1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: FW: MEDM install result
To: tech-talk <[email protected]>
Date: Tue, 26 Nov 2019 23:00:27 +0000
Folks,
I am trying to get help Peiyu get medm running on Ubuntu.  He has installed libmotif-devel, and that has installed libXm.a and libXm.so in /usr/lib/x86_64-linux-gnu/.  I was not sure if Ubuntu was searching that directory by default, so just to be sure I had him set LD_LIBRARY_PATH to point to it.
This is that directory:
epics0@ubuntu:~/Apps/epics/base/lib/linux-x86_64$ ls -l $LD_LIBRARY_PATH/libXm*
-rw-r--r-- 1 root root 4677026 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.a
lrwxrwxrwx 1 root root      14 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so -> libXm.so.4.0.4
lrwxrwxrwx 1 root root      14 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so.3 -> libXm.so.4.0.4
lrwxrwxrwx 1 root root      14 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so.4 -> libXm.so.4.0.4
-rw-r--r-- 1 root root 2886704 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so.4.0.4
-rw-r--r-- 1 root root  201152 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmu.a
lrwxrwxrwx 1 root root      15 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmu.so -> libXmu.so.6.2.0
lrwxrwxrwx 1 root root      15 Sep  3 08:09 /usr/lib/x86_64-linux-gnu/libXmu.so.6 -> libXmu.so.6.2.0
-rw-r--r-- 1 root root  102824 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
lrwxrwxrwx 1 root root      16 Sep  3 08:09 /usr/lib/x86_64-linux-gnu/libXmuu.so.1 -> libXmuu.so.1.0.0
-rw-r--r-- 1 root root   14528 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmuu.so.1.0.0
However, when he builds medm he still gets this:
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../xgif.c
make[2]: *** No rule to make target '../../../../lib/linux-x86_64/libXm.a', needed by 'medm'.  Stop.
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
../../../base/configure/RULES_DIRS:84: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
Any ideas?
Sent: Tuesday, November 26, 2019 3:39 PM
Subject: Re: MEDM install result
Dear Mark
   I have never modified medm.
I only install a lot of lib.... files.
I will try to other versions of medm.
Thanks
Peiyu
On Tue, Nov 26, 2019 at 3:17 PM Mark Rivers <[email protected]> wrote:
I am not sure why you are getting that error then.  It seems like it should be able to find libXm.
Have you changed any of the files in the medm source tree?
Sent: Tuesday, November 26, 2019 2:19 PM
Dear Mark
This is output result:
Peiyu Quan
On Tue, Nov 26, 2019 at 1:59 PM Mark Rivers <[email protected]> wrote:
I don’t see any difference in the error output.
This is what you got this time:
This is what you got previously:
make[4]: *** No rule to make target '../../../../lib/linux-x86_64/libXm.a', needed by 'medm'.  Stop.
make[4]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
make[2]: *** [medm.install] Error 2
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master'
make[1]: *** [medm.install] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src'
../base/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Please send the output of this command:
Sent: Tuesday, November 26, 2019 1:36 PM
Dear Mark
I have input: export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu
The errors have reduced parts, but not complete removal
The output result:
epics0@ubuntu:~/Apps/epics/extensions/src/medm$ make
make -C ./printUtils install
make[1]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils'
perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF xwd2ps.d  ../xwd2ps.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF xwd.d  ../xwd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF utilPrint.d  ../utilPrint.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF ps_utils.d  ../ps_utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF pUtils.d  ../pUtils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF getopt.d  ../getopt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../getopt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../pUtils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../ps_utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../utilPrint.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../xwd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../xwd2ps.c
../xwd2ps.c: In function ‘get_raster_header’:
../xwd2ps.c:1185:5: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
     fread((char *)win, sizeof( *win ), 1, file);
../xwd2ps.c:1224:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread(w_name, idifsize, 1, file);
../xwd2ps.c:1238:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread((char *)colors, win->ncolors, sizeof(XColor), file);
../xwd2ps.c: In function ‘get_next_raster_line’:
../xwd2ps.c:1296:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread((char *)buffer, iwbytes, 1, file);
../xwd2ps.c:1321:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
../xwd2ps.c:1366:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread((char *)linec, iwbytes, 1, file);
/usr/bin/ar -rc    libPrintUtils.a     getopt.o pUtils.o ps_utils.o utilPrint.o xwd.o xwd2ps.o
/usr/bin/ranlib libPrintUtils.a
Installing library ../../../../lib/linux-x86_64/libPrintUtils.a
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils/O.linux-x86_64'
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils'
make -C ./xc install
make[1]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc'
mkdir -p O.Common
