1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: RE: MEDM install result
To: tech-talk <[email protected]>
Date: Tue, 26 Nov 2019 23:01:46 +0000
Folks,
I am trying to get help Peiyu get medm running on Ubuntu.  He has installed libmotif-devel, and that has installed libXm.a and libXm.so in /usr/lib/x86_64-linux-gnu/.  I was not sure if Ubuntu was searching that directory by default, so just to be sure I had him set LD_LIBRARY_PATH to point to it.
This is that directory:
epics0@ubuntu:~/Apps/epics/base/lib/linux-x86_64$ ls -l $LD_LIBRARY_PATH/libXm*
-rw-r--r-- 1 root root 4677026 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.a
lrwxrwxrwx 1 root root      14 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so -> libXm.so.4.0.4
lrwxrwxrwx 1 root root      14 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so.3 -> libXm.so.4.0.4
lrwxrwxrwx 1 root root      14 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so.4 -> libXm.so.4.0.4
-rw-r--r-- 1 root root 2886704 Feb 19  2018 /usr/lib/x86_64-linux-gnu/libXm.so.4.0.4
-rw-r--r-- 1 root root  201152 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmu.a
lrwxrwxrwx 1 root root      15 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmu.so -> libXmu.so.6.2.0
lrwxrwxrwx 1 root root      15 Sep  3 08:09 /usr/lib/x86_64-linux-gnu/libXmu.so.6 -> libXmu.so.6.2.0
-rw-r--r-- 1 root root  102824 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmu.so.6.2.0
lrwxrwxrwx 1 root root      16 Sep  3 08:09 /usr/lib/x86_64-linux-gnu/libXmuu.so.1 -> libXmuu.so.1.0.0
-rw-r--r-- 1 root root   14528 Dec 10  2015 /usr/lib/x86_64-linux-gnu/libXmuu.so.1.0.0
However, when he builds medm he still gets this:
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include -I../../../../../base/include/compiler/gcc -I../../../../../base/include/os/Linux -I../../../../../base/include       -I../../printUtils -I../../xc -I/usr/include -I/usr/include    -c ../xgif.c
make[2]: *** No rule to make target '../../../../lib/linux-x86_64/libXm.a', needed by 'medm'.  Stop.
make[2]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm/O.linux-x86_64'
../../../../base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/epics0/Apps/epics/extensions/src/medm-master/medm'
../../../base/configure/RULES_DIRS:84: recipe for target 'medm.install' failed
make: *** [medm.install] Error 2
Any ideas?
Re: MEDM install result Soliday, Robert T. via Tech-talk
Re: MEDM install result Torsten Bögershausen via Tech-talk
Prev: FW: MEDM install result Mark Rivers via Tech-talk
Next: Re: MEDM install result Soliday, Robert T. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 27 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
