-rsa,ssh-dss\0\0\0\222aes128-ctr,aes192-ctr,aes256-ctr,aes256-cbc,[email protected],aes192-cb"..., 744, MSG_NOSIGNAL, NULL, 0) = 744 <0.000016>
17:30:56.956192 recvfrom(3, "\0\0\0044\6\24!\274?\330\226\303\316\277\340\354\247\242N\230\271,\0\0\1\2curve25519-sha256,[email protected],ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 1080 <0.000010>
17:30:56.956235 sendto(3, "\0\0\0\24\6\"\0\0\4\0\0\0\6\0\0\0\10\0\244\n8\0\325\0", 24, MSG_NOSIGNAL, NULL, 0) = 24 <0.000012>
17:30:56.956270 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:30:56.956303 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:56.956336 poll([{fd=3, events=POLLIN}], 1, 188) = 1 ([{fd=3, revents=POLLIN}]) <0.020487>
17:30:56.976903 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000015>
17:30:56.976984 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000014>
17:30:56.977045 recvfrom(3, "\0\0\1\24\10\37\0\0\1\1\0\332W\261\211v\351\305\\\352\303\277\377pA\232\25P%\216\2475\224\0\275O\254\217B\3\267>\v\305Mb\300\242\331\252\233T?\254\240)\5\24\352Bm\346\376\370\227\313\205\202CQ\35\316QpB\fy\235\210\215\317\334E\2\377I\266o4\347\\\0\351\212U@\212y\37\365\317\352|(\217\216fd\"jj\220\276#}.@\302\7\265\255\f\256\337\332IF\346:\3525\32\t\357F%\25\376\324\t\206\224$\34\320~,\267r{9\270\261\271F}r\337\271\10\330\26\237]\263\315Zk\353\3414LXZ\210%\10\267`@.\206\353\233UH\247\271\2065\354\374\334\2\377b\262\234S\204qB\374Y\212\334f\366\"\366\351\367;\337\2\263\327\225\300\337#\320\16Z:wH\363\341\325\260oF\324V\214\343\364\314W\346}L6\337\\\22\200\6 i\214r|\305\365"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 280 <0.000020>
17:30:56.982066 sendto(3, "\0\0\1\f\6 \0\0\1\0*n\222\260\330\0\20\264\10\331*\321s\214\364\357_\7\376\207?\326\232'M\310\304nv\301\200\370E>0\331\346\301\326\272\200\353\347\370\260\220\f\36\334\257\253\20M0Ta{\351\367J6\n:\242\205(3\366\232('\330\23!\344\304#Pe\26\\\230m\216\327\373\247i\261\30e\207\320l\356\302\321!\212\25[-S\201J\362\211\6<\211\35\333?\223y\235\356n\215\336(\235\360\334\202\211)}\221\373\367\334\314t\335R\"Id\317<9\374\24\345\2122E\345\310Q\321\372\315\376\315\270\236\377\313\244\270r(\301\342\333\3179\332 \30\250\377\320\315\312\360\0316J\261\314\3368\324n\314\35\255C\27\242\202z\2145\26\263\fL\371\214\341*\204\341R\t\0312%\225\323\240\35\272\376\217\2<C\21\354\250u\263{\307\300\207\225\334\230{\302\313\211Z\325F\264!\353\2261"..., 272, MSG_NOSIGNAL, NULL, 0) = 272 <0.000068>
17:30:56.982235 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000011>
17:30:56.982294 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000017>
17:30:56.982348 poll([{fd=3, events=POLLIN}], 1, 162) = 1 ([{fd=3, revents=POLLIN}]) <0.023083>
17:30:57.005488 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000012>
17:30:57.005541 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000014>
17:30:57.005592 recvfrom(3, "\0\0\3<\7!\0\0\1\27\0\0\0\7ssh-rsa\0\0\0\3\1\0\1\0\0\1\1\0\225\226qkoT\263\216(\336Y\31]\323\17\214&\226\345\256\301|\274K\255\261\31\311o\23\214\34\254\374v\32\217\376\241\243`\353F\334\240\213\300\321\374\241\322\322\265\336h\257\220\272\361z\233t\24\361\\mBi:\322wFx\201j7p\334\267\254\250\311\342\231\223T\373\205\\A\373\210'\335\364cC|\373T9\220\336&\26\300\\\200\374\231E\355\234f\260\3421\367\275\345\222\230\261\220\223\373\0335\30\5}\\\255\2\250F\306\1770V\0fV\336U\32f\2207\327\367\346h\244~l\221f\334\20_\6\177\261\273\315a\210\206U\267t\232|\355k\0\35\277\320\231\206\327I\6\207\343\327*\245w\17\362|\336\346\377\300$(z\200:T_l\243\10]O\225^B\223\302\17\255\257/\332`\16\372"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 848 <0.000015>
17:30:57.012229 sendto(3, "\0\0\0\f\n\25\277o\204\1\277\270w\206Y\365", 16, MSG_NOSIGNAL, NULL, 0) = 16 <0.000020>
17:30:57.012350 sendto(3, "\351\256\r\231\3214\355\245*\206[8\367Z1s\n\234\2011\t>\17\5\222x&\261\365i\256`\236\267C\356\206\262z\4\372\306\267\355\245\356\325\276\237\20R\25\266\351\202\332\205[\24,Z\274\265\235", 64, MSG_NOSIGNAL, NULL, 0) = 64 <0.000015>
17:30:57.012398 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000012>
17:30:57.012441 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000012>
17:30:57.012520 poll([{fd=3, events=POLLIN}], 1, 132) = 1 ([{fd=3, revents=POLLIN}]) <0.000020>
17:30:57.012593 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000011>
17:30:57.012636 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000011>
17:30:57.012675 recvfrom(3, "K\313\211Kj\236\200\200\2719\266P\313zw\232\344.\2514\277J\5/\320\250\6=\240E\232)\255\35\277Z\363\363\214\"Ks\355\354P`\241t\365\370-\320\t\5d:S9)\t\10\233\353\323", 16384, MSG_NOSIGNAL, NULL, NULL) = 64 <0.000023>
17:30:57.012744 write(2, "*", 1*)        = 1 <0.000016>
17:30:57.012783 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.012817 write(2, "SSH MD5 fingerprint: 8de67ccf8c2f9b3b584c703b9fb749f6\n", 54SSH MD5 fingerprint: 8de67ccf8c2f9b3b584c703b9fb749f6
) = 54 <0.000012>
17:30:57.012865 sendto(3, "\341\212\10\355F\2768Y,#\333z\n\214\201R?\346\10\0F\357\"\353\342\302b\274\6?\270\210\326h\216\204\322\274\215N-\320\213\21\305KI\10\205\223\2\351U\273\223E+7'\376\vY\257\345\267\27v\17\344g\10\271`\17\266^\25\360ev\360\343m\304o5\314\224\212\336\\\22\334\351\363\332", 96, MSG_NOSIGNAL, NULL, 0) = 96 <0.000016>
17:30:57.012914 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:30:57.012952 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.012986 poll([{fd=3, events=POLLIN}], 1, 132) = 1 ([{fd=3, revents=POLLIN}]) <0.000460>
17:30:57.013473 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000009>
17:30:57.013505 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.013539 recvfrom(3, "\361\22\227*(<\267\310\302$\253\310F\310\332v\24\236\214\302\30P\26\3226\2\277a?C\261\300\31a<\310s\10\234i\37\264\n\322\254\237\335q\n\252\301(\33\220\257\347\332\311\224\207\7\275#\355\1^9\355\223\302\327\f\256\330&\271\231{,\10}|\312\267\326\350vD.\17\345\327D\371%H\310\371\321g~\237\364-\\}\264\217\344\243\330\254v9\343\272\320\17B\30\274\2107b\253\2465~(\266\231\10\276\316r$c]8L\234\216@\234\rMD:2K0\tc;Qj\22E\242S\7F\316\210\256\255F\244sjU.\211v\277\356\270\326a~\37\217Ij\204\366\346\0020\340\v\202r\267-S\33\23\362hy`\352\323\256\365|\217\304\4d6L/\370\341\336o?\210\364\323\220\35\375\273G\267;\213&J\367\364\305\214\347\300\35\230\374\213\213\226wHx\307\333\277\243\256\343\177\377<"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 1760 <0.000011>
17:30:57.013615 write(2, "*", 1*)        = 1 <0.000014>
17:30:57.013653 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.013687 write(2, "SSH authentication methods available: publickey,password,keyboard-interactive\n", 78SSH authentication methods available: publickey,password,keyboard-interactive
) = 78 <0.000012>
17:30:57.013725 access("/home/epics/.ssh/id_rsa", R_OK) = 0 <0.000015>
17:30:57.013766 write(2, "*", 1*)        = 1 <0.000012>
17:30:57.013801 write(2, " ", 1 )        = 1 <0.000040>
17:30:57.013866 write(2, "Using SSH private key file '/home/epics/.ssh/id_rsa'\n", 53Using SSH private key file '/home/epics/.ssh/id_rsa'
) = 53 <0.000012>
17:30:57.013906 open("/home/epics/.ssh/id_rsa", O_RDONLY) = 5 <0.000014>
17:30:57.013950 fstat(5, {st_mode=S_IFREG|0600, st_size=1675, ...}) = 0 <0.000010>
17:30:57.013986 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f9bde697000 <0.000012>
17:30:57.014022 lseek(5, 0, SEEK_SET)   = 0 <0.000009>
17:30:57.014060 read(5, "-----BEGIN RSA PRIVATE KEY-----\nMIIEogIBAAKCAQEAw2XnqGqU7M6nYLFgVH5GsBWbNEVsp0cIY2Z5lZwWR+6u8LEw\nG6cLN7AxCq3Ww93fUKk1RSbU9t4yPwfjzVU+CbEN0Q9XLkDYdjapzMFeNThHak/P\nTFBgJOlSbuw/CIToQqZyD/fVngPgRixuQKyubCw5zli9LpzEtWZIBwE11HYAIOM5\ngUau8MEbkXAoPxcGoN0rbdQPk8+qa"..., 4096) = 1675 <0.000014>
17:30:57.014146 close(5)                = 0 <0.000011>
17:30:57.014179 munmap(0x7f9bde697000, 4096) = 0 <0.000014>
17:30:57.014232 sendto(3, "\325p\254:\5]FWd[%\0O\360\345\253\22\221I@Z\247P\230\201r\16=\373[\232\221\v#@DF\374\362\370\277U>:\367\3259\347\225i\\d=\227\360\31o\363\16\233\350*\215!\251\0\5\225\315\215}|\303\370d\3\6\337\227\231\302\357G\254~\340\313P^%#\2210\0164\313\225%Q\300D\26\37\f\264\214\25\25\33L%U\375\336AhM`36\277\330\20\350\344\306\304f\323\367\3310\220\275J\311\346\247t\271u\272\6\207P4&o\234\222\250\336\1\t,UkJy\206\0\3070\346WI\350\r\265\217\306\253R\3578\264\234\307\342\201o\322,\212w\21'c\0i\242\26J\325,\212\341v\203\365c\377\336Q\207\375\v\v\247\325\217\204\223\210\24\337;\337\16\7H\275\240Y\2\212\325;`\201$;`5<S\22\216\361\215\24k{p\333A\242\311\370Wl\273'}w\260"..., 400, MSG_NOSIGNAL, NULL, 0) = 400 <0.000016>
17:30:57.014275 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:30:57.014309 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.014343 poll([{fd=3, events=POLLIN}], 1, 130) = 1 ([{fd=3, revents=POLLIN}]) <0.000293>
17:30:57.014673 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000009>
17:30:57.014708 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.014743 recvfrom(3, "\272\351\276\366\2664\347\360\202h\24m\362\367\216\305\367\7\274^\326\25\234\4\277Wf@\337\201nf\7\377\260\356\35\3739\230ds\35i2\275\326\335Z\303e\335$*`\22a>\213J&.\336'\317\3142\243\214\225%\306b\276Ib\313 \215\224\241\205u\343\337\245\313L\216\26y\242\312\353\r\264", 16384, MSG_NOSIGNAL, NULL, NULL) = 96 <0.000010>
17:30:57.014789 write(2, "*", 1*)        = 1 <0.000015>
17:30:57.014826 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.014860 write(2, "SSH public key authentication failed: Username/PublicKey combination invalid\n", 77SSH public key authentication failed: Username/PublicKey combination invalid
) = 77 <0.000010>
17:30:57.014903 sendto(3, "7\312\212\346\267\314\250\2658M\340r\2443,]\251\354\320\276\370\213=\211in<\355/s\254\323\347\370J\301c\3171\235Q\25\204\243\347\302\315\335\367\272\\\232T\7\357O>\305\261\22198g\314$\376\354[\312k\356\360\305\327\302\344Ue+\26Fv\377\v\330\325\347\273\34\265j\r\360A\257}\373\270\210R@W\0043\244?@}Y\316\231Q", 112, MSG_NOSIGNAL, NULL, 0) = 112 <0.000015>
17:30:57.014944 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:57.014977 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.015011 poll([{fd=3, events=POLLIN}], 1, 130) = 1 ([{fd=3, revents=POLLIN}]) <0.000164>
17:30:57.015201 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000010>
17:30:57.015252 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000011>
17:30:57.015299 recvfrom(3, "N\205d7\302`\343\t\252r1\221\225\253\201\210\347\303\334\210\361\3323\346\veO\222\35\240\ts7\231r9\273\276?a\233v\277t\37{(\37", 16384, MSG_NOSIGNAL, NULL, NULL) = 48 <0.000010>
17:30:57.015341 write(2, "*", 1*)        = 1 <0.000012>
17:30:57.015377 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.015411 write(2, "Initialized password authentication\n", 36Initialized password authentication
) = 36 <0.000011>
17:30:57.015445 write(2, "*", 1*)        = 1 <0.000011>
17:30:57.015479 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.015513 write(2, "Authentication complete\n", 24Authentication complete
) = 24 <0.000011>
17:30:57.015548 write(2, "*", 1*)        = 1 <0.000021>
17:30:57.015591 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.015626 write(2, "SSH CONNECT phase done\n", 23SSH CONNECT phase done
) = 23 <0.000011>
17:30:57.015676 sendto(3, "\275\1\250\32\305\4\242\207\20)\250\353l$\32_.sh0(\361\315]\257\250\4\233m\241\367\177R'B@\341\351\336\211\305\3564\334\373R\216\265\216\227r\251\326\r%\213r\267\362\262\246N\202{\332\361Y<\204\1\303\206\5\27\357\377@\340\24<", 80, MSG_NOSIGNAL, NULL, 0) = 80 <0.000015>
17:30:57.015716 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:57.015751 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.015785 poll([{fd=3, events=POLLIN}], 1, 129) = 1 ([{fd=3, revents=POLLIN}]) <0.000015>
17:30:57.015826 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000009>
17:30:57.015859 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000011>
17:30:57.015895 recvfrom(3, "\231.\206\4i\353<\346g1[\342>\226\240\331\232M\220B\16v%^\334\277e\3305\25\247\326n\25\324\264XQ%\21\376N\t6=\325~\7W\315\266\231\33C\2102\205\272\355\223\247\206\224\305V\344}\340\2359\335umSb{8m\1\0003\17\365\213;;\277\223l\362]\242v\237R\233\225\220t\231\177\ruiCi\330Y\332s_\235.!\313\252\345T\v\361??{\252|\23\f\257XI\365\252\206f\326\374\211$P\316\326\27\10\203\331\337\371\6\20\274hv\270m\213\346% d\331\303\332\217{\\o\366\233\277\277\306\230\225\262\272\2141\313\253K\372\"b\204\211\254\2136)\377\262\334\271Y6\36\357\230\21\331\17\303F7\364\30R 5\305h\371\206\272~$`Y((A\354\321\322\353\224d \242\30\210\25\356\6\266\354\7\274\350\341\254\316\356\363D\230~s\tLY\235\315J(k"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 960 <0.000010>
17:30:57.015948 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:57.015983 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.016016 poll([{fd=3, events=POLLIN}], 1, 129) = 1 ([{fd=3, revents=POLLIN}]) <0.039706>
17:30:57.055800 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000039>
17:30:57.055882 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000011>
17:30:57.055924 recvfrom(3, "\5\271\202i\331\377{\327lh\327\352\264|\311\337VN)\22f\307\337A\207I'\215\247\374\201h\347'\334\246\234\3505\302\f[U\332n\37\212\204\31V\311\221Gv5\206i\231\261\264\10\0271m", 16384, MSG_NOSIGNAL, NULL, NULL) = 64 <0.000027>
17:30:57.056004 sendto(3, "\364\267q\273\356\23\233\342P\202q\213\275\317\362\210i\233\340/`\231\325\255\300n=\222I\315\220{\23\351\3323\0\34tx\245$\240\304\205C\20_+\264\327\301\222;[\225\7\351\324\365m\206\361\376\332\311**G\331\351\332\256}\315s\177.[\32\200\324\240o\33J\304\324\214\0\350R\30S@\322\275_\301\0027qt\316\216|O_\200\314\5\331", 112, MSG_NOSIGNAL, NULL, 0) = 112 <0.000016>
17:30:57.056050 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:57.056085 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.056131 poll([{fd=3, events=POLLIN}], 1, 88) = 1 ([{fd=3, revents=POLLIN}]) <0.000737>
17:30:57.056906 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000010>
17:30:57.056944 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.056977 recvfrom(3, "8W\210\276\325\303\35\302_\273\2\243a.u\177\262\344\37RZ\276\350\24M\265\301l\221\256x\342\324^t\6\327\274^\311\265\210\344u\373\334\246&y\374\362\325\366\345\317\313\321?dN\375U\276e\t/\177\264P,4\312[t\242'Z\257)\215]\321yK\322y\214\276\341\337stX\250J\234\321\0\4?\206\1\317t\366\3155\226@\200\5H", 16384, MSG_NOSIGNAL, NULL, NULL) = 112 <0.000010>
17:30:57.057031 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:57.057073 sendto(3, "D\25\34B\351\310\341\373\334\265>\321-\17\270\26y\30\320E\\lW\32\224G\366\256\273dq\327\f>\365\17\10\rI\17\371\253\231?\22\177z\266\307\303\r{\356\247\354M\213\221\336#\20\244\311\355", 64, MSG_NOSIGNAL, NULL, 0) = 64 <0.000014>