make[2]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF WheelSwitch.d  ../WheelSwitch.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF utils.d  ../utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF bae.d  ../bae.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Value.d  ../Value.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Meter.d  ../Meter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Marquee.d  ../Marquee.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Matrix.d  ../Matrix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Indicator.d  ../Indicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Control.d  ../Control.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Clip.d  ../Clip.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Caption.d  ../Caption.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Byte.d  ../Byte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF BarGraph.d  ../BarGraph.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../BarGraph.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Byte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Caption.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Clip.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Control.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Indicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Matrix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Marquee.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Meter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Value.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../bae.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../WheelSwitch.c
/usr/bin/ar -rc    libANLwidgets.a     BarGraph.o Byte.o Caption.o Clip.o Control.o Indicator.o Matrix.o Marquee.o Meter.o Value.o bae.o utils.o WheelSwitch.o
/usr/bin/ranlib libANLwidgets.a
Installing library ../../../../lib/linux-x86_64/libANLwidgets.a
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc/O.linux-x86_64'
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc'
make -C ./medm install
make[1]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
mkdir -p O.Common
make[2]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF xgif.d  ../xgif.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF utils.d  ../utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF updateTask.d  ../updateTask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF updateMonitors.d  ../updateMonitors.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF resourcePalette.d  ../resourcePalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF productDescriptionShell.d  ../productDescriptionShell.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF objectPalette.d  ../objectPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmWidget.d  ../medmWidget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmWheelSwitch.d  ../medmWheelSwitch.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmValuator.d  ../medmValuator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmTextUpdate.d  ../medmTextUpdate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmTextEntry.d  ../medmTextEntry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmText.d  ../medmText.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmStripChart.d  ../medmStripChart.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmShellCommand.d  ../medmShellCommand.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmRelatedDisplay.d  ../medmRelatedDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmRectangle.d  ../medmRectangle.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmPolyline.d  ../medmPolyline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmPolygon.d  ../medmPolygon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmPixmap.d  ../medmPixmap.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmOval.d  ../medmOval.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMonitor.d  ../medmMonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMeter.d  ../medmMeter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMessageButton.d  ../medmMessageButton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMenu.d  ../medmMenu.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmIndicator.d  ../medmIndicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmImage.d  ../medmImage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmDisplay.d  ../medmDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmControl.d  ../medmControl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmComposite.d  ../medmComposite.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmCommon.d  ../medmCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmChoiceButtons.d  ../medmChoiceButtons.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmByte.d  ../medmByte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmBar.d  ../medmBar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmArc.d  ../medmArc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medm.d  ../medm.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF help.d  ../help.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF eventHandlers.d  ../eventHandlers.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF display.d  ../display.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF dialogs.d  ../dialogs.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF colorPalette.d  ../colorPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF channelPalette.d  ../channelPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF browserHelp.d  ../browserHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF callbacks.d  ../callbacks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF bubbleHelp.d  ../bubbleHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF actions.d  ../actions.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmCA.d  ../medmCA.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF SciPlot.d  ../SciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmSciPlot.d  ../medmSciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmCartesianPlot.d  ../medmCartesianPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmCartesianPlot.c
../medmCartesianPlot.c: In function ‘cartesianPlotDraw’:
../medmCartesianPlot.c:1976:24: warning: comparison of constant ‘0’ with boolean _expression_ is always false [-Wbool-compare]
      if(!pr->connected < 0) {
