Hi:
Check the manual for archive settings, https://phoebus-doc.readthedocs.io/en/latest/preference_properties.html#trends-databrowser3, specifically these 3:
# Suggested data servers...
org.csstudio.trends.databrowser3/urls
# Default data sources for newly added channels...
org.csstudio.trends.databrowser3/archives
# When opening existing data browser plot,...
org.csstudio.trends.databrowser3/use_default_archives
In your setup, you must have use_default_archives=true and archives=jdbc::oracle::...
So when you create a plot, you might search for PVs, add, view and save them with the AA data source:
org.csstudio.trends.databrowser3/urls=pbraw://claraserv2.dl.ac.uk:17668/retrieval/
But when you later re-open the *.plt file, use_default_archives=true ignores the saved archive data sources and instead uses the default data sources from
org.csstudio.trends.databrowser3/archives, which point to some jdbc::oracle URL and then fail to connect to Oracle:
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:774)
==> Define org.csstudio.trends.databrowser3/archives to the same value as your
org.csstudio.trends.databrowser3/urls, and consider use_default_archives=false.
The idea for use_default_archives=true is to offer an 'update path' when you change your archiving setup.
You can then set use_default_archives=true, and previously saved *.plt files will use the current default archive data sources instead of the then obsolete saved settings.
-Kay
- Phoebus and Archiver Appliance Rory Clarke - UKRI STFC via Tech-talk
Re: MySQL statement in caMonitor code Aaron Brown via Tech-talk
Re: MySQL statement in caMonitor code Mark Rivers via Tech-talk
<2019>
2025
2026
<2019>
2025
2026
