1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asynPortDriver: get all addresses for ASYN_MULTIDEVICE
To: "Dunning, Michael" <[email protected]>
Date: Wed, 20 Nov 2019 01:48:26 +0000
Hi Michael,
One solution is to implement the drvUserCreate() method in your driver.
drvUserCreate can call the getAddress() method to get the address of this device from the pasynUser passed to it.  You can then build an std::set of the addresses that are actually used.  You only insert a new address into the set if std::set.find() does not find the address in the set already.  Once you call getAddress() you then call the base class asynPortDriver::drvUserCreate() to complete the operation.
Your driver can then loop over the entries in the std::set.
From: Tech-talk <[email protected]> on behalf of Dunning, Michael via Tech-talk <[email protected]>
Sent: Tuesday, November 19, 2019 4:02 PM
To: EPICS Tech-Talk
Subject: asynPortDriver: get all addresses for ASYN_MULTIDEVICE
I've written an asynPortDriver for a TCP/IP-to-BitBus gateway which talks to power supply controllers.  The driver sends addressed messages to each controller and receives similar messages as responses.  The controllers may have non-sequential addresses in the [1, 200] range.
It works well with a single controller, and now I'm adding support for multiple controllers.  Since the gateway doesn't support multiple sockets, I'm using ASYN_MULTIDEVICE (multiple addresses using a single asyn port).
To poll the controllers, I need to loop over all addresses in my driver.  If I have sequential addresses that's easy, but mine may be non-sequential and I don't want to loop over non-existent addresses.
Is there a way to get a list of all registered addresses for a given port from asynManager somehow?  By "registered" I mean an address that's present in a record and tied to a specific port, e.g.:
record(bo, "$(ps):StateSetpt") {
    field(DESC, "Power Supply On/Off")
    field(DTYP, "asynInt32")
    field(OUT,  "@asyn($(asynPort), $(address), 0) STATE_SETPT")
    field(ZNAM, "OFF")
    field(ONAM, "ON")
My first attempt would be to follow the asynReport (pasynManager->report) function which sets up a linked list and prints all addresses.  Am I on the right track?  Or is there something built-in that I missed?
Mike
Michael Dunning
SLAC National Accelerator Laboratory
2575 Sand Hill Road
Menlo Park, CA 94025
(650) 926-5200
Re: asynPortDriver: get all addresses for ASYN_MULTIDEVICE Dunning, Michael via Tech-talk
Prev: asynPortDriver: get all addresses for ASYN_MULTIDEVICE Dunning, Michael via Tech-talk
Next: RE: EPICS Codeathon 2020 Rose, Austen (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: asynPortDriver: get all addresses for ASYN_MULTIDEVICE Dunning, Michael via Tech-talk
ANJ, 20 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