../medmCartesianPlot.c:1976:24: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
../medmCartesianPlot.c:1976:9: note: add parentheses around left hand side _expression_ to silence this warning
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmSciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../SciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmCA.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../actions.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../bubbleHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../callbacks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../browserHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../channelPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../colorPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../dialogs.c
../dialogs.c: In function ‘updatePrintSetupFromDialog’:
../dialogs.c:1854:5: warning: format not a string literal and no format arguments [-Wformat-security]
     sprintf(printCommand, string);
../dialogs.c:1943:5: warning: format not a string literal and no format arguments [-Wformat-security]
     sprintf(printTitleString, string);
../dialogs.c:1949:5: warning: format not a string literal and no format arguments [-Wformat-security]
     sprintf(printFile, string);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../display.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../eventHandlers.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../help.c
../help.c: In function ‘errMsgDlgCb’:
../help.c:217:19: warning: format not a string literal and no format arguments [-Wformat-security]
      fprintf(file,timeStampStr);
../help.c:218:6: warning: format not a string literal and no format arguments [-Wformat-security]
      fprintf(file,tmp);
../help.c: In function ‘medmPostMsg’:
../help.c:696:21: warning: format not a string literal and no format arguments [-Wformat-security]
     fprintf(stderr, timeStampStr);
../help.c: In function ‘medmPrintf’:
../help.c:748:21: warning: format not a string literal and no format arguments [-Wformat-security]
     fprintf(stderr, medmPrintfStr);
../help.c:228:3: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
   system(commandBuffer);
../help.c:232:3: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
../help.c: In function ‘displayHelpCallback’:
../help.c:1269:2: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
  (void)system(command);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medm.c
../medm.c: In function ‘mainFileMenuSimpleCallback’:
../medm.c:1579:27: warning: ‘%s’ directive writing up to 511 bytes into a region of size 506 [-Wformat-overflow=]
       sprintf(str,"Save \"%s\" ?",displayInfo->dlFile->name);
In file included from /usr/include/stdio.h:862:0,
                 from ../medm.h:28,
                 from ../medm.c:33:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 10 and 521 bytes into a destination of size 512
   return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
       __bos (__s), __fmt, __va_arg_pack ());
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmArc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmBar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmByte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmChoiceButtons.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmComposite.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmControl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmImage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmIndicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMenu.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMessageButton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMeter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmOval.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmPixmap.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmPolygon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmPolyline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmRectangle.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmRelatedDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmShellCommand.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmStripChart.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmText.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmTextEntry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmTextUpdate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmValuator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmWheelSwitch.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmWidget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../objectPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../productDescriptionShell.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../resourcePalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../updateMonitors.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../updateTask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../utils.c
../utils.c: In function ‘convertNameToFullPath’:
../utils.c:203:2: warning: ignoring return value of ‘getcwd’, declared with attribute warn_unused_result [-Wunused-result]
  getcwd(currentDirectoryName, PATH_MAX);
../utils.c: In function ‘parseAndExecCommand’:
../utils.c:4307:7: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
       system(command);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../xgif.c
make[2]: *** No rule to make target '../../../../lib/linux-x86_64/libXm.a', needed by 'medm'.  Stop.
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
../../../base/configure/RULES_DIRS:84: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
Thanks
Peiyu
On Tue, Nov 26, 2019 at 6:03 AM Mark Rivers <[email protected]> wrote:
It looks like perhaps the system is not looking in /usr/lib/x86_64-linux-gnu for libraries.
Please type this command
export LD_LIBRARY_PATH=/usr/lib/x86_64-linux-gnu
Then go to the medm directory and type "make" again.
