1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Getting TOD
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Stefen Paul <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 27 Nov 2019 17:20:17 +0000
Hi Stefen,
On 11/27/19 5:08 AM, Stefen Paul via Tech-talk wrote:
Anybody having idea about how to access Time of Day clock on VMVE-6100 CPU board using vxWorks 6.9 and get the actual time and date ?
You should be able to build a vxWorks image for the mv6100 with INCLUDE_RTC enabled (by default it is excluded). The API they provide is not called by EPICS since it isn't standardized, but you should be able to write code to read and write the time using it (sysRtc.c even provides a setAnsiSysTime() routine that calls clock_settime() but I'm not sure if/when it might be called). The BSP documentation says about it:
Real-Time Clock
Support for a real-time clock is provided.  The clock is implemented with the M48T37 Timekeeper SRAM.
Real-time clock support is included in the BSP by defining INCLUDE_RTC in config.h.  This support by default is excluded.
The real-time clock can be set in your application code with a call to sysRtcSet().  The following information needs to be supplied in order to set the RTC: century, year, month, day of month, day of week, hour, minute, and second.  The current RTC settings can be retrieved with a call to sysRtcGet().  The current RTC date and time can be displayed with a call to sysRtcShow().  However, the real-time clock must be set via sysRtcSet() or via the MotLoad "set" command the first time the board is used.  The sysRtcDateTimeHook() routine is provided as a hook to the VxWorks dosFsLib as a means of providing the date and time for file timestamps.
You should be able to write a clock-time provider for the EPICS generalTime system if you wanted to use that as a source of time for your IOCs, but I haven't tried doing that myself. Getting at the BSP's header files isn't trivial and it looks like you might need them to use the API.
Alternatively you might want write your own driver; accessing the RTC is surprisingly easy. Dirk Zimoch's post here shows how, although he's only reading the chip's battery status bit. I would also look at the code in the BSP's m48t37.c and m48t37.h files.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Getting TOD Stefen Paul via Tech-talk
Prev: areaDetector and GigE Prosilica GE680 Bekman, Ilja via Tech-talk
Next: Re: areaDetector and GigE Prosilica GE680 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Getting TOD Stefen Paul via Tech-talk
Next: areaDetector and GigE Prosilica GE680 Bekman, Ilja via Tech-talk
ANJ, 27 Nov 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