17:30:57.057112 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:30:57.057144 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.057176 poll([{fd=3, events=POLLIN}], 1, 87) = 1 ([{fd=3, revents=POLLIN}]) <0.008109>
17:30:57.065349 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000018>
17:30:57.065425 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000015>
17:30:57.065482 recvfrom(3, "h\303\342\343\257Z\231Sy\312%\232\20P=\313\204}\213\354\v7\27\321mg'r\216\366\21\233C\332\256\264\352\267\214\374\304\32\347\325{\22tQk\6*;\217\355\223u\240\222\323?\346\276s\262\0\344>C\320}K\fp\341Y\v\233\272\r{\305\3131\247\321\353S\0\fC\361\236NQ_\353\277\31\337\346\337A\367X\322\277\277\0\225\32\5\351\237{\265F\361\214n7ntGwXf\4\370\177\6s\4\253<8P\31\311\265\3579?H\253\322\253&\307bI\373\351k*\267\207\217\346\216_\334\241g\346vbd\242\220G\235\t\255q,\305\227\244*\230\313\222'to\23\235\5\21\257\353\263\202Z\253LO\0e4\361\361\342@4\270vIi;\10<\320\215\250\220<\233\37\355\302\312\17]\241\323\224#\230\37v\247\277\241\346\27b\221W4\320\226]j\352U\2209\272\23\344\241\0313\203W"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 288 <0.000028>
17:30:57.065591 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:30:57.065628 recvfrom(3, 0x55c95e061400, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:30:57.065670 sendto(3, "\24\324\330\251\266_&\20\34Q{\t\363\"L-C\247\265\364\346\325\0\231h\255\37\333\2639\3414\f\320\235\320\367\4c\17\324Q\33=\326\"\321\32", 48, MSG_NOSIGNAL, NULL, 0) = 48 <0.000014>
17:30:57.065716 sendto(3, "\220.VQ\367\344j\3724\376SU\361\346c\215=\334\322\224k\34wc\316\243W`Z|\6\5\4\332\n\315t\221\vpj=\340m\366\207;\260", 48, MSG_NOSIGNAL, NULL, 0) = 48 <0.000012>
17:30:57.065756 write(2, "*", 1*)        = 1 <0.000017>
17:30:57.065797 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.065833 write(2, "Failed to recv file\n", 20Failed to recv file
) = 20 <0.000012>
17:30:57.065874 write(2, "\r", 1
)       = 1 <0.000012>
17:30:57.065909 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.065943 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.065977 write(2, "0", 10)        = 1 <0.000011>
17:30:57.066010 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066044 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066079 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066113 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066147 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066181 write(2, "0", 10)        = 1 <0.000014>
17:30:57.066218 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.066253 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066288 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066322 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066356 write(2, "0", 10)        = 1 <0.000011>
17:30:57.066390 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066424 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066457 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066491 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066525 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066559 write(2, "0", 10)        = 1 <0.000013>
17:30:57.066610 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066645 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066678 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066712 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066745 write(2, "0", 10)        = 1 <0.000011>
17:30:57.066779 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066813 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066847 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066880 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066914 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.066947 write(2, "0", 10)        = 1 <0.000012>
17:30:57.066981 write(2, " ", 1 )        = 1 <0.000014>
17:30:57.067017 write(2, " ", 1 )        = 1 <0.000014>
17:30:57.067053 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067087 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067121 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067154 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067187 write(2, "0", 10)        = 1 <0.000011>
17:30:57.067221 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067255 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067288 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067322 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067356 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067389 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067423 write(2, "0", 10)        = 1 <0.000011>
17:30:57.067457 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067491 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067524 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067558 write(2, ":", 1:)        = 1 <0.000014>
17:30:57.067600 write(2, "-", 1-)        = 1 <0.000013>
17:30:57.067636 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067671 write(2, ":", 1:)        = 1 <0.000011>
17:30:57.067705 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067741 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067776 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.067810 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067843 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067877 write(2, ":", 1:)        = 1 <0.000011>
17:30:57.067910 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067944 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.067977 write(2, ":", 1:)        = 1 <0.000011>
17:30:57.068012 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.068045 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.068079 write(2, " ", 1 )        = 1 <0.000037>
17:30:57.068145 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.068184 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.068217 write(2, ":", 1:)        = 1 <0.000014>
17:30:57.068252 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.068283 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.068315 write(2, ":", 1:)        = 1 <0.000010>
17:30:57.068346 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.068378 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.068410 write(2, " ", 1 )        = 1 <0.000010>
17:30:57.068467 write(2, " ", 1 )        = 1 <0.000014>
17:30:57.068517 write(2, " ", 1 )        = 1 <0.000010>
17:30:57.068550 write(2, " ", 1 )        = 1 <0.000018>
17:30:57.068592 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.068626 write(2, "0", 10)        = 1 <0.000012>
17:30:57.068659 write(2, "\n", 1
)       = 1 <0.000012>
17:30:57.068695 write(2, "\r", 1
)       = 1 <0.000011>
17:30:57.068727 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.068759 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.068804 write(2, "0", 10)        = 1 <0.000012>
17:30:57.068840 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.068876 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.068913 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.068949 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.068985 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069021 write(2, "0", 10)        = 1 <0.000012>
17:30:57.069060 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.069096 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069132 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069169 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069205 write(2, "0", 10)        = 1 <0.000013>
17:30:57.069243 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069280 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069316 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069354 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069391 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069434 write(2, "0", 10)        = 1 <0.000012>
17:30:57.069470 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.069506 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069542 write(2, " ", 1 )        = 1 <0.000016>
17:30:57.069587 write(2, " ", 1 )        = 1 <0.000014>
17:30:57.069625 write(2, "0", 10)        = 1 <0.000012>
17:30:57.069662 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069699 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069736 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069772 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069808 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069844 write(2, "0", 10)        = 1 <0.000013>
17:30:57.069880 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069918 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.069955 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.069991 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070027 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070063 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.070099 write(2, "0", 10)        = 1 <0.000013>
17:30:57.070135 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.070172 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.070208 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070245 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070282 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070318 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070354 write(2, "0", 10)        = 1 <0.000012>
17:30:57.070391 write(2, " ", 1 )        = 1 <0.000012>
17:30:57.070426 write(2, "-", 1-)        = 1 <0.000014>
17:30:57.070473 write(2, "-", 1-)        = 1 <0.000013>
17:30:57.070522 write(2, ":", 1:)        = 1 <0.000012>
17:30:57.070554 write(2, "-", 1-)        = 1 <0.000016>
17:30:57.070609 write(2, "-", 1-)        = 1 <0.000019>
17:30:57.070683 write(2, ":", 1:)        = 1 <0.000016>
17:30:57.070732 write(2, "-", 1-)        = 1 <0.000017>
17:30:57.070789 write(2, "-", 1-)        = 1 <0.000016>
17:30:57.070838 write(2, " ", 1 )        = 1 <0.000019>
17:30:57.070909 write(2, "-", 1-)        = 1 <0.000022>
17:30:57.070982 write(2, "-", 1-)        = 1 <0.000015>
17:30:57.071030 write(2, ":", 1:)        = 1 <0.000012>
17:30:57.071073 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.071120 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.071153 write(2, ":", 1:)        = 1 <0.000011>
17:30:57.071186 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.071217 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.071251 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.071286 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.071319 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.071352 write(2, ":", 1:)        = 1 <0.000010>
17:30:57.071385 write(2, "-", 1-)        = 1 <0.000010>
17:30:57.071417 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.071450 write(2, ":", 1:)        = 1 <0.000011>
17:30:57.071483 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.071516 write(2, "-", 1-)        = 1 <0.000011>
17:30:57.071550 write(2, " ", 1 )        = 1 <0.000017>
17:30:57.071590 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.071625 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.071658 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.071691 write(2, " ", 1 )        = 1 <0.000010>
17:30:57.071724 write(2, "0", 10)        = 1 <0.000010>
17:30:57.071758 write(2, "\n", 1
)       = 1 <0.000011>
17:30:57.071795 write(2, "*", 1*)        = 1 <0.000011>
17:30:57.071842 write(2, " ", 1 )        = 1 <0.000023>
17:30:57.071917 write(2, "Connection #1 to host 164.54.160.71 left intact\n", 48Connection #1 to host 164.54.160.71 left intact
) = 48 <0.000012>
17:30:57.071968 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.072006 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.072043 write(2, "c", 1c)        = 1 <0.000014>
17:30:57.072082 write(2, "u", 1u)        = 1 <0.000015>
17:30:57.072122 write(2, "r", 1r)        = 1 <0.000015>
17:30:57.072160 write(2, "l", 1l)        = 1 <0.000015>
17:30:57.072199 write(2, ":", 1:)        = 1 <0.000013>
17:30:57.072235 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.072268 write(2, "(", 1()        = 1 <0.000010>
17:30:57.072301 write(2, "7", 17)        = 1 <0.000011>
17:30:57.072333 write(2, "8", 18)        = 1 <0.000021>
17:30:57.072377 write(2, ")", 1))        = 1 <0.000011>
17:30:57.072411 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.072445 write(2, "F", 1F)        = 1 <0.000012>
17:30:57.072481 write(2, "a", 1a)        = 1 <0.000011>
17:30:57.072516 write(2, "i", 1i)        = 1 <0.000011>
17:30:57.072550 write(2, "l", 1l)        = 1 <0.000018>
17:30:57.072599 write(2, "e", 1e)        = 1 <0.000011>
17:30:57.072634 write(2, "d", 1d)        = 1 <0.000011>
17:30:57.072669 write(2, " ", 1 )        = 1 <0.000011>
17:30:57.072702 write(2, "t", 1t)        = 1 <0.000016>
17:30:57.072743 write(2, "o", 1o)        = 1 <0.000014>
17:30:57.072782 write(2, " ", 1 )        = 1 <0.000013>
17:30:57.072820 write(2, "r", 1r)        = 1 <0.000015>
17:30:57.072859 write(2, "e", 1e)        = 1 <0.000012>
17:30:57.072896 write(2, "c", 1c)        = 1 <0.000011>
17:30:57.072932 write(2, "v", 1v)        = 1 <0.000012>
17:30:57.072969 write(2, " ", 1 )        = 1 <0.000014>
17:30:57.073008 write(2, "f", 1f)        = 1 <0.000013>
17:30:57.073045 write(2, "i", 1i)        = 1 <0.000012>
17:30:57.073081 write(2, "l", 1l)        = 1 <0.000011>
17:30:57.073118 write(2, "e", 1e)        = 1 <0.000012>
17:30:57.073154 write(2, "\n", 1
)       = 1 <0.000011>
17:30:57.073194 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000010>
17:30:57.073236 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.073273 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000009>
17:30:57.073306 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.073355 sendto(3, "GgM\332B&$\360u\212>\32j\f\327\253\262N\331\355\32\361\201\272\276@N8#a/\31\32\254\262u\371\324\203\305\4\5,\2526.G6O\1W\0102\273\343:\231b\335\271\362dba", 64, MSG_NOSIGNAL, NULL, 0) = 64 <0.000015>
17:30:57.073407 close(3)                = 0 <0.000020>
17:30:57.073452 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.073488 rt_sigaction(SIGPIPE, NULL, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, 8) = 0 <0.000009>
17:30:57.073523 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000009>
17:30:57.073576 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.073620 rt_sigaction(SIGPIPE, {SIG_IGN, [PIPE], SA_RESTORER|SA_RESTART, 0x7f9bde10c6d0}, NULL, 8) = 0 <0.000010>
17:30:57.073668 fstat(4, {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 9), ...}) = 0 <0.000010>
17:30:57.073705 close(4)                = 0 <0.000011>
17:30:57.073904 exit_group(78)          = ?