Sent: Monday, November 25, 2019 7:07 PM
To: Mark Rivers
Subject: Re: MEDM install result
Dear Mark
epics0@ubuntu:/usr/lib/x86_64-linux-gnu$ ls -l libXm.a
-rw-r--r-- 1 root root 4677026 Feb 19  2018 libXm.a
epics0@ubuntu:/usr/lib/x86_64-linux-gnu$ ls -l libXm.so
lrwxrwxrwx 1 root root 14 Feb 19  2018 libXm.so -> libXm.so.4.0.4
epics0@ubuntu:/usr/lib/x86_64-linux-gnu$ ls -l libXm.so.3
lrwxrwxrwx 1 root root 14 Feb 19  2018 libXm.so.3 -> libXm.so.4.0.4
epics0@ubuntu:/usr/lib/x86_64-linux-gnu$ ls -l libXm.so.4
lrwxrwxrwx 1 root root 14 Feb 19  2018 libXm.so.4 -> libXm.so.4.0.4
epics0@ubuntu:/usr/lib/x86_64-linux-gnu$ ls -l libXm.so.4.0.4
-rw-r--r-- 1 root root 2886704 Feb 19  2018 libXm.so.4.0.4
epics0@ubuntu:~/Apps/epics/extensions$ make
make -C ./configure install
make[1]: Entering directory '/home/epics0/Apps/epics/extensions/configure'
perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/epics0/Apps/epics/extensions/configure/O.linux-x86_64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/configure'
make -C ./src install
make[1]: Entering directory '/home/epics0/Apps/epics/extensions/src'
make[2]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master'
make -C ./printUtils install
make[3]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils'
perl -CSD /home/epics0/Apps/epics/base/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[4]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF xwd2ps.d  ../xwd2ps.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF xwd.d  ../xwd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF utilPrint.d  ../utilPrint.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF ps_utils.d  ../ps_utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF pUtils.d  ../pUtils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -MM -MF getopt.d  ../getopt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../getopt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../pUtils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../ps_utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../utilPrint.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../xwd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include    -c ../xwd2ps.c
../xwd2ps.c: In function ‘get_raster_header’:
../xwd2ps.c:1185:5: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
     fread((char *)win, sizeof( *win ), 1, file);
../xwd2ps.c:1224:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread(w_name, idifsize, 1, file);
../xwd2ps.c:1238:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread((char *)colors, win->ncolors, sizeof(XColor), file);
../xwd2ps.c: In function ‘get_next_raster_line’:
../xwd2ps.c:1296:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread((char *)buffer, iwbytes, 1, file);
../xwd2ps.c:1321:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
../xwd2ps.c:1366:2: warning: ignoring return value of ‘fread’, declared with attribute warn_unused_result [-Wunused-result]
  fread((char *)linec, iwbytes, 1, file);
/usr/bin/ar -rc    libPrintUtils.a     getopt.o pUtils.o ps_utils.o utilPrint.o xwd.o xwd2ps.o
/usr/bin/ranlib libPrintUtils.a
Installing library ../../../../lib/linux-x86_64/libPrintUtils.a
make[4]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils/O.linux-x86_64'
make[3]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/printUtils'
make -C ./xc install
make[3]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc'
mkdir -p O.Common
make[4]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF WheelSwitch.d  ../WheelSwitch.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF utils.d  ../utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF bae.d  ../bae.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Value.d  ../Value.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Meter.d  ../Meter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Marquee.d  ../Marquee.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Matrix.d  ../Matrix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Indicator.d  ../Indicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Control.d  ../Control.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Clip.d  ../Clip.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Caption.d  ../Caption.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF Byte.d  ../Byte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -MM -MF BarGraph.d  ../BarGraph.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../BarGraph.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Byte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Caption.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Clip.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Control.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Indicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Matrix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Marquee.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Meter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../Value.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../bae.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I/usr/include -I/usr/include    -c ../WheelSwitch.c
/usr/bin/ar -rc    libANLwidgets.a     BarGraph.o Byte.o Caption.o Clip.o Control.o Indicator.o Matrix.o Marquee.o Meter.o Value.o bae.o utils.o WheelSwitch.o
/usr/bin/ranlib libANLwidgets.a
Installing library ../../../../lib/linux-x86_64/libANLwidgets.a
make[4]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc/O.linux-x86_64'
make[3]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/xc'
make -C ./medm install
make[3]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
mkdir -p O.Common
make[4]: Entering directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF xgif.d  ../xgif.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF utils.d  ../utils.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF updateTask.d  ../updateTask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF updateMonitors.d  ../updateMonitors.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF resourcePalette.d  ../resourcePalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF productDescriptionShell.d  ../productDescriptionShell.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF objectPalette.d  ../objectPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmWidget.d  ../medmWidget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmWheelSwitch.d  ../medmWheelSwitch.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmValuator.d  ../medmValuator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmTextUpdate.d  ../medmTextUpdate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmTextEntry.d  ../medmTextEntry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmText.d  ../medmText.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmStripChart.d  ../medmStripChart.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmShellCommand.d  ../medmShellCommand.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmRelatedDisplay.d  ../medmRelatedDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmRectangle.d  ../medmRectangle.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmPolyline.d  ../medmPolyline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmPolygon.d  ../medmPolygon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmPixmap.d  ../medmPixmap.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmOval.d  ../medmOval.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMonitor.d  ../medmMonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMeter.d  ../medmMeter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMessageButton.d  ../medmMessageButton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmMenu.d  ../medmMenu.