1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: MySQL statement in caMonitor code
From: Aaron Brown via Tech-talk <[email protected]>
Date: Tue, 3 Dec 2019 16:50:41 +0000
Okay,
I have changed my Makefile:
TOP=..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS AFTER THIS LINE
PROD_HOST += caExample
caExample_SRCS += caExample.c
caExample_LIBS += $(EPICS_BASE_HOST_LIBS)
PROD_HOST += caMonitor
caMonitor_SRCS += caMonitor.c
USR_CFLAGS += -I/usr/include/mysql
USR_LDFLAGS += -L/usr/lib64/
caMonitor_SYS_LIBS += mysql mysqlclient pthread z m dl ssl crypto
include $(TOP)/configure/RULES
#  ADD RULES AFTER THIS LINE
I have attached a screenshot of the errors that I'm still getting. For some reason it's still saying that it cannot find the libraries.
Sent: Tuesday, December 3, 2019 11:11 AM
To: Aaron Brown <[email protected]>
Subject: [EXTERNAL] RE: MySQL statement in caMonitor code
Hi Aaron,
Change these lines:
caMonitor_SYS_LIBS += -I/usr/include/mysql
USR_LDFLAGS += -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto
to this:
The USR_LDFLAGS line is almost certainly not needed, because it will search that library by default.
You can probably also remove pthread and m from caMonitor_SYS_LIBS because EPICS base uses those by default.
Sent: Tuesday, December 3, 2019 9:45 AM
So, here is what I have changed my Makefile to:
TOP=..
Now the error I am getting is:
"cannot find -l-I/usr/include/mysql" even though that is what running mysql_config --cflags returns. Did I do this correctly?
Sent: Tuesday, December 3, 2019 10:16 AM
Subject: [EXTERNAL] Re: MySQL statement in caMonitor code
Your Makefile should be changed to
caMonitor _SYS_LIBS += all your libraries without the -l in front of each.
The -L is probably not needed but it would go in
USR_LDFLAGS += -L ...
Sent from my iPhone
On Dec 3, 2019, at 8:58 AM, Aaron Brown <[email protected]<mailto:[email protected]>> wrote:
This is what my make file looks like:
TOP=..
caMonitor_LIBS += $(EPICS_BASE_HOST_LIBS)
MYSQLCFLAGS += -I/usr/include/mysql
MYSQLLIBS += -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto
I have highlighted my additions in yellow. I got the library paths from running mysql_config --cflags --libs.
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 3, 2019 8:39 AM
To: Aaron Brown <[email protected]<mailto:[email protected]>>
Cc: tech-talk <[email protected]<mailto:[email protected]>>
Please send the Makefile.
From: Aaron Brown <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 3, 2019 7:18 AM
To: Mark Rivers
Cc: tech-talk
Hi Mark,
I tried that, but everything I did returned some sort of "missing separator" error.
I tried typing the paths to the libraries at the end of the Makefile and at the beginning.
I even tried this:
MYSQLLIBS += <path to libraries>
I keep getting the same "missing separator" error.
Aaron Brown
Detector Support Group
Jefferson Lab
Sent: Tuesday, December 3, 2019 8:10 AM
> I think this means there is a linker issue, but am not sure how to fix this.
Did you modify the Makefile to add the MySQL libraries to those that should be linked with?
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Aaron Brown via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 3, 2019 6:50 AM
To: [email protected]<mailto:[email protected]>
Subject: MySQL statement in caMonitor code
Hello all,
I have embedded a MySQL statement in the caMonitor example code. I have included all the necessary header files, I think, but when I compile it complains of undefined references:
caMonitor.o: In function `eventCallback':
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:74: undefined reference to `mysql_init'
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:75: undefined reference to `mysql_real_connect'
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:92: undefined reference to `mysql_query'
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:93: undefined reference to `mysql_close'
collect2: error: ld returned 1 exit status
Any ideas?
Thanks
Aaron Brown
Jefferson Lab
Attachment: compileError.png
Description: compileError.png
RE: MySQL statement in caMonitor code Mark Rivers via Tech-talk
MySQL statement in caMonitor code Aaron Brown via Tech-talk
Re: MySQL statement in caMonitor code Mark Rivers via Tech-talk
Re: MySQL statement in caMonitor code Aaron Brown via Tech-talk
Prev: RE: MySQL statement in caMonitor code Mark Rivers via Tech-talk
Next: RE: MySQL statement in caMonitor code Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 03 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