17:30:57.074225 +++ exited with 78 +++
% time     seconds  usecs/call     calls    errors syscall
 87.15    0.105186        3627        29           poll
  6.27    0.007570          15       506           write
  1.06    0.001274          14        90        61 open
  0.96    0.001155          14        80           mmap
  0.62    0.000751          13        56        14 recvfrom
  0.56    0.000670          11        63           rt_sigaction
  0.46    0.000557          15        38           close
  0.41    0.000496          15        34           mprotect
  0.37    0.000449          14        31           read
  0.32    0.000387          13        29           fstat
  0.29    0.000352          11        31        25 stat
  0.23    0.000279          19        15           sendto
  0.20    0.000237          22        11           munmap
  0.15    0.000177          18        10         1 ioctl
  0.14    0.000167          10        16           futex
  0.13    0.000159         159         1           execve
  0.13    0.000151          22         7           socket
  0.11    0.000132          22         6         3 connect
  0.10    0.000115          23         5           sendmmsg
  0.07    0.000079          10         8           brk
  0.04    0.000045          45         1           clone
  0.03    0.000034          17         2           set_robust_list
  0.03    0.000033           8         4           setsockopt
  0.03    0.000033          33         1           readlink
  0.02    0.000028          14         2         1 access
  0.02    0.000026           9         3           fcntl
  0.01    0.000016          16         1           madvise
  0.01    0.000016          16         1           getuid
  0.01    0.000014          14         1           set_tid_address
  0.01    0.000012          12         1           pipe
  0.01    0.000011          11         1           rt_sigprocmask
  0.01    0.000011          11         1           arch_prctl
  0.01    0.000010          10         1           select
  0.01    0.000009           9         1           lseek
  0.01    0.000009           9         1           getsockopt
  0.01    0.000009           9         1           getrlimit
  0.01    0.000009           9         1           getgid
  0.01    0.000009           9         1           geteuid
  0.01    0.000009           9         1           getegid
  0.01    0.000008           8         1           getsockname
  0.01    0.000008           8         1           getpeername
100.00    0.120702                  1094       105 total
17:31:06.762665 execve("../../../../bin/linux-x86_64/curl_gen", ["../../../../bin/linux-x86_64/curl_gen"], [/* 85 vars */]) = 0 <0.000171>
17:31:06.763236 brk(NULL)               = 0x813000 <0.000012>
17:31:06.763308 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c9a7000 <0.000014>
17:31:06.763378 access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.763460 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/tls/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.763530 stat("/home/epics/devel/motor-7-0/lib/linux-x86_64/tls/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000023>
17:31:06.763603 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/tls/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.763656 stat("/home/epics/devel/motor-7-0/lib/linux-x86_64/tls", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.763717 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.763773 stat("/home/epics/devel/motor-7-0/lib/linux-x86_64/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.763823 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.763871 stat("/home/epics/devel/motor-7-0/lib/linux-x86_64", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0 <0.000013>
17:31:06.763940 open("/usr/local/lib/tls/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764006 stat("/usr/local/lib/tls/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764055 open("/usr/local/lib/tls/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764105 stat("/usr/local/lib/tls", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.764153 open("/usr/local/lib/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764203 stat("/usr/local/lib/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764262 open("/usr/local/lib/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764318 stat("/usr/local/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 <0.000014>
17:31:06.764371 open("/usr/local/lib64/tls/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.764422 stat("/usr/local/lib64/tls/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764472 open("/usr/local/lib64/tls/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764522 stat("/usr/local/lib64/tls", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.764575 open("/usr/local/lib64/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.764652 stat("/usr/local/lib64/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000021>
17:31:06.764746 open("/usr/local/lib64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000027>
17:31:06.764864 stat("/usr/local/lib64", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 <0.000019>
17:31:06.764960 open("/usr/local64/lib/tls/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.765019 stat("/usr/local64/lib/tls/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.765071 open("/usr/local64/lib/tls/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.765132 stat("/usr/local64/lib/tls", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.765183 open("/usr/local64/lib/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.765243 stat("/usr/local64/lib/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.765293 open("/usr/local64/lib/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.765343 stat("/usr/local64/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0 <0.000014>
17:31:06.765394 open("/usr/local/epics/extensions/lib/linux-x86/tls/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.765444 stat("/usr/local/epics/extensions/lib/linux-x86/tls/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.765493 open("/usr/local/epics/extensions/lib/linux-x86/tls/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.765540 stat("/usr/local/epics/extensions/lib/linux-x86/tls", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000020>
17:31:06.765603 open("/usr/local/epics/extensions/lib/linux-x86/x86_64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.765654 stat("/usr/local/epics/extensions/lib/linux-x86/x86_64", 0x7ffec2282460) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.765703 open("/usr/local/epics/extensions/lib/linux-x86/libcurl.so.4", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.765751 stat("/usr/local/epics/extensions/lib/linux-x86", {st_mode=S_IFDIR|0775, st_size=4096, ...}) = 0 <0.000013>
17:31:06.765803 open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3 <0.000015>
17:31:06.765853 fstat(3, {st_mode=S_IFREG|0644, st_size=118229, ...}) = 0 <0.000013>
17:31:06.765900 mmap(NULL, 118229, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7f0b5c98a000 <0.000014>
17:31:06.765949 close(3)                = 0 <0.000010>
17:31:06.766000 open("/lib64/libcurl.so.4", O_RDONLY|O_CLOEXEC) = 3 <0.000022>
17:31:06.766055 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\243\0\0\0\0\0\0@\0\0\0\0\0\0\0\330\254\6\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0TS\6\0\0\0\0\0TS\6\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\350b\6\0\0\0\0\0\350b&\0\0\0\0\0\350b&\0\0\0\0\0\250(\0\0\0\0\0\0\0.\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0`|\6\0\0\0\0\0`|&\0\0\0\0\0`|&\0\0\0\0\0\360\2\0\0\0\0\0\0\360\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000014>
17:31:06.766114 fstat(3, {st_mode=S_IFREG|0755, st_size=439320, ...}) = 0 <0.000013>
17:31:06.766162 mmap(NULL, 2527464, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5c51d000 <0.000014>
17:31:06.766210 mprotect(0x7f0b5c583000, 2097152, PROT_NONE) = 0 <0.000017>
17:31:06.766258 mmap(0x7f0b5c783000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x66000) = 0x7f0b5c783000 <0.000016>
17:31:06.766311 mmap(0x7f0b5c786000, 232, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c786000 <0.000017>
17:31:06.766369 close(3)                = 0 <0.000014>
17:31:06.766417 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.766469 open("/usr/local/lib/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.766520 open("/usr/local/lib64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.766573 open("/usr/local64/lib/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.766627 open("/usr/local/epics/extensions/lib/linux-x86/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.766683 open("/lib64/libstdc++.so.6", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.766734 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \262\5\0\0\0\0\0@\0\0\0\0\0\0\0@\31\17\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0!\0 \0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\333\213\16\0\0\0\0\0\333\213\16\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\20\215\16\0\0\0\0\0\20\215.\0\0\0\0\0\20\215.\0\0\0\0\0\350\211\0\0\0\0\0\0P\326\1\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\330\364\16\0\0\0\0\0\330\364.\0\0\0\0\0\330\364.\0\0\0\0\0 \2\0\0\0\0\0\0 \2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.766792 fstat(3, {st_mode=S_IFREG|0755, st_size=991616, ...}) = 0 <0.000014>
17:31:06.766841 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c989000 <0.000025>
17:31:06.766914 mmap(NULL, 3171168, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5c216000 <0.000016>
17:31:06.766972 mprotect(0x7f0b5c2ff000, 2093056, PROT_NONE) = 0 <0.000019>
17:31:06.767023 mmap(0x7f0b5c4fe000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe8000) = 0x7f0b5c4fe000 <0.000017>
17:31:06.767077 mmap(0x7f0b5c508000, 82784, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c508000 <0.000013>
17:31:06.767126 close(3)                = 0 <0.000010>
17:31:06.767169 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.767224 open("/usr/local/lib/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.767272 open("/usr/local/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.767320 open("/usr/local64/lib/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.767368 open("/usr/local/epics/extensions/lib/linux-x86/libm.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.767420 open("/lib64/libm.so.6", O_RDONLY|O_CLOEXEC) = 3 <0.000019>
17:31:06.767482 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0pS\0\0\0\0\0\0@\0\0\0\0\0\0\0\340Z\21\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0$\0#\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0@\10\20\0\0\0\0\0@\10\20\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0p\r\20\0\0\0\0\0p\r0\0\0\0\0\0p\r0\0\0\0\0\0t\3\0\0\0\0\0\0\310\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\220\r\20\0\0\0\0\0\220\r0\0\0\0\0\0\220\r0\0\0\0\0\0 \2\0\0\0\0\0\0 \2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000016>
17:31:06.767556 fstat(3, {st_mode=S_IFREG|0755, st_size=1139680, ...}) = 0 <0.000014>
17:31:06.767625 mmap(NULL, 3150136, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5bf14000 <0.000016>
17:31:06.767676 mprotect(0x7f0b5c015000, 2093056, PROT_NONE) = 0 <0.000016>
17:31:06.767723 mmap(0x7f0b5c214000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x100000) = 0x7f0b5c214000 <0.000020>
17:31:06.767790 close(3)                = 0 <0.000014>
17:31:06.767838 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.767890 open("/usr/local/lib/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000022>
17:31:06.767954 open("/usr/local/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000020>
17:31:06.768018 open("/usr/local64/lib/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.768071 open("/usr/local/epics/extensions/lib/linux-x86/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.768123 open("/lib64/libgcc_s.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.768173 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220*\0\0\0\0\0\0@\0\0\0\0\0\0\0\10S\1\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\37\0\36\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0TL\1\0\0\0\0\0TL\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\260M\1\0\0\0\0\0\260M!\0\0\0\0\0\260M!\0\0\0\0\0\300\3\0\0\0\0\0\0P\6\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\330M\1\0\0\0\0\0\330M!\0\0\0\0\0\330M!\0\0\0\0\0\360\1\0\0\0\0\0\0\360\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.768232 fstat(3, {st_mode=S_IFREG|0755, st_size=88776, ...}) = 0 <0.000012>
17:31:06.768280 mmap(NULL, 2184192, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5bcfe000 <0.000015>
17:31:06.768329 mprotect(0x7f0b5bd13000, 2093056, PROT_NONE) = 0 <0.000015>
17:31:06.768376 mmap(0x7f0b5bf12000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7f0b5bf12000 <0.000015>
17:31:06.768432 close(3)                = 0 <0.000010>
17:31:06.768482 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000016>
17:31:06.768544 open("/usr/local/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.768612 open("/usr/local/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.768665 open("/usr/local64/lib/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.768715 open("/usr/local/epics/extensions/lib/linux-x86/libc.so.6", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.768764 open("/lib64/libc.so.6", O_RDONLY|O_CLOEXEC) = 3 <0.000019>
17:31:06.768816 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P%\2\0\0\0\0\0@\0\0\0\0\0\0\0H\27!\0\0\0\0\0\0\0\0\0@\0008\0\n\0@\0L\0K\0\6\0\0\0\5\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0000\2\0\0\0\0\0\0000\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\3\0\0\0\4\0\0\0p\341\30\0\0\0\0\0p\341\30\0\0\0\0\0p\341\30\0\0\0\0\0\34\0\0\0\0\0\0\0\34\0\0\0\0\0\0\0\20\0\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0`&\34\0\0\0\0\0`&\34\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0 '\34\0\0\0\0\0 '<\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.768866 fstat(3, {st_mode=S_IFREG|0755, st_size=2173512, ...}) = 0 <0.000015>
17:31:06.768916 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c988000 <0.000016>
17:31:06.768970 mmap(NULL, 3981792, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5b931000 <0.000014>
17:31:06.769026 mprotect(0x7f0b5baf4000, 2093056, PROT_NONE) = 0 <0.000018>
17:31:06.769080 mmap(0x7f0b5bcf3000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c2000) = 0x7f0b5bcf3000 <0.000015>
17:31:06.769129 mmap(0x7f0b5bcf9000, 16864, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5bcf9000 <0.000012>
17:31:06.769175 close(3)                = 0 <0.000011>
17:31:06.769219 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libidn.so.11", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000016>
17:31:06.769269 open("/usr/local/lib/libidn.so.11", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.769317 open("/usr/local/lib64/libidn.so.11", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.769364 open("/usr/local64/lib/libidn.so.11", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.769411 open("/usr/local/epics/extensions/lib/linux-x86/libidn.so.11", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.769467 open("/lib64/libidn.so.11", O_RDONLY|O_CLOEXEC) = 3 <0.000019>
17:31:06.769522 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0000\0\0\0\0\0\0@\0\0\0\0\0\0\0\330(\3\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\224\21\3\0\0\0\0\0\224\21\3\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\200\22\3\0\0\0\0\0\200\22#\0\0\0\0\0\200\22#\0\0\0\0\0H\17\0\0\0\0\0\0P\17\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\300\35\3\0\0\0\0\0\300\35#\0\0\0\0\0\300\35#\0\0\0\0\0\360\1\0\0\0\0\0\0\360\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000014>
17:31:06.769579 fstat(3, {st_mode=S_IFREG|0755, st_size=208920, ...}) = 0 <0.000013>
17:31:06.769635 mmap(NULL, 2302416, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5b6fe000 <0.000016>
17:31:06.769688 mprotect(0x7f0b5b730000, 2093056, PROT_NONE) = 0 <0.000016>
17:31:06.769735 mmap(0x7f0b5b92f000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x31000) = 0x7f0b5b92f000 <0.000015>
17:31:06.769790 close(3)                = 0 <0.000013>
17:31:06.769837 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.769887 open("/usr/local/lib/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.769934 open("/usr/local/lib64/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000016>
17:31:06.769992 open("/usr/local64/lib/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.770043 open("/usr/local/epics/extensions/lib/linux-x86/libssh2.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.770092 open("/lib64/libssh2.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000018>