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmIndicator.d  ../medmIndicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmImage.d  ../medmImage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmDisplay.d  ../medmDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmControl.d  ../medmControl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmComposite.d  ../medmComposite.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmCommon.d  ../medmCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmChoiceButtons.d  ../medmChoiceButtons.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmByte.d  ../medmByte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmBar.d  ../medmBar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmArc.d  ../medmArc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medm.d  ../medm.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF help.d  ../help.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF eventHandlers.d  ../eventHandlers.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF display.d  ../display.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF dialogs.d  ../dialogs.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF colorPalette.d  ../colorPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF channelPalette.d  ../channelPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF browserHelp.d  ../browserHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF callbacks.d  ../callbacks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF bubbleHelp.d  ../bubbleHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF actions.d  ../actions.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmCA.d  ../medmCA.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF SciPlot.d  ../SciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmSciPlot.d  ../medmSciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -MM -MF medmCartesianPlot.d  ../medmCartesianPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmCartesianPlot.c
../medmCartesianPlot.c: In function ‘cartesianPlotDraw’:
../medmCartesianPlot.c:1976:24: warning: comparison of constant ‘0’ with boolean _expression_ is always false [-Wbool-compare]
      if(!pr->connected < 0) {
../medmCartesianPlot.c:1976:24: warning: logical not is only applied to the left hand side of comparison [-Wlogical-not-parentheses]
../medmCartesianPlot.c:1976:9: note: add parentheses around left hand side _expression_ to silence this warning
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmSciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../SciPlot.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmCA.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../actions.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../bubbleHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../callbacks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../browserHelp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../channelPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../colorPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../dialogs.c
../dialogs.c: In function ‘updatePrintSetupFromDialog’:
../dialogs.c:1854:5: warning: format not a string literal and no format arguments [-Wformat-security]
     sprintf(printCommand, string);
../dialogs.c:1943:5: warning: format not a string literal and no format arguments [-Wformat-security]
     sprintf(printTitleString, string);
../dialogs.c:1949:5: warning: format not a string literal and no format arguments [-Wformat-security]
     sprintf(printFile, string);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../display.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../eventHandlers.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../help.c
../help.c: In function ‘errMsgDlgCb’:
../help.c:217:19: warning: format not a string literal and no format arguments [-Wformat-security]
      fprintf(file,timeStampStr);
../help.c:218:6: warning: format not a string literal and no format arguments [-Wformat-security]
      fprintf(file,tmp);
../help.c: In function ‘medmPostMsg’:
../help.c:696:21: warning: format not a string literal and no format arguments [-Wformat-security]
     fprintf(stderr, timeStampStr);
../help.c: In function ‘medmPrintf’:
../help.c:748:21: warning: format not a string literal and no format arguments [-Wformat-security]
     fprintf(stderr, medmPrintfStr);
../help.c:228:3: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
   system(commandBuffer);
../help.c:232:3: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
../help.c: In function ‘displayHelpCallback’:
../help.c:1269:2: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
  (void)system(command);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medm.c
../medm.c: In function ‘mainFileMenuSimpleCallback’:
../medm.c:1579:27: warning: ‘%s’ directive writing up to 511 bytes into a region of size 506 [-Wformat-overflow=]
       sprintf(str,"Save \"%s\" ?",displayInfo->dlFile->name);
In file included from /usr/include/stdio.h:862:0,
                 from ../medm.h:28,
                 from ../medm.c:33:
/usr/include/x86_64-linux-gnu/bits/stdio2.h:33:10: note: ‘__builtin___sprintf_chk’ output between 10 and 521 bytes into a destination of size 512
   return __builtin___sprintf_chk (__s, __USE_FORTIFY_LEVEL - 1,
       __bos (__s), __fmt, __va_arg_pack ());
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmArc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmBar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmByte.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmChoiceButtons.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmComposite.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmControl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmImage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmIndicator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMenu.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMessageButton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMeter.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmMonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmOval.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmPixmap.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmPolygon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmPolyline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmRectangle.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmRelatedDisplay.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmShellCommand.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmStripChart.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmText.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmTextEntry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmTextUpdate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmValuator.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmWheelSwitch.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../medmWidget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../objectPalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../productDescriptionShell.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../resourcePalette.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../updateMonitors.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../updateTask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../utils.c
../utils.c: In function ‘convertNameToFullPath’:
../utils.c:203:2: warning: ignoring return value of ‘getcwd’, declared with attribute warn_unused_result [-Wunused-result]
  getcwd(currentDirectoryName, PATH_MAX);
../utils.c: In function ‘parseAndExecCommand’:
../utils.c:4307:7: warning: ignoring return value of ‘system’, declared with attribute warn_unused_result [-Wunused-result]
       system(command);
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../xgif.c
make[4]: *** No rule to make target '../../../../lib/linux-x86_64/libXm.a', needed by 'medm'.  Stop.