17:31:06.770142 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@V\0\0\0\0\0\0@\0\0\0\0\0\0\0008\322\2\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\34\0\33\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0d\256\2\0\0\0\0\0d\256\2\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0(\265\2\0\0\0\0\0(\265\"\0\0\0\0\0(\265\"\0\0\0\0\0`\20\0\0\0\0\0\0p\20\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\300\275\2\0\0\0\0\0\300\275\"\0\0\0\0\0\300\275\"\0\0\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000014>
17:31:06.770192 fstat(3, {st_mode=S_IFREG|0755, st_size=186680, ...}) = 0 <0.000013>
17:31:06.770238 mmap(NULL, 2278808, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5b4d1000 <0.000014>
17:31:06.770284 mprotect(0x7f0b5b4fc000, 2097152, PROT_NONE) = 0 <0.000016>
17:31:06.770329 mmap(0x7f0b5b6fc000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2b000) = 0x7f0b5b6fc000 <0.000023>
17:31:06.770404 close(3)                = 0 <0.000021>
17:31:06.770480 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libssl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000016>
17:31:06.770541 open("/usr/local/lib/libssl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000022>
17:31:06.770603 open("/usr/local/lib64/libssl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.770653 open("/usr/local64/lib/libssl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.770700 open("/usr/local/epics/extensions/lib/linux-x86/libssl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.770749 open("/lib64/libssl3.so", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.770798 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\340\302\0\0\0\0\0\0@\0\0\0\0\0\0\0p,\5\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\36\0\35\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\304\310\4\0\0\0\0\0\304\310\4\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\250\315\4\0\0\0\0\0\250\315$\0\0\0\0\0\250\315$\0\0\0\0\0\230<\0\0\0\0\0\0 H\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0@\375\4\0\0\0\0\0@\375$\0\0\0\0\0@\375$\0\0\0\0\0`\2\0\0\0\0\0\0`\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000014>
17:31:06.770848 fstat(3, {st_mode=S_IFREG|0755, st_size=340976, ...}) = 0 <0.000013>
17:31:06.770894 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c987000 <0.000023>
17:31:06.770965 mmap(NULL, 2430408, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5b27f000 <0.000024>
17:31:06.771037 mprotect(0x7f0b5b2cc000, 2093056, PROT_NONE) = 0 <0.000024>
17:31:06.771106 mmap(0x7f0b5b4cb000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4c000) = 0x7f0b5b4cb000 <0.000016>
17:31:06.771163 mmap(0x7f0b5b4d0000, 1480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5b4d0000 <0.000014>
17:31:06.771242 close(3)                = 0 <0.000010>
17:31:06.771297 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libsmime3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.771351 open("/usr/local/lib/libsmime3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.771397 open("/usr/local/lib64/libsmime3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.771442 open("/usr/local64/lib/libsmime3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.771495 open("/usr/local/epics/extensions/lib/linux-x86/libsmime3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.771588 open("/lib64/libsmime3.so", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.771646 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\222\0\0\0\0\0\0@\0\0\0\0\0\0\0@z\2\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\36\0\35\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\\>\2\0\0\0\0\0\\>\2\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0h?\2\0\0\0\0\0h?\"\0\0\0\0\0h?\"\0\0\0\0\0@+\0\0\0\0\0\0\360+\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\340\\\2\0\0\0\0\0\340\\\"\0\0\0\0\0\340\\\"\0\0\0\0\0`\2\0\0\0\0\0\0`\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000015>
17:31:06.771697 fstat(3, {st_mode=S_IFREG|0755, st_size=164288, ...}) = 0 <0.000012>
17:31:06.771743 mmap(NULL, 2255704, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5b058000 <0.000014>
17:31:06.771789 mprotect(0x7f0b5b07c000, 2093056, PROT_NONE) = 0 <0.000024>
17:31:06.771854 mmap(0x7f0b5b27b000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x7f0b5b27b000 <0.000017>
17:31:06.771927 close(3)                = 0 <0.000012>
17:31:06.771975 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libnss3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.772027 open("/usr/local/lib/libnss3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.772073 open("/usr/local/lib64/libnss3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.772118 open("/usr/local64/lib/libnss3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.772163 open("/usr/local/epics/extensions/lib/linux-x86/libnss3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.772211 open("/lib64/libnss3.so", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.772257 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\235\1\0\0\0\0\0@\0\0\0\0\0\0\0\200\t\23\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\36\0\35\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\204:\22\0\0\0\0\0\204:\22\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\350B\22\0\0\0\0\0\350B2\0\0\0\0\0\350B2\0\0\0\0\0tk\0\0\0\0\0\0@\203\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\240\213\22\0\0\0\0\0\240\2132\0\0\0\0\0\240\2132\0\0\0\0\0P\2\0\0\0\0\0\0P\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000012>
17:31:06.772305 fstat(3, {st_mode=S_IFREG|0755, st_size=1249536, ...}) = 0 <0.000012>
17:31:06.772360 mmap(NULL, 3327528, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5ad2b000 <0.000016>
17:31:06.772424 mprotect(0x7f0b5ae4f000, 2097152, PROT_NONE) = 0 <0.000016>
17:31:06.772471 mmap(0x7f0b5b04f000, 28672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x124000) = 0x7f0b5b04f000 <0.000014>
17:31:06.772518 mmap(0x7f0b5b056000, 5672, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5b056000 <0.000012>
17:31:06.772572 close(3)                = 0 <0.000014>
17:31:06.772626 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libnssutil3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.772678 open("/usr/local/lib/libnssutil3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.772732 open("/usr/local/lib64/libnssutil3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.772778 open("/usr/local64/lib/libnssutil3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.772824 open("/usr/local/epics/extensions/lib/linux-x86/libnssutil3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.772869 open("/lib64/libnssutil3.so", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.772915 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320\310\0\0\0\0\0\0@\0\0\0\0\0\0\0\0\362\2\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\36\0\35\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\314~\2\0\0\0\0\0\314~\2\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\210\177\2\0\0\0\0\0\210\177\"\0\0\0\0\0\210\177\"\0\0\0\0\0 f\0\0\0\0\0\0Xl\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\240\334\2\0\0\0\0\0\240\334\"\0\0\0\0\0\240\334\"\0\0\0\0\0@\2\0\0\0\0\0\0@\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000012>
17:31:06.772962 fstat(3, {st_mode=S_IFREG|0755, st_size=194944, ...}) = 0 <0.000012>
17:31:06.773008 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c986000 <0.000014>
17:31:06.773054 mmap(NULL, 2288608, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5aafc000 <0.000013>
17:31:06.773097 mprotect(0x7f0b5ab24000, 2093056, PROT_NONE) = 0 <0.000016>
17:31:06.773142 mmap(0x7f0b5ad23000, 32768, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x27000) = 0x7f0b5ad23000 <0.000015>
17:31:06.773193 close(3)                = 0 <0.000009>
17:31:06.773244 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libplds4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000022>
17:31:06.773333 open("/usr/local/lib/libplds4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.773386 open("/usr/local/lib64/libplds4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000018>
17:31:06.773447 open("/usr/local64/lib/libplds4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.773503 open("/usr/local/epics/extensions/lib/linux-x86/libplds4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.773552 open("/lib64/libplds4.so", O_RDONLY|O_CLOEXEC) = 3 <0.000027>
17:31:06.773635 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\300\16\0\0\0\0\0\0@\0\0\0\0\0\0\0x6\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\314#\0\0\0\0\0\0\314#\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\330-\0\0\0\0\0\0\330- \0\0\0\0\0\330- \0\0\0\0\0 \3\0\0\0\0\0\0(\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\370-\0\0\0\0\0\0\370- \0\0\0\0\0\370- \0\0\0\0\0\340\1\0\0\0\0\0\0\340\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000014>
17:31:06.773696 fstat(3, {st_mode=S_IFREG|0755, st_size=15800, ...}) = 0 <0.000012>
17:31:06.773743 mmap(NULL, 2109696, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5a8f8000 <0.000015>
17:31:06.773789 mprotect(0x7f0b5a8fb000, 2093056, PROT_NONE) = 0 <0.000016>
17:31:06.773834 mmap(0x7f0b5aafa000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f0b5aafa000 <0.000015>
17:31:06.773888 close(3)                = 0 <0.000013>
17:31:06.773932 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libplc4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.773981 open("/usr/local/lib/libplc4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.774026 open("/usr/local/lib64/libplc4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.774071 open("/usr/local64/lib/libplc4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.774116 open("/usr/local/epics/extensions/lib/linux-x86/libplc4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.774186 open("/lib64/libplc4.so", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.774234 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\24\0\0\0\0\0\0@\0\0\0\0\0\0\0@G\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0l6\0\0\0\0\0\0l6\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\330=\0\0\0\0\0\0\330= \0\0\0\0\0\330= \0\0\0\0\0\200\3\0\0\0\0\0\0\230\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\370=\0\0\0\0\0\0\370= \0\0\0\0\0\370= \0\0\0\0\0\340\1\0\0\0\0\0\0\340\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000012>
17:31:06.774281 fstat(3, {st_mode=S_IFREG|0755, st_size=20096, ...}) = 0 <0.000011>
17:31:06.774325 mmap(NULL, 2113904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5a6f3000 <0.000013>
17:31:06.774370 mprotect(0x7f0b5a6f7000, 2093056, PROT_NONE) = 0 <0.000015>
17:31:06.774414 mmap(0x7f0b5a8f6000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x3000) = 0x7f0b5a8f6000 <0.000013>
17:31:06.774464 close(3)                = 0 <0.000009>
17:31:06.774504 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libnspr4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.774587 open("/usr/local/lib/libnspr4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000027>
17:31:06.774692 open("/usr/local/lib64/libnspr4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000022>
17:31:06.774782 open("/usr/local64/lib/libnspr4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.774846 open("/usr/local/epics/extensions/lib/linux-x86/libnspr4.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.774902 open("/lib64/libnspr4.so", O_RDONLY|O_CLOEXEC) = 3 <0.000019>
17:31:06.774961 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\314\0\0\0\0\0\0@\0\0\0\0\0\0\0x\320\3\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0l\223\3\0\0\0\0\0l\223\3\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0@\227\3\0\0\0\0\0@\227#\0\0\0\0\0@\227#\0\0\0\0\0\210\34\0\0\0\0\0\0\300E\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\240\235\3\0\0\0\0\0\240\235#\0\0\0\0\0\240\235#\0\0\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.775011 fstat(3, {st_mode=S_IFREG|0755, st_size=251832, ...}) = 0 <0.000013>
17:31:06.775057 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c985000 <0.000017>
17:31:06.775119 mmap(NULL, 2350336, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5a4b5000 <0.000015>
17:31:06.775178 mprotect(0x7f0b5a4ef000, 2093056, PROT_NONE) = 0 <0.000016>
17:31:06.775222 mmap(0x7f0b5a6ee000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x39000) = 0x7f0b5a6ee000 <0.000015>
17:31:06.775269 mmap(0x7f0b5a6f1000, 7424, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5a6f1000 <0.000012>
17:31:06.775316 close(3)                = 0 <0.000011>
17:31:06.775360 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.775408 open("/usr/local/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.775451 open("/usr/local/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.775493 open("/usr/local64/lib/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.775546 open("/usr/local/epics/extensions/lib/linux-x86/libpthread.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.775616 open("/lib64/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3 <0.000015>
17:31:06.775665 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0m\0\0\0\0\0\0@\0\0\0\0\0\0\0X+\2\0\0\0\0\0\0\0\0\0@\0008\0\t\0@\0)\0(\0\6\0\0\0\5\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0@\0\0\0\0\0\0\0\370\1\0\0\0\0\0\0\370\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\3\0\0\0\4\0\0\0P\23\1\0\0\0\0\0P\23\1\0\0\0\0\0P\23\1\0\0\0\0\0\34\0\0\0\0\0\0\0\34\0\0\0\0\0\0\0\20\0\0\0\0\0\0\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\354g\1\0\0\0\0\0\354g\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0`k\1\0\0\0\0\0`k!\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.775734 fstat(3, {st_mode=S_IFREG|0755, st_size=144792, ...}) = 0 <0.000013>
17:31:06.775788 mmap(NULL, 2208904, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5a299000 <0.000013>
17:31:06.775833 mprotect(0x7f0b5a2b0000, 2093056, PROT_NONE) = 0 <0.000015>
17:31:06.775876 mmap(0x7f0b5a4af000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0x7f0b5a4af000 <0.000014>
17:31:06.775922 mmap(0x7f0b5a4b1000, 13448, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b5a4b1000 <0.000013>
17:31:06.775967 close(3)                = 0 <0.000011>
17:31:06.776010 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.776057 open("/usr/local/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.776099 open("/usr/local/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.776142 open("/usr/local64/lib/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.776185 open("/usr/local/epics/extensions/lib/linux-x86/libdl.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.776228 open("/lib64/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000019>
17:31:06.776294 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\16\0\0\0\0\0\0@\0\0\0\0\0\0\0\0E\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0!\0 \0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\330\37\0\0\0\0\0\0\330\37\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0X-\0\0\0\0\0\0X- \0\0\0\0\0X- \0\0\0\0\0@\3\0\0\0\0\0\0\330\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\210-\0\0\0\0\0\0\210- \0\0\0\0\0\210- \0\0\0\0\0\20\2\0\0\0\0\0\0\20\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.776347 fstat(3, {st_mode=S_IFREG|0755, st_size=19776, ...}) = 0 <0.000012>
17:31:06.776390 mmap(NULL, 2109744, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5a095000 <0.000013>
17:31:06.776434 mprotect(0x7f0b5a097000, 2097152, PROT_NONE) = 0 <0.000015>
17:31:06.776476 mmap(0x7f0b5a297000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f0b5a297000 <0.000012>
17:31:06.776524 close(3)                = 0 <0.000012>
17:31:06.776574 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.776626 open("/usr/local/lib/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.776671 open("/usr/local/lib64/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.776713 open("/usr/local64/lib/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.776756 open("/usr/local/epics/extensions/lib/linux-x86/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.776800 open("/lib64/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.776844 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \307\0\0\0\0\0\0@\0\0\0\0\0\0\0\320\335\4\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0L\234\4\0\0\0\0\0L\234\4\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0 \241\4\0\0\0\0\0 \241$\0\0\0\0\0 \241$\0\0\0\0\0X%\0\0\0\0\0\0\240'\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0H\252\4\0\0\0\0\0H\252$\0\0\0\0\0H\252$\0\0\0\0\0`\2\0\0\0\0\0\0`\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000012>
17:31:06.776896 fstat(3, {st_mode=S_IFREG|0755, st_size=320784, ...}) = 0 <0.000011>
17:31:06.776940 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c984000 <0.000013>