make[4]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[3]: *** [install.linux-x86_64] Error 2
make[3]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
../../../base/configure/RULES_DIRS:84: recipe for target 'medm.install' failed
make[2]: *** [medm.install] Error 2
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master'
make[1]: *** [medm.install] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src'
../base/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
On Mon, Nov 25, 2019 at 6:41 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Please send the complete output of the command building medm that fails.
Also please send the output of “ls –l” for the libXm.a and libXm.so files on your system.
From: peiyu Quan <[email protected]<mailto:[email protected]>>
Sent: Monday, November 25, 2019 5:37 PM
To: Mark Rivers <[email protected]<mailto:[email protected]>>
Subject: Re: MEDM install result
Dear Mark
This is result,
Do I need set path for some files?
epics0@ubuntu:~/Apps/epics/extensions$ sudo apt-get install libmotif-dev
[sudo] password for epics0:
Reading package lists... Done
Building dependency tree
Reading state information... Done
libmotif-dev is already the newest version (2.3.8-2build1).
0 upgraded, 0 newly installed, 0 to remove and 82 not upgraded.
Peiyu
On Mon, Nov 25, 2019 at 5:08 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
Your output shows that you have installed libxm4 but not libmotif-dev.  Please try to install that package.
Sent: Monday, November 25, 2019 4:41 PM
Dear Mark
I use Ubuntu 64-bit - VMware workstation 15 player
I have that file : libmotif-dev.
epics0@ubuntu:~/Apps/epics/extensions$ apt-file find libXm.so
libmotif-dev: /usr/lib/x86_64-linux-gnu/libXm.so
libxm4: /usr/lib/x86_64-linux-gnu/libXm.so.3
libxm4: /usr/lib/x86_64-linux-gnu/libXm.so.4
libxm4: /usr/lib/x86_64-linux-gnu/libXm.so.4.0.4
epics0@ubuntu:~/Apps/epics/extensions$ sudo apt-get install libxm4
libxm4 is already the newest version (2.3.8-2build1).
libxm4 set to manually installed.
epics0@ubuntu:~/Apps/epics/extensions$ apt-file find libXm.a
libmotif-dev: /usr/lib/x86_64-linux-gnu/libXm.a
I got the same error result when I make in extension again.
Peiyu
On Mon, Nov 25, 2019 at 4:11 PM Mark Rivers <[email protected]<mailto:[email protected]>> wrote:
What version of Ubuntu are you running?
On my Ubuntu 18 system I used the following commands to determine what package provide libXm.a and libXm.so
TahoeU18:~> apt-file find libXm.a
TahoeU18:~> apt-file find libXm.so
So the package is libmotif-dev.  You probably need to install that package.
Sent: Monday, November 25, 2019 2:52 PM
Subject: MEDM install result
Dear Mark
   I am installing MEDM in ubuntu, But I don't know where can download libXp6?
There are some errors in result;
Could you tell me what other files I need install?
Thanks
Peiyu
The part of result is as follows:
       system(command);
Prev: Coaxpress Extension over Optical Fibre Tahirovic, Elvedin (OBS, RAL, TEC) via Tech-talk
Next: RE: MEDM install result Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 26 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