17:31:06.776984 mmap(NULL, 2410688, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b59e48000 <0.000013>
17:31:06.777026 mprotect(0x7f0b59e92000, 2097152, PROT_NONE) = 0 <0.000014>
17:31:06.777067 mmap(0x7f0b5a092000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x4a000) = 0x7f0b5a092000 <0.000013>
17:31:06.777129 close(3)                = 0 <0.000011>
17:31:06.777174 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.777221 open("/usr/local/lib/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.777264 open("/usr/local/lib64/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000019>
17:31:06.777315 open("/usr/local64/lib/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.777357 open("/usr/local/epics/extensions/lib/linux-x86/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.777401 open("/lib64/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.777447 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0 \\\2\0\0\0\0\0@\0\0\0\0\0\0\0(\275\16\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\334\205\r\0\0\0\0\0\334\205\r\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0X\214\r\0\0\0\0\0X\214-\0\0\0\0\0X\214-\0\0\0\0\0\360\372\0\0\0\0\0\0\10\376\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\240\\\16\0\0\0\0\0\240\\.\0\0\0\0\0\240\\.\0\0\0\0\0@\2\0\0\0\0\0\0@\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.777493 fstat(3, {st_mode=S_IFREG|0755, st_size=967784, ...}) = 0 <0.000011>
17:31:06.777535 mmap(NULL, 3050080, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b59b5f000 <0.000021>
17:31:06.777589 mprotect(0x7f0b59c38000, 2093056, PROT_NONE) = 0 <0.000018>
17:31:06.777635 mmap(0x7f0b59e37000, 69632, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd8000) = 0x7f0b59e37000 <0.000016>
17:31:06.777688 close(3)                = 0 <0.000012>
17:31:06.777732 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.777777 open("/usr/local/lib/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.777819 open("/usr/local/lib64/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.777861 open("/usr/local64/lib/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:31:06.777903 open("/usr/local/epics/extensions/lib/linux-x86/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.777957 open("/lib64/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = 3 <0.000024>
17:31:06.778012 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320H\0\0\0\0\0\0@\0\0\0\0\0\0\0 0\3\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\344\0\3\0\0\0\0\0\344\0\3\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\340\f\3\0\0\0\0\0\340\f#\0\0\0\0\0\340\f#\0\0\0\0\0\350\25\0\0\0\0\0\0\370\25\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\200\35\3\0\0\0\0\0\200\35#\0\0\0\0\0\200\35#\0\0\0\0\0 \2\0\0\0\0\0\0 \2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000014>
17:31:06.778061 fstat(3, {st_mode=S_IFREG|0755, st_size=210784, ...}) = 0 <0.000013>
17:31:06.778107 mmap(NULL, 2302680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b5992c000 <0.000019>
17:31:06.778161 mprotect(0x7f0b5995d000, 2093056, PROT_NONE) = 0 <0.000022>
17:31:06.778211 mmap(0x7f0b59b5c000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x30000) = 0x7f0b59b5c000 <0.000018>
17:31:06.778272 close(3)                = 0 <0.000012>
17:31:06.778322 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.778371 open("/usr/local/lib/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.778417 open("/usr/local/lib64/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.778462 open("/usr/local64/lib/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.778507 open("/usr/local/epics/extensions/lib/linux-x86/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.778555 open("/lib64/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000018>
17:31:06.778616 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\25\0\0\0\0\0\0@\0\0\0\0\0\0\0\2606\0\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\36\0\35\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\314%\0\0\0\0\0\0\314%\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\210-\0\0\0\0\0\0\210- \0\0\0\0\0\210- \0\0\0\0\0\310\3\0\0\0\0\0\0`\4\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\270-\0\0\0\0\0\0\270- \0\0\0\0\0\270- \0\0\0\0\0\360\1\0\0\0\0\0\0\360\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.778664 fstat(3, {st_mode=S_IFREG|0755, st_size=15920, ...}) = 0 <0.000012>
17:31:06.778708 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c983000 <0.000015>
17:31:06.778757 mmap(NULL, 2109928, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b59728000 <0.000015>
17:31:06.778801 mprotect(0x7f0b5972b000, 2093056, PROT_NONE) = 0 <0.000027>
17:31:06.778867 mmap(0x7f0b5992a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f0b5992a000 <0.000018>
17:31:06.778935 close(3)                = 0 <0.000012>
17:31:06.778981 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.779032 open("/usr/local/lib/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.779077 open("/usr/local/lib64/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.779123 open("/usr/local64/lib/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.779168 open("/usr/local/epics/extensions/lib/linux-x86/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.779214 open("/lib64/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.779263 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\2006\0\0\0\0\0\0@\0\0\0\0\0\0\0\0\353\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\34\0\33\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0T\331\0\0\0\0\0\0T\331\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0@\332\0\0\0\0\0\0@\332 \0\0\0\0\0@\332 \0\0\0\0\0\20\7\0\0\0\0\0\0\250\7\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0`\332\0\0\0\0\0\0`\332 \0\0\0\0\0`\332 \0\0\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.779310 fstat(3, {st_mode=S_IFREG|0755, st_size=61952, ...}) = 0 <0.000012>
17:31:06.779357 mmap(NULL, 2154984, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b59519000 <0.000015>
17:31:06.779402 mprotect(0x7f0b59527000, 2093056, PROT_NONE) = 0 <0.000018>
17:31:06.779448 mmap(0x7f0b59726000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xd000) = 0x7f0b59726000 <0.000016>
17:31:06.779503 close(3)                = 0 <0.000013>
17:31:06.779574 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libldap-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.779646 open("/usr/local/lib/libldap-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.779696 open("/usr/local/lib64/libldap-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.779741 open("/usr/local64/lib/libldap-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.779786 open("/usr/local/epics/extensions/lib/linux-x86/libldap-2.4.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.779832 open("/lib64/libldap-2.4.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000017>
17:31:06.779880 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0000\377\0\0\0\0\0\0@\0\0\0\0\0\0\0HZ\5\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\34\0\33\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\344\30\5\0\0\0\0\0\344\30\5\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\300\"\5\0\0\0\0\0\300\"%\0\0\0\0\0\300\"%\0\0\0\0\0\300\"\0\0\0\0\0\0 #\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0`*\5\0\0\0\0\0`*%\0\0\0\0\0`*%\0\0\0\0\0\320\2\0\0\0\0\0\0\320\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.779931 fstat(3, {st_mode=S_IFREG|0755, st_size=352584, ...}) = 0 <0.000012>
17:31:06.779982 mmap(NULL, 2442720, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b592c4000 <0.000017>
17:31:06.780031 mprotect(0x7f0b59316000, 2097152, PROT_NONE) = 0 <0.000019>
17:31:06.780078 mmap(0x7f0b59516000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x52000) = 0x7f0b59516000 <0.000015>
17:31:06.780132 close(3)                = 0 <0.000011>
17:31:06.780177 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.780223 open("/usr/local/lib/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000018>
17:31:06.780273 open("/usr/local/lib64/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.780315 open("/usr/local64/lib/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.780357 open("/usr/local/epics/extensions/lib/linux-x86/libz.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.780402 open("/lib64/libz.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000016>
17:31:06.780447 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p!\0\0\0\0\0\0@\0\0\0\0\0\0\0\350Z\1\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\254D\1\0\0\0\0\0\254D\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\310L\1\0\0\0\0\0\310L!\0\0\0\0\0\310L!\0\0\0\0\0008\5\0\0\0\0\0\0@\5\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\330M\1\0\0\0\0\0\330M!\0\0\0\0\0\330M!\0\0\0\0\0\360\1\0\0\0\0\0\0\360\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000013>
17:31:06.780492 fstat(3, {st_mode=S_IFREG|0755, st_size=90664, ...}) = 0 <0.000012>
17:31:06.780534 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c982000 <0.000042>
17:31:06.780616 mmap(NULL, 2183688, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b590ae000 <0.000017>
17:31:06.780665 mprotect(0x7f0b590c3000, 2093056, PROT_NONE) = 0 <0.000018>
17:31:06.780711 mmap(0x7f0b592c2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x14000) = 0x7f0b592c2000 <0.000017>
17:31:06.780784 close(3)                = 0 <0.000015>
17:31:06.780880 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libssl.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000014>
17:31:06.780932 open("/usr/local/lib/libssl.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.780964 open("/usr/local/lib64/libssl.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.780998 open("/usr/local64/lib/libssl.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781027 open("/usr/local/epics/extensions/lib/linux-x86/libssl.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781056 open("/lib64/libssl.so.10", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.781089 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\220\253\1\0\0\0\0\0@\0\0\0\0\0\0\0(&\7\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\334d\6\0\0\0\0\0\334d\6\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\210s\6\0\0\0\0\0\210s&\0\0\0\0\0\210s&\0\0\0\0\0x\236\0\0\0\0\0\0\210\237\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\10\255\6\0\0\0\0\0\10\255&\0\0\0\0\0\10\255&\0\0\0\0\0p\2\0\0\0\0\0\0p\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000030>
17:31:06.781152 fstat(3, {st_mode=S_IFREG|0755, st_size=470376, ...}) = 0 <0.000008>
17:31:06.781193 mmap(NULL, 2560784, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b58e3c000 <0.000012>
17:31:06.781227 mprotect(0x7f0b58ea3000, 2097152, PROT_NONE) = 0 <0.000014>
17:31:06.781259 mmap(0x7f0b590a3000, 45056, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x67000) = 0x7f0b590a3000 <0.000012>
17:31:06.781297 close(3)                = 0 <0.000008>
17:31:06.781330 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libcrypto.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.781363 open("/usr/local/lib/libcrypto.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781391 open("/usr/local/lib64/libcrypto.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000008>
17:31:06.781419 open("/usr/local64/lib/libcrypto.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781446 open("/usr/local/epics/extensions/lib/linux-x86/libcrypto.so.10", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781475 open("/lib64/libcrypto.so.10", O_RDONLY|O_CLOEXEC) = 3 <0.000011>
17:31:06.781505 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0\321\6\0\0\0\0\0@\0\0\0\0\0\0\0\370p&\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\224_#\0\0\0\0\0\224_#\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\0l#\0\0\0\0\0\0lC\0\0\0\0\0\0lC\0\0\0\0\0\240v\2\0\0\0\0\0H\267\2\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0p\35%\0\0\0\0\0p\35E\0\0\0\0\0p\35E\0\0\0\0\0 \2\0\0\0\0\0\0 \2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.781535 fstat(3, {st_mode=S_IFREG|0755, st_size=2521144, ...}) = 0 <0.000007>
17:31:06.781569 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c981000 <0.000010>
17:31:06.781606 mmap(NULL, 4596552, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b589d9000 <0.000010>
17:31:06.781634 mprotect(0x7f0b58c0f000, 2097152, PROT_NONE) = 0 <0.000012>
17:31:06.781662 mmap(0x7f0b58e0f000, 167936, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x236000) = 0x7f0b58e0f000 <0.000011>
17:31:06.781695 mmap(0x7f0b58e38000, 13128, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b58e38000 <0.000010>
17:31:06.781726 close(3)                = 0 <0.000007>
17:31:06.781774 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.781804 open("/usr/local/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781832 open("/usr/local/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781860 open("/usr/local64/lib/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.781887 open("/usr/local/epics/extensions/lib/linux-x86/librt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.781922 open("/lib64/librt.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000012>
17:31:06.781953 read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\"\0\0\0\0\0\0@\0\0\0\0\0\0\0\340\243\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0'\0&\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0008e\0\0\0\0\0\0008e\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0@m\0\0\0\0\0\0@m \0\0\0\0\0@m \0\0\0\0\0\24\5\0\0\0\0\0\0\370\16\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0pm\0\0\0\0\0\0pm \0\0\0\0\0pm \0\0\0\0\0000\2\0\0\0\0\0\0000\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.781982 fstat(3, {st_mode=S_IFREG|0755, st_size=44448, ...}) = 0 <0.000008>
17:31:06.782010 mmap(NULL, 2128952, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b587d1000 <0.000010>
17:31:06.782038 mprotect(0x7f0b587d8000, 2093056, PROT_NONE) = 0 <0.000012>
17:31:06.782067 mmap(0x7f0b589d7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x6000) = 0x7f0b589d7000 <0.000011>
17:31:06.782103 close(3)                = 0 <0.000007>
17:31:06.782136 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.782165 open("/usr/local/lib/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.782202 open("/usr/local/lib64/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.782232 open("/usr/local64/lib/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.782259 open("/usr/local/epics/extensions/lib/linux-x86/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.782288 open("/lib64/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = 3 <0.000011>
17:31:06.782317 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360;\0\0\0\0\0\0@\0\0\0\0\0\0\0\340\376\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0l\336\0\0\0\0\0\0l\336\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\350\354\0\0\0\0\0\0\350\354 \0\0\0\0\0\350\354 \0\0\0\0\0\340\7\0\0\0\0\0\0\300\t\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0000\355\0\0\0\0\0\0000\355 \0\0\0\0\0000\355 \0\0\0\0\0000\2\0\0\0\0\0\0000\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.782346 fstat(3, {st_mode=S_IFREG|0755, st_size=67104, ...}) = 0 <0.000012>
17:31:06.782378 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c980000 <0.000009>
17:31:06.782410 mmap(NULL, 2160296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b585c1000 <0.000036>
17:31:06.782465 mprotect(0x7f0b585cf000, 2097152, PROT_NONE) = 0 <0.000016>
17:31:06.782499 mmap(0x7f0b587cf000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0xe000) = 0x7f0b587cf000 <0.000013>
17:31:06.782543 close(3)                = 0 <0.000009>
17:31:06.782586 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.782624 open("/usr/local/lib/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.782654 open("/usr/local/lib64/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.782683 open("/usr/local64/lib/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.782712 open("/usr/local/epics/extensions/lib/linux-x86/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:31:06.782744 open("/lib64/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.782777 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260\25\0\0\0\0\0\0@\0\0\0\0\0\0\0H6\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\34\0\33\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\274(\0\0\0\0\0\0\274(\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\260-\0\0\0\0\0\0\260- \0\0\0\0\0\260- \0\0\0\0\0`\3\0\0\0\0\0\0h\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\320-\0\0\0\0\0\0\320- \0\0\0\0\0\320- \0\0\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000010>
17:31:06.782812 fstat(3, {st_mode=S_IFREG|0755, st_size=15688, ...}) = 0 <0.000009>
17:31:06.782842 mmap(NULL, 2109720, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b583bd000 <0.000012>
17:31:06.782873 mprotect(0x7f0b583c0000, 2093056, PROT_NONE) = 0 <0.000015>
17:31:06.782904 mmap(0x7f0b585bf000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7f0b585bf000 <0.000012>
17:31:06.782944 close(3)                = 0 <0.000009>
17:31:06.782975 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.783011 open("/usr/local/lib/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.783041 open("/usr/local/lib64/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.783073 open("/usr/local64/lib/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.783101 open("/usr/local/epics/extensions/lib/linux-x86/libresolv.so.2", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.783132 open("/lib64/libresolv.so.2", O_RDONLY|O_CLOEXEC) = 3 <0.000012>
17:31:06.783163 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@9\0\0\0\0\0\0@\0\0\0\0\0\0\0\340\230\1\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\"\0!\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\254R\1\0\0\0\0\0\254R\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0HU\1\0\0\0\0\0HU!\0\0\0\0\0HU!\0\0\0\0\0\214\f\0\0\0\0\0\0\2704\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\210]\1\0\0\0\0\0\210]!\0\0\0\0\0\210]!\0\0\0\0\0\20\2\0\0\0\0\0\0\20\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.783197 fstat(3, {st_mode=S_IFREG|0755, st_size=106848, ...}) = 0 <0.000008>
17:31:06.783227 mmap(NULL, 2198016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b581a4000 <0.000017>
17:31:06.783288 mprotect(0x7f0b581ba000, 2093056, PROT_NONE) = 0 <0.000022>
17:31:06.783330 mmap(0x7f0b583b9000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x15000) = 0x7f0b583b9000 <0.000017>
17:31:06.783374 mmap(0x7f0b583bb000, 6656, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b583bb000 <0.000013>
17:31:06.783417 close(3)                = 0 <0.000010>
17:31:06.783468 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c97f000 <0.000011>
17:31:06.783510 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libsasl2.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000015>
17:31:06.783546 open("/usr/local/lib/libsasl2.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.783592 open("/usr/local/lib64/libsasl2.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.783626 open("/usr/local64/lib/libsasl2.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:31:06.783669 open("/usr/local/epics/extensions/lib/linux-x86/libsasl2.so.3", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000016>
17:31:06.783726 open("/lib64/libsasl2.so.3", O_RDONLY|O_CLOEXEC) = 3 <0.000015>
17:31:06.783771 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260K\0\0\0\0\0\0@\0\0\0\0\0\0\0\350\322\1\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\34\0\33\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0t\264\1\0\0\0\0\0t\264\1\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\270\273\1\0\0\0\0\0\270\273!\0\0\0\0\0\270\273!\0\0\0\0\0\250\v\0\0\0\0\0\0\220\f\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\360\273\1\0\0\0\0\0\360\273!\0\0\0\0\0\360\273!\0\0\0\0\0P\2\0\0\0\0\0\0P\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.783807 fstat(3, {st_mode=S_IFREG|0755, st_size=121320, ...}) = 0 <0.000008>
17:31:06.783837 mmap(NULL, 2213960, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b57f87000 <0.000011>
17:31:06.783867 mprotect(0x7f0b57fa3000, 2093056, PROT_NONE) = 0 <0.000012>
17:31:06.783896 mmap(0x7f0b581a2000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1b000) = 0x7f0b581a2000 <0.000010>
17:31:06.783933 close(3)                = 0 <0.000008>
17:31:06.783983 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libselinux.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.784012 open("/usr/local/lib/libselinux.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.784039 open("/usr/local/lib64/libselinux.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000008>
17:31:06.784065 open("/usr/local64/lib/libselinux.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.784093 open("/usr/local/epics/extensions/lib/linux-x86/libselinux.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.784121 open("/lib64/libselinux.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000010>
17:31:06.784149 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\320i\0\0\0\0\0\0@\0\0\0\0\0\0\0\310X\2\0\0\0\0\0\0\0\0\0@\0008\0\10\0@\0\37\0\36\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0<0\2\0\0\0\0\0<0\2\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\220<\2\0\0\0\0\0\220<\"\0\0\0\0\0\220<\"\0\0\0\0\0\230\t\0\0\0\0\0\0\300,\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0H=\2\0\0\0\0\0H=\"\0\0\0\0\0H=\"\0\0\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\0\2\0\0\0\0\0\0\0\2\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.784177 fstat(3, {st_mode=S_IFREG|0755, st_size=155784, ...}) = 0 <0.000007>
17:31:06.784203 mmap(NULL, 2255184, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b57d60000 <0.000010>
17:31:06.784230 mprotect(0x7f0b57d84000, 2093056, PROT_NONE) = 0 <0.000011>
17:31:06.784258 mmap(0x7f0b57f83000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x23000) = 0x7f0b57f83000 <0.000010>
17:31:06.784287 mmap(0x7f0b57f85000, 6480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b57f85000 <0.000008>
17:31:06.784318 close(3)                = 0 <0.000007>
17:31:06.784349 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.784377 open("/usr/local/lib/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000008>
17:31:06.784403 open("/usr/local/lib64/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000008>
17:31:06.784429 open("/usr/local64/lib/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000008>
17:31:06.784455 open("/usr/local/epics/extensions/lib/linux-x86/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.784483 open("/lib64/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000010>
17:31:06.784511 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\16\0\0\0\0\0\0@\0\0\0\0\0\0\0008\230\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0!\0 \0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0lt\0\0\0\0\0\0lt\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\200}\0\0\0\0\0\0\200} \0\0\0\0\0\200} \0\0\0\0\0`\3\0\0\0\0\0\0\300\344\2\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\240}\0\0\0\0\0\0\240} \0\0\0\0\0\240} \0\0\0\0\0 \2\0\0\0\0\0\0 \2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000008>
17:31:06.784538 fstat(3, {st_mode=S_IFREG|0755, st_size=41080, ...}) = 0 <0.000007>
17:31:06.784580 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c97e000 <0.000010>
17:31:06.784631 mmap(NULL, 2318912, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b57b29000 <0.000009>
17:31:06.784660 mprotect(0x7f0b57b31000, 2093056, PROT_NONE) = 0 <0.000010>
17:31:06.784688 mmap(0x7f0b57d30000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x7000) = 0x7f0b57d30000 <0.000011>
17:31:06.784723 mmap(0x7f0b57d32000, 184896, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f0b57d32000 <0.000039>
17:31:06.784802 close(3)                = 0 <0.000009>
17:31:06.784846 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.784894 open("/usr/local/lib/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.784928 open("/usr/local/lib64/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.784957 open("/usr/local64/lib/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.784987 open("/usr/local/epics/extensions/lib/linux-x86/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.785018 open("/lib64/libpcre.so.1", O_RDONLY|O_CLOEXEC) = 3 <0.000014>
17:31:06.785052 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\360\25\0\0\0\0\0\0@\0\0\0\0\0\0\0\320\34\6\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\34\0\33\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0004\377\5\0\0\0\0\0004\377\5\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\210\f\6\0\0\0\0\0\210\f&\0\0\0\0\0\210\f&\0\0\0\0\0\224\4\0\0\0\0\0\0\200\5\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\270\r\6\0\0\0\0\0\270\r&\0\0\0\0\0\270\r&\0\0\0\0\0\340\1\0\0\0\0\0\0\340\1\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000009>
17:31:06.785084 fstat(3, {st_mode=S_IFREG|0755, st_size=402384, ...}) = 0 <0.000007>
17:31:06.785114 mmap(NULL, 2494984, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b578c7000 <0.000010>
17:31:06.785145 mprotect(0x7f0b57927000, 2097152, PROT_NONE) = 0 <0.000014>
17:31:06.785177 mmap(0x7f0b57b27000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x60000) = 0x7f0b57b27000 <0.000011>
17:31:06.785216 close(3)                = 0 <0.000008>
17:31:06.785250 open("/home/epics/devel/motor-7-0/lib/linux-x86_64/libfreebl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000011>
17:31:06.785293 open("/usr/local/lib/libfreebl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000013>
17:31:06.785348 open("/usr/local/lib64/libfreebl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000017>
17:31:06.785390 open("/usr/local64/lib/libfreebl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.785418 open("/usr/local/epics/extensions/lib/linux-x86/libfreebl3.so", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory) <0.000009>
17:31:06.785447 open("/lib64/libfreebl3.so", O_RDONLY|O_CLOEXEC) = 3 <0.000011>
17:31:06.785476 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\v\0\0\0\0\0\0@\0\0\0\0\0\0\0x%\0\0\0\0\0\0\0\0\0\0@\0008\0\7\0@\0\35\0\34\0\1\0\0\0\5\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0|\24\0\0\0\0\0\0|\24\0\0\0\0\0\0\0\0 \0\0\0\0\0\1\0\0\0\6\0\0\0\250\35\0\0\0\0\0\0\250\35 \0\0\0\0\0\250\35 \0\0\0\0\0\340\2\0\0\0\0\0\0\10\3\0\0\0\0\0\0\0\0 \0\0\0\0\0\2\0\0\0\6\0\0\0\310\35\0\0\0\0\0\0\310\35 \0\0\0\0\0\310\35 \0\0\0\0\0\20\2\0\0\0\0\0\0\20\2\0\0\0\0\0\0\10\0\0\0\0\0\0\0\4\0\0\0\4\0\0\0\310\1\0\0\0\0\0\0\310\1\0\0\0\0\0\0"..., 832) = 832 <0.000008>
17:31:06.785505 fstat(3, {st_mode=S_IFREG|0755, st_size=11448, ...}) = 0 <0.000007>
17:31:06.785533 mmap(NULL, 2105520, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7f0b576c4000 <0.000011>
17:31:06.785567 mprotect(0x7f0b576c6000, 2093056, PROT_NONE) = 0 <0.000015>
17:31:06.785607 mmap(0x7f0b578c5000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1000) = 0x7f0b578c5000 <0.000012>
17:31:06.785652 close(3)                = 0 <0.000008>
17:31:06.785683 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c97d000 <0.000009>
17:31:06.785747 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c97c000 <0.000008>
17:31:06.785780 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c97b000 <0.000007>
17:31:06.785829 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c97a000 <0.000007>
17:31:06.785863 mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c978000 <0.000008>
17:31:06.785893 arch_prctl(ARCH_SET_FS, 0x7f0b5c978880) = 0 <0.000007>
17:31:06.785999 mprotect(0x7f0b5bcf3000, 16384, PROT_READ) = 0 <0.000011>
17:31:06.786040 mprotect(0x7f0b5a297000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786070 mprotect(0x7f0b578c5000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786105 mprotect(0x7f0b5a4af000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786141 mprotect(0x7f0b57b27000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.786172 mprotect(0x7f0b57d30000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786215 mprotect(0x7f0b57f83000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786246 mprotect(0x7f0b585bf000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.786279 mprotect(0x7f0b583b9000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786316 mprotect(0x7f0b587cf000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786358 mprotect(0x7f0b59b5c000, 8192, PROT_READ) = 0 <0.000010>
17:31:06.786391 mprotect(0x7f0b5992a000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.786516 mprotect(0x7f0b59e37000, 57344, PROT_READ) = 0 <0.000010>
17:31:06.786605 mprotect(0x7f0b5a092000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.786675 mprotect(0x7f0b581a2000, 4096, PROT_READ) = 0 <0.000011>
17:31:06.786708 mprotect(0x7f0b589d7000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.786737 mprotect(0x7f0b592c2000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.786918 mprotect(0x7f0b58e0f000, 114688, PROT_READ) = 0 <0.000011>
17:31:06.787016 mprotect(0x7f0b590a3000, 16384, PROT_READ) = 0 <0.000009>
17:31:06.787064 mprotect(0x7f0b5a6ee000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.787092 mprotect(0x7f0b5aafa000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.787122 mprotect(0x7f0b5a8f6000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.787188 mprotect(0x7f0b5ad23000, 28672, PROT_READ) = 0 <0.000010>
17:31:06.787283 mprotect(0x7f0b5b04f000, 20480, PROT_READ) = 0 <0.000011>
17:31:06.787344 mprotect(0x7f0b5b4cb000, 16384, PROT_READ) = 0 <0.000010>
17:31:06.787398 mprotect(0x7f0b5b27b000, 12288, PROT_READ) = 0 <0.000010>
17:31:06.787467 mprotect(0x7f0b59726000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.787559 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffec22829f0) = -1 ENOENT (No such file or directory) <0.000012>
17:31:06.787866 mprotect(0x7f0b59516000, 8192, PROT_READ) = 0 <0.000011>
17:31:06.787912 mprotect(0x7f0b5b6fc000, 4096, PROT_READ) = 0 <0.000008>
17:31:06.787948 mprotect(0x7f0b5b92f000, 4096, PROT_READ) = 0 <0.000009>
17:31:06.787976 mprotect(0x7f0b5bf12000, 4096, PROT_READ) = 0 <0.000012>
17:31:06.788022 mprotect(0x7f0b5c214000, 4096, PROT_READ) = 0 <0.000010>
17:31:06.788361 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c977000 <0.000009>
17:31:06.788406 mprotect(0x7f0b5c4fe000, 32768, PROT_READ) = 0 <0.000013>
17:31:06.788475 mprotect(0x7f0b5c783000, 8192, PROT_READ) = 0 <0.000011>
17:31:06.788511 mprotect(0x600000, 4096, PROT_READ) = 0 <0.000011>
17:31:06.788548 mprotect(0x7f0b5c9a8000, 4096, PROT_READ) = 0 <0.000016>
17:31:06.788591 munmap(0x7f0b5c98a000, 118229) = 0 <0.000018>
17:31:06.788638 set_tid_address(0x7f0b5c978b50) = 30866 <0.000009>
17:31:06.788670 set_robust_list(0x7f0b5c978b60, 24) = 0 <0.000009>
17:31:06.788705 rt_sigaction(SIGRTMIN, {0x7f0b5a29f7e0, [], SA_RESTORER|SA_SIGINFO, 0x7f0b5a2a86d0}, NULL, 8) = 0 <0.000009>
17:31:06.788747 rt_sigaction(SIGRT_1, {0x7f0b5a29f870, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7f0b5a2a86d0}, NULL, 8) = 0 <0.000010>
17:31:06.788787 rt_sigprocmask(SIG_UNBLOCK, [RTMIN RT_1], NULL, 8) = 0 <0.000009>
17:31:06.788830 getrlimit(RLIMIT_STACK, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0 <0.000010>
17:31:06.788893 statfs("/sys/fs/selinux", 0x7ffec2283c50) = -1 ENOENT (No such file or directory) <0.000016>
17:31:06.788943 statfs("/selinux", 0x7ffec2283c50) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.789018 brk(NULL)               = 0x813000 <0.000009>
17:31:06.789050 brk(0x834000)           = 0x834000 <0.000010>
17:31:06.789092 open("/proc/filesystems", O_RDONLY) = 3 <0.000016>
17:31:06.789141 fstat(3, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0 <0.000009>
17:31:06.789178 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c9a6000 <0.000011>
17:31:06.789213 read(3, "nodev\tsysfs\nnodev\trootfs\nnodev\tramfs\nnodev\tbdev\nnodev\tproc\nnodev\tcgroup\nnodev\tcpuset\nnodev\ttmpfs\nnodev\tdevtmpfs\nnodev\tdebugfs\nnodev\tsecurityfs\nnodev\tsockfs\nnodev\tdax\nnodev\tpipefs\nnodev\tanon_inodefs\nnodev\tconfigfs\nnodev\tdevpts\nnodev\thugetlbfs\nnodev\tautofs\nn"..., 1024) = 378 <0.000023>
17:31:06.789263 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffec2283830) = -1 ENOENT (No such file or directory) <0.000011>
17:31:06.789303 read(3, "", 1024)       = 0 <0.000008>
17:31:06.789336 close(3)                = 0 <0.000009>
17:31:06.789362 munmap(0x7f0b5c9a6000, 4096) = 0 <0.000012>
17:31:06.789391 access("/etc/selinux/config", F_OK) = 0 <0.000010>
17:31:06.789439 open("/etc/pki/tls/legacy-settings", O_RDONLY) = -1 ENOENT (No such file or directory) <0.000010>
17:31:06.789470 access("/etc/system-fips", F_OK) = -1 ENOENT (No such file or directory) <0.000008>
17:31:06.789556 futex(0x7f0b5a2980d0, FUTEX_WAKE_PRIVATE, 2147483647) = 0 <0.000009>
17:31:06.789628 gettid()                = 30866 <0.000008>
17:31:06.789679 rt_sigaction(SIGPIPE, {SIG_IGN, [], SA_RESTORER, 0x7f0b5b9672f0}, NULL, 8) = 0 <0.000008>
17:31:06.789730 brk(NULL)               = 0x834000 <0.000007>
17:31:06.789752 brk(0x857000)           = 0x857000 <0.000012>
17:31:06.789936 write(2, "* ", 2* )       = 2 <0.000013>
17:31:06.789972 write(2, "About to connect() to 164.54.160.71 port 22 (#0)\n", 49About to connect() to 164.54.160.71 port 22 (#0)
) = 49 <0.000009>
17:31:06.790003 socket(AF_INET, SOCK_STREAM, IPPROTO_IP) = 3 <0.000011>
17:31:06.790046 write(2, "* ", 2* )       = 2 <0.000010>
17:31:06.790073 write(2, "  Trying 164.54.160.71...\n", 26  Trying 164.54.160.71...
) = 26 <0.000009>
17:31:06.790101 setsockopt(3, SOL_SOCKET, SO_KEEPALIVE, [1], 4) = 0 <0.000008>
17:31:06.790129 setsockopt(3, SOL_TCP, TCP_KEEPIDLE, [60], 4) = 0 <0.000008>
17:31:06.790156 setsockopt(3, SOL_TCP, TCP_KEEPINTVL, [60], 4) = 0 <0.000007>
17:31:06.790183 fcntl(3, F_GETFL)       = 0x2 (flags O_RDWR) <0.000008>
17:31:06.790209 fcntl(3, F_SETFL, O_RDWR|O_NONBLOCK) = 0 <0.000008>
17:31:06.790234 connect(3, {sa_family=AF_INET, sin_port=htons(22), sin_addr=inet_addr("164.54.160.71")}, 16) = -1 EINPROGRESS (Operation now in progress) <0.000018>
17:31:06.790286 poll([{fd=3, events=POLLOUT|POLLWRNORM}], 1, 0) = 0 (Timeout) <0.000008>
17:31:06.790355 poll([{fd=3, events=POLLOUT}], 1, 1) = 1 ([{fd=3, revents=POLLOUT}]) <0.000015>
17:31:06.790399 poll([{fd=3, events=POLLOUT|POLLWRNORM}], 1, 0) = 1 ([{fd=3, revents=POLLOUT|POLLWRNORM}]) <0.000008>
17:31:06.790434 getsockopt(3, SOL_SOCKET, SO_ERROR, [0], [4]) = 0 <0.000009>
17:31:06.790465 write(2, "* ", 2* )       = 2 <0.000015>
17:31:06.790500 write(2, "Connected to 164.54.160.71 (164.54.160.71) port 22 (#0)\n", 56Connected to 164.54.160.71 (164.54.160.71) port 22 (#0)
) = 56 <0.000010>
17:31:06.790530 getpeername(3, {sa_family=AF_INET, sin_port=htons(22), sin_addr=inet_addr("164.54.160.71")}, [16]) = 0 <0.000009>
17:31:06.790566 getsockname(3, {sa_family=AF_INET, sin_port=htons(41264), sin_addr=inet_addr("164.54.160.82")}, [16]) = 0 <0.000009>
17:31:06.790612 brk(NULL)               = 0x857000 <0.000007>
17:31:06.790640 brk(0x879000)           = 0x879000 <0.000010>
17:31:06.790864 fcntl(3, F_GETFL)       = 0x802 (flags O_RDWR|O_NONBLOCK) <0.000008>
17:31:06.790891 sendto(3, "SSH-2.0-libssh2_1.8.0\r\n", 23, MSG_NOSIGNAL, NULL, 0) = 23 <0.000016>
17:31:06.790929 recvfrom(3, 0x7ffec22828f7, 1, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:31:06.790964 recvfrom(3, 0x7ffec2282917, 1, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:06.790991 poll([{fd=3, events=POLLIN}], 1, 1) = 0 (Timeout) <0.001072>
17:31:06.792094 recvfrom(3, 0x7ffec2282917, 1, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:31:06.792129 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.008983>
17:31:06.801255 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000041>
17:31:06.801339 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:31:06.801369 recvfrom(3, "H", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801396 recvfrom(3, "-", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801422 recvfrom(3, "2", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801449 recvfrom(3, ".", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801475 recvfrom(3, "0", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801502 recvfrom(3, "-", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801528 recvfrom(3, "O", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801555 recvfrom(3, "p", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000009>
17:31:06.801589 recvfrom(3, "e", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801617 recvfrom(3, "n", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801643 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801670 recvfrom(3, "S", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801696 recvfrom(3, "H", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000029>
17:31:06.801752 recvfrom(3, "_", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801779 recvfrom(3, "7", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801806 recvfrom(3, ".", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801832 recvfrom(3, "5", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801858 recvfrom(3, "\r", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000007>
17:31:06.801884 recvfrom(3, "\n", 1, MSG_NOSIGNAL, NULL, NULL) = 1 <0.000008>
17:31:06.801932 open("/dev/urandom", O_RDONLY|O_NOCTTY|O_NONBLOCK) = 4 <0.000019>
17:31:06.801975 fstat(4, {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 9), ...}) = 0 <0.000010>
17:31:06.802016 poll([{fd=4, events=POLLIN}], 1, 10) = 1 ([{fd=4, revents=POLLIN}]) <0.000008>
17:31:06.802048 read(4, "\334lh\353Ik\tNZ\235~\31\357\251E5\370\222\373\224o\26\274;\303\314\361/~\220\315\6\325m\342\372\324xe\21B\201\3456ld\24\344", 48) = 48 <0.000009>
17:31:06.802077 close(4)                = 0 <0.000008>
17:31:06.802113 getuid()                = 849601092 <0.000008>
17:31:06.802172 sendto(3, "\0\0\2\344\n\24\371u@\325\3\374q\26<\\C\233\312\10\16\300\0\0\0~diffie-hellman-group-exchange-sha256,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha1,diffie-hellman-group1-sha1\0\0\0\17ssh-rsa,ssh-dss\0\0\0\222aes128-ctr,aes192-ctr,aes256-ctr,aes256-cbc,[email protected],aes192-cb"..., 744, MSG_NOSIGNAL, NULL, 0) = 744 <0.000013>
17:31:06.802209 recvfrom(3, "\0\0\0044\6\24\357\27M\236B\235k\351\20\256\33\344\324pO,\0\0\1\2curve25519-sha256,[email protected],ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 1080 <0.000009>
17:31:06.802254 sendto(3, "\0\0\0\24\6\"\0\0\4\0\0\0\6\0\0\0\10\0\370\212VUq\275", 24, MSG_NOSIGNAL, NULL, 0) = 24 <0.000009>
17:31:06.802282 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:06.802311 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.212209>
17:31:07.014576 recvfrom(3, "\0\0\1\24\10\37\0\0\1\1\0\332W\261\211v\351\305\\\352\303\277\377pA\232\25P%\216\2475\224\0\275O\254\217B\3\267>\v\305Mb\300\242\331\252\233T?\254\240)\5\24\352Bm\346\376\370\227\313\205\202CQ\35\316QpB\fy\235\210\215\317\334E\2\377I\266o4\347\\\0\351\212U@\212y\37\365\317\352|(\217\216fd\"jj\220\276#}.@\302\7\265\255\f\256\337\332IF\346:\3525\32\t\357F%\25\376\324\t\206\224$\34\320~,\267r{9\270\261\271F}r\337\271\10\330\26\237]\263\315Zk\353\3414LXZ\210%\10\267`@.\206\353\233UH\247\271\2065\354\374\334\2\377b\262\234S\204qB\374Y\212\334f\366\"\366\351\367;\337\2\263\327\225\300\337#\320\16Z:wH\363\341\325\260oF\324V\214\343\364\314W\346}L6\337\\\22\200\6 i\214r|\305\365"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 280 <0.000011>
17:31:07.017846 sendto(3, "\0\0\1\f\6 \0\0\1\0~\343S\225X?{\3}\337\t\321\25yZ\326\332\2716,np\207^\321\372\365\220@\233\372\300\22\267\202)\232@\227\"\257\365\272\206_\324\312$\24\374\274\336+\303LDm\255\277o\300\360\267\30i\345\323$6a\325\335\332\31\\k+\16\225Ps\0107t\366\343\31n\227\25'o\257\256\341\316\303\16#C\340c\2266\303\347a\33\277\201\204\222\26\361\10z\254\367$B\350\316\353$\247\372Y\270N'\342\0230\223\325\\\241\344\313\350\212c%d\221\344\367s\243-|y\2122z\6\342;\200\236\324\273\261\372$\356\37\346F\257h\215\216\222\350m\1\253$\300\3706\335\246\316\236\300\335U\ni\256\31\372.D\367\201\231\314\224\20t\17\230:\16s\325\277m\2654X\202Ag\236%L\245\204\252\306\22\342\21#\332:\262\23\361\206\24\203}`\2\225l\3442\31\307\33"..., 272, MSG_NOSIGNAL, NULL, 0) = 272 <0.000016>
17:31:07.017905 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000013>
17:31:07.017977 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.022766>
17:31:07.040790 recvfrom(3, "\0\0\3<\10!\0\0\1\27\0\0\0\7ssh-rsa\0\0\0\3\1\0\1\0\0\1\1\0\225\226qkoT\263\216(\336Y\31]\323\17\214&\226\345\256\301|\274K\255\261\31\311o\23\214\34\254\374v\32\217\376\241\243`\353F\334\240\213\300\321\374\241\322\322\265\336h\257\220\272\361z\233t\24\361\\mBi:\322wFx\201j7p\334\267\254\250\311\342\231\223T\373\205\\A\373\210'\335\364cC|\373T9\220\336&\26\300\\\200\374\231E\355\234f\260\3421\367\275\345\222\230\261\220\223\373\0335\30\5}\\\255\2\250F\306\1770V\0fV\336U\32f\2207\327\367\346h\244~l\221f\334\20_\6\177\261\273\315a\210\206U\267t\232|\355k\0\35\277\320\231\206\327I\6\207\343\327*\245w\17\362|\336\346\377\300$(z\200:T_l\243\10]O\225^B\223\302\17\255\257/\332`\16\372"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 848 <0.000011>
17:31:07.044793 sendto(3, "\0\0\0\f\n\25\300\304\330\342\317\335\204\336\256\25", 16, MSG_NOSIGNAL, NULL, 0) = 16 <0.000017>
17:31:07.044905 sendto(3, "JR\242\252\256\325B\374\304$\266\231\"\375\0101\257\341\200\203\251\257q\375e\220\265#\7\t\27`\247\27\233\245\376l\344\314\32Y>>.,\363\32\252\35\27\342\210s\360W>\255\206~\243\374v\265", 64, MSG_NOSIGNAL, NULL, 0) = 64 <0.000011>
17:31:07.044958 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:07.044996 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.199228>
17:31:07.244295 recvfrom(3, "\207\367\0058#\207\346\335*\263\273\22X\211\16\357r\371T\227\240\232\25\320%\242P\361]2\231\356\255\311v\262\306\306Q~]\363m\236\30\345-\237y\254\270\314vg\351|\24U\224\27\7\256\206\253", 16384, MSG_NOSIGNAL, NULL, NULL) = 64 <0.000019>
17:31:07.244430 write(2, "* ", 2* )       = 2 <0.000021>
17:31:07.244503 write(2, "SSH MD5 fingerprint: 8de67ccf8c2f9b3b584c703b9fb749f6\n", 54SSH MD5 fingerprint: 8de67ccf8c2f9b3b584c703b9fb749f6
) = 54 <0.000013>
17:31:07.244567 sendto(3, "\34!e\234\34\307\334}\r\313n\226E[\355Pxw\30\320O\224\267]f \247\256\34<9\361\6soE\20\305\300\354\227G\304\355\226<\r=\v[I=\247\1#\316\326\26\233\214\0263\17\244+\0345T\321}u\3447\241\33\262\331\242\342k\365\212[aH\226o\"\376\251\207#\35\307\205\237", 96, MSG_NOSIGNAL, NULL, 0) = 96 <0.000019>
17:31:07.244627 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000012>
17:31:07.244685 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.000478>
17:31:07.245203 recvfrom(3, "J\366\254\306\212Me\3\35f\361\312\366\316\3155\20\246fh\300\236\226\364\t\256\266\330\200\33\\\334\27\235\363\321\341\216\330\221\266GW\200\277\366\302\1775\350>\272\314.(D\227\300\323\32N\372\216\r2\21+\240g1z\231\270\347f\336\355PF\225\364\27\31lN\2278\247jj\236v\271\253\337\253:P\222\326\311P\267*\367\346ANq\33\356&Y\363\37\20K>\273(\241\16Il<J\233\240\34638\266\226\305\216OO\20\nV\206^\260\337\245\240\7\367\240l\35m6F\335M\355\344\323D\236\3\306\341\327!\16\275\376\311@0\251\331\321\211z\10Ip\206\363\t?#\323\206\346\303$\362\v\252\320\333\362\351\22S5\255\251\345\0362iT\3417Y\273\215\246o7y\16?\266\n\361\300\0\272\32+\256%\200f\220B\343\372\2738\230-\370\304\274OE\2346\254\365\6\316\323\223a\177\372\331\7"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 1760 <0.000013>
17:31:07.245286 write(2, "* ", 2* )       = 2 <0.000019>
17:31:07.245351 write(2, "SSH authentication methods available: publickey,password,keyboard-interactive\n", 78SSH authentication methods available: publickey,password,keyboard-interactive
) = 78 <0.000014>
17:31:07.245396 stat("/etc/sysconfig/64bit_strstr_via_64bit_strstr_sse2_unaligned", 0x7ffec22824f0) = -1 ENOENT (No such file or directory) <0.000014>
17:31:07.245452 access("/home/epics/.ssh/id_rsa", R_OK) = 0 <0.000016>
17:31:07.245499 write(2, "* ", 2* )       = 2 <0.000013>
17:31:07.245541 write(2, "Using SSH private key file '/home/epics/.ssh/id_rsa'\n", 53Using SSH private key file '/home/epics/.ssh/id_rsa'
) = 53 <0.000024>
17:31:07.245617 open("/home/epics/.ssh/id_rsa", O_RDONLY) = 4 <0.000018>
17:31:07.245684 fstat(4, {st_mode=S_IFREG|0600, st_size=1675, ...}) = 0 <0.000013>
17:31:07.245731 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c9a6000 <0.000019>
17:31:07.245781 lseek(4, 0, SEEK_SET)   = 0 <0.000013>
17:31:07.245844 read(4, "-----BEGIN RSA PRIVATE KEY-----\nMIIEogIBAAKCAQEAw2XnqGqU7M6nYLFgVH5GsBWbNEVsp0cIY2Z5lZwWR+6u8LEw\nG6cLN7AxCq3Ww93fUKk1RSbU9t4yPwfjzVU+CbEN0Q9XLkDYdjapzMFeNThHak/P\nTFBgJOlSbuw/CIToQqZyD/fVngPgRixuQKyubCw5zli9LpzEtWZIBwE11HYAIOM5\ngUau8MEbkXAoPxcGoN0rbdQPk8+qa"..., 4096) = 1675 <0.000016>
17:31:07.245942 close(4)                = 0 <0.000014>
17:31:07.245981 munmap(0x7f0b5c9a6000, 4096) = 0 <0.000019>
17:31:07.246051 sendto(3, "\272\253\357\1*\32\247\0371\361\\X\211|\31\263\2423\5\27\30\2220y<O\344(}\317\273I\311\211%\266:\10Q\351\16\334\0321\3605\260a|wa\203\375aZ\202\36\327\306M\307?G\253,\210\\\333\344\t\316\244:t\202\343c\2635d\314\231\342\214\355\0279*.\177\vZ\222+\205Q\v\30o\257\373\345\254\350\312\261\233\353\3\376\244_6\227\361s\223\251nKp\341\206\252hs\222\267\227\203\37\311\2278Y!\\\252\3\352\346\202e>\264\360V\371\337W<5c\200\323\245\16\361\343!\254\302\261\332t7#\341j\200\272\342\17.h\216\246&e\f\260\211\216\301c\322\210\221\372q[(\307:\304e\252\320\225C\236\227\272\316\342\0035Xu\317D\245\275qx\276\231\256\326Xk\372XD\253N\203\3000\34\377n\356\3\305\5\356\373\275\355\4\1\34\177m\213\207\346\332\311\255\366?\264\255\374"..., 400, MSG_NOSIGNAL, NULL, 0) = 400 <0.000017>
17:31:07.246105 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000025>
17:31:07.246163 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.000279>
17:31:07.246480 recvfrom(3, "H0S\332#\246\352J\332\27t\352}\26\f<\273\31\271-\321Q*p\350[\245\304\372@\207\r\327E\331]\242\266\236\200\320\234\373.(\24\34AJ\260$tU\312CdBHmw\\\177\317\200\3615\"\261\235\1\351\rg\7H,eJ\304\211J\345\317\343g-\0311\256\326\357\204#\336\377\30", 16384, MSG_NOSIGNAL, NULL, NULL) = 96 <0.000012>
17:31:07.246536 write(2, "* ", 2* )       = 2 <0.000023>
17:31:07.246593 write(2, "SSH public key authentication failed: Username/PublicKey combination invalid\n", 77SSH public key authentication failed: Username/PublicKey combination invalid
) = 77 <0.000016>
17:31:07.246656 sendto(3, "\264P\225\206;\n\n\336T\221c\242MY\340)\7\224\254\207,r\241\327\243U\345?\277\27N\355)\4#\30\366\205\257\16\276\334)[\2202s\323\242\366\1\316z\255\23\n\314\212\273\16i\272\\\271#\251\353+<v\365xo\276\20\300\250\264a\300>\307\27<s2^\22\376\7y\17\23J1\232X\311\r\363{\346G\202\344\370\326\217e\333\10\312", 112, MSG_NOSIGNAL, NULL, 0) = 112 <0.000018>
17:31:07.246713 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000012>
17:31:07.246756 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.000182>
17:31:07.246972 recvfrom(3, "\234>u\5[\24\310\\K\342|ab`\271$$\217A`\202\216C\2731\207YC\365slx!\364\332\2718\337`r\24[5\3236\326\17~", 16384, MSG_NOSIGNAL, NULL, NULL) = 48 <0.000012>
17:31:07.247020 write(2, "* ", 2* )       = 2 <0.000016>
17:31:07.247065 write(2, "Initialized password authentication\n", 36Initialized password authentication
) = 36 <0.000018>
17:31:07.247113 write(2, "* ", 2* )       = 2 <0.000013>
17:31:07.247158 write(2, "Authentication complete\n", 24Authentication complete
) = 24 <0.000017>
17:31:07.247205 write(2, "* ", 2* )       = 2 <0.000018>
17:31:07.247254 write(2, "SSH CONNECT phase done\n", 23SSH CONNECT phase done
) = 23 <0.000018>
17:31:07.247326 sendto(3, "\34\223\0p\272\240\0X;\263\226\331\217\351\245\367[{\353\225\300\214\360\203\326|\305p\314?o\240\326\374\315\207\17\240\371\377\351\303\177A\222\26163J\331DV\277ZJ\3609w\221\207\274\217$!\10\20\304I\270\214\25\375\16\264\213\216\301\237\fB", 80, MSG_NOSIGNAL, NULL, 0) = 80 <0.000017>
17:31:07.247375 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000012>
17:31:07.247419 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.000137>
17:31:07.247593 recvfrom(3, "\3654\302\225\341\313nSO\37&=|\22Zo~\276\271\205\277\n\224\35\342\263\22Y\25\35f\212\351W\316@\373XI\261\334\277\330\346\214m\367\274\r\200=U\321LP:]\221~Qr/\247\342x\0R\5D\240\226\271\242.A\326yk'\36\221C%6\253\f\336\246i>\235G\37I\342\377\2\31\32\375r\16dE\211l\3m\236R\222\336\247\257\374\261B\n\200\374u\302\363\310\355\374\351\0$>L\377ET\307\342\4*i1DB\0168\37L\350]\242\320c\355\212\315\264~\327c\332\350!\264$G%\205\370\214[\314\n\213\311\303\16*<s\362Vr\254n\256{\25l8\3141\263T\244\36\5\216\364\200=Z\231\\\215G\25\226\v\374h\261KA\206-\t\2751\217\34&D\32\206&\251t\35\220\277\341\177\217'\355-\276{}\301X\331\232\216ZFz\nuS\260\331\3604\365\345\27"..., 16384, MSG_NOSIGNAL, NULL, NULL) = 960 <0.000012>
17:31:07.247656 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000013>
17:31:07.247701 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.038989>
17:31:07.286776 recvfrom(3, "\230\237Y\300E\313\336\232\314\316\316\227\306\37d\215G>dN\2w\250W\10$=\26\345\2733^#\23sYA\375g\206\17B\234\324l\352\342\205\235q\317K\263\244\213\257\232\336\273\222\370\\N\262", 16384, MSG_NOSIGNAL, NULL, NULL) = 64 <0.000019>
17:31:07.286867 sendto(3, "Y\305\20\16\265_\223/\236\201\306\3172\271\232P\31\316.\223\232\262n\225_\327\270<\325\243\201\300E9\314h\351\363\247\277\224\335\261\233\205\363\245\301\3036\350\263.'+\271\257\240\302\321\343%\5s\243:\230\236\256va\231&8i\22\236\264B\6\237\342\203By\35\202\250\267\30\241]0\365\362\351\366\322bO\245\356\30O\315\3036l\335\204\370\33D\210@\321\267\305h\253\250\271\35uh\346\257\376", 128, MSG_NOSIGNAL, NULL, 0) = 128 <0.000024>
17:31:07.286933 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000015>
17:31:07.286987 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.000766>
17:31:07.287810 recvfrom(3, "fy\372\3527(\266{\350.@\210\356\212\272\331\316\31\20\267\216\323BYp\364%\5 S\nu\211\206,\257\311\267\240\244c\364\267\264\260\271S\326\332\223\316\345z\25\206/7w\272\357\23\222j+\346\"\273\355\323\v\221U\346\354_\352)\0361\276&\23\345\357\314\332\271\311|\221\2511\354%\367\365\223\236#\373\337V\312\367\37\332\224\201\315\276\204\367", 16384, MSG_NOSIGNAL, NULL, NULL) = 112 <0.000016>
17:31:07.287889 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000013>
17:31:07.287947 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.008183>
17:31:07.296206 recvfrom(3, "_\253\360\204\2271\270\212\37\351;\16\335\266\257\253\256\356\241[\33~\25\362\235[\275V\334\2\251\242\220\201\r\3\322YT\253?A\361\206t\224\327\375\3252\377\203\21\243vU\362\355\362t\251g\0372", 16384, MSG_NOSIGNAL, NULL, NULL) = 64 <0.000028>
17:31:07.296301 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:31:07.296357 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000012>
17:31:07.296400 sendto(3, "l\244\210\320\7m\341\237\2163\220s\5\204m\245\200\247\372\332\27> \325\301\"\350\337_\2760\34\274\243R\347T\350\277\316\220D\250T\336\320\353v};\326\7\300h\323nQ\2019\224r\32\344qr\307\361t\364i\27vIv\210\2233\300u\240", 80, MSG_NOSIGNAL, NULL, 0) = 80 <0.000016>
17:31:07.296447 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000011>
17:31:07.296486 poll([{fd=3, events=POLLIN}], 1, 1000) = 1 ([{fd=3, revents=POLLIN}]) <0.000235>
17:31:07.296759 recvfrom(3, "\261\275,L\263\272\35\326\351\315\341Eh\30Qr!\256QR\200NR\277.z\370\313\361\351kmf\333m$W\215\210\311J!c\306\373\r\0f\25\34\231\342sY\204\26u2`\3\361Q\270l", 16384, MSG_NOSIGNAL, NULL, NULL) = 64 <0.000014>
17:31:07.296810 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000012>
17:31:07.296857 fstat(0, {st_mode=S_IFREG|0664, st_size=5149, ...}) = 0 <0.000011>
17:31:07.296898 mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f0b5c9a6000 <0.000013>
17:31:07.296941 read(0, "0.372071, 0.235507, 1.265924, 0.934449, 5.022960\n0.100000, 0.126592, 1.255740, 0.502296, 4.861967\n0.100000, 0.124556, 1.225350, 0.470098, 4.389310\n0.100000, 0.120515, 1.175244, 0.407764, 3.635287\n0.100000, 0.114534, 1.106227, 0.319293, 2.648232\n0.100000, 0"..., 16384) = 5149 <0.000014>
17:31:07.296984 read(0, "", 8192)       = 0 <0.000011>
17:31:07.297023 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000011>
17:31:07.297096 sendto(3, ">.\374d7\234.|\247\316XE\302\341\214\v;\16Po\"\351E\300{\366\32\36\344\301\272\26p\310r\355\1\370\32\n\236w\32\210\331G:a\322{4\332K\20\3642;m\304\nG\tL\2211>\255\273\233o\24\360M\373yA\215iR\256Zly\313\377\323\201\334q|\35\207\274\256\262]\221\247s\253\370\346\314\374\223\367\343\363B4}\361\274\272\225\3675;\2510&ELSE\16R\236\303Rz\325\2129\210\27\1\277v\37K\4\327\266D\311sM\240\tb\355\21\376\260\332\3724,D\303\2F\350M\20D\253\220\341\360\344\312\200\237\306 *\202\325,\250\355c$\6u\341e\221\277 \213cC0\277\255\22CZ\244C\245\350\216u$\342\"*\"Q7]Zr\204\241k\1\242\306\242\374=t!MuV\26\244\300\251\307\212\234l\241\354jb\nCG\7H ~w\314\361\25\263\247"..., 5200, MSG_NOSIGNAL, NULL, 0) = 5200 <0.000041>
17:31:07.297177 write(2, "* ", 2* )       = 2 <0.000018>
17:31:07.297226 write(2, "We are completely uploaded and fine\n", 36We are completely uploaded and fine
) = 36 <0.000015>
17:31:07.297280 sendto(3, "#W|\261\177;\35\0329\373\244\20\v\276\373\240\275\312\213)k0\353\373\37\262\321\307\362\3\267*\17\24\36\1 E\204\312\36\343\242K\260\0315W", 48, MSG_NOSIGNAL, NULL, 0) = 48 <0.000013>
17:31:07.297317 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:07.297347 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000008>
17:31:07.297377 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:07.297405 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000008>
17:31:07.297437 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:07.297465 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000008>
17:31:07.297495 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000010>
17:31:07.297539 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000009>
17:31:07.297580 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:31:07.297610 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000008>
17:31:07.297639 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000008>
17:31:07.297667 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000008>
17:31:07.297695 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:31:07.297725 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 0 (Timeout) <0.000010>
17:31:07.297754 recvfrom(3, 0x84aff0, 16384, MSG_NOSIGNAL, NULL, NULL) = -1 EAGAIN (Resource temporarily unavailable) <0.000009>
17:31:07.297787 poll([{fd=3, events=POLLIN|POLLPRI|POLLRDNORM|POLLRDBAND}], 1, 0) = 1 ([{fd=3, revents=POLLIN|POLLRDNORM}]) <0.000009>
17:31:07.297818 recvfrom(3, "\226\244\231\230\216O_\221l\220\344\360\337\r\224\313\226\375\326\242\222\300\303g)z\304Q\343\200\256>xM\324\3718(\177\340\317^X\302>\10\332\271\346\342o\225\335\20\314\266\35\224\354t\377\351s\316\20P`\270\1]zJ;\242\376\24i\313\257\301{\203Dyi\35\356\357Or\34\336\357c\17J\3313G\1\35w\177\224\"\22:J\212\245F\257\357\363y\267O~`\363EWa1\214\306\223e\272\362\364\177z\16\346\30(\253-\30\266#\271\335\317$\3068\201\236\25-\326]Nc\306\34\336\327\340\362ET\320H\300\305\307\373S^\340m{J", 16384, MSG_NOSIGNAL, NULL, NULL) = 176 <0.000009>
17:31:07.297868 sendto(3, "\244\243\211|\260z\347\333P 9\16`}\2\274+\7\5\267S]\300$\251\301\366\307\325FP\214\324\231\320\237 \212%\304_\301\216\v\377h\325a", 48, MSG_NOSIGNAL, NULL, 0) = 48 <0.000012>
17:31:07.297905 write(2, "* ", 2* )       = 2 <0.000013>
17:31:07.297938 write(2, "Connection #0 to host 164.54.160.71 left intact\n", 48Connection #0 to host 164.54.160.71 left intact
) = 48 <0.000011>
17:31:07.297985 sendto(3, "\217\317\367z[\274\335\26\314?>\277A\7\21\354\201s\213C\350\272Sb\312\227z4\236\314\365_\31\32\330\202\345Z6\25~\244\306\26\255\377\32\16(\311\275\222\364\256\350\240\200\264\305\326\314U\303\361", 64, MSG_NOSIGNAL, NULL, 0) = 64 <0.000009>
17:31:07.298033 close(3)                = 0 <0.000020>
17:31:07.298241 exit_group(0)           = ?
17:31:07.298670 +++ exited with 0 +++
% time     seconds  usecs/call     calls    errors syscall
 98.20    0.493614       19745        25           poll
  0.61    0.003051          14       224       186 open
  0.30    0.001488          15       102           mmap
  0.18    0.000929          13        70           mprotect
  0.14    0.000690          12        60        26 recvfrom
  0.10    0.000506          13        40           read
  0.09    0.000431          11        39           close
  0.09    0.000431          11        39           fstat
  0.07    0.000366          15        24           write
  0.07    0.000336          15        23        18 stat
  0.05    0.000268          17        16           sendto
  0.03    0.000171         171         1           execve
  0.01    0.000067          10         7           brk
  0.01    0.000049          16         3           munmap
  0.01    0.000049          12         4         2 access
  0.01    0.000027           9         3           rt_sigaction
  0.01    0.000026          13         2         2 statfs
  0.00    0.000024           8         3           fcntl
  0.00    0.000023           8         3           setsockopt
  0.00    0.000018          18         1         1 connect
  0.00    0.000013          13         1           lseek
  0.00    0.000011          11         1           socket
  0.00    0.000010          10         1           getrlimit
  0.00    0.000009           9         1           rt_sigprocmask
  0.00    0.000009           9         1           getsockname
  0.00    0.000009           9         1           getpeername
  0.00    0.000009           9         1           getsockopt
  0.00    0.000009           9         1           futex
  0.00    0.000009           9         1           set_tid_address
  0.00    0.000009           9         1           set_robust_list
  0.00    0.000008           8         1           getuid
  0.00    0.000008           8         1           gettid
  0.00    0.000007           7         1           arch_prctl
100.00    0.502684                   702       235 total
Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
RE: Uploading a file with SFTP from an EPICS driver Mark Rivers via Tech-talk
Prev: RE: areaDetector-R3-4, Stats Plugin - Histogram Mark Rivers via Tech-talk
Next: RE: [EXTERNAL] ai records with data covering many decades [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Uploading a file with SFTP from an EPICS driver J. Lewis Muir via Tech-talk
Next: Release of EPICS Qt 3.7.2 [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
ANJ, 18 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
