Mark,
I changed my Makefile, but now I get a different error (see attachment).
It seems that by removing mysql from caMontior_SYS_LIBS has caused trouble, but when I do add it the compile complains
about not finding -lmysql.
Any thoughts?
Also, Thanks so much for taking the time to help me with this.
Aaron
Hi Aaron,
My mistake, /usr/lib64/mysql is a directory, not a library, so those lines should be the following (I also added EPICS_BASE_HOST_LIBS).
PROD_HOST += caMonitor
caMonitor_SRCS += caMonitor.c
USR_CFLAGS += -I/usr/include/mysql
USR_LDFLAGS += -L/usr/lib64/mysql
caMonitor_LIBS += $(EPICS_BASE_HOST_LIBS)
caMonitor_SYS_LIBS += mysqlclient pthread z m dl ssl crypto
I have changed my Makefile:
TOP=..
include $(TOP)/configure/CONFIG
# ADD MACRO DEFINITIONS AFTER THIS LINE
caExample_SRCS += caExample.c
caExample_LIBS += $(EPICS_BASE_HOST_LIBS)
caMonitor_SYS_LIBS += mysql mysqlclient pthread z m dl ssl crypto
include $(TOP)/configure/RULES
# ADD RULES AFTER THIS LINE
I have attached a screenshot of the errors that I'm still getting. For some reason it's still saying that it cannot find the libraries.
Hi Aaron,
Change these lines:
caMonitor_SYS_LIBS += -I/usr/include/mysql
USR_LDFLAGS += -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto
to this:
The USR_LDFLAGS line is almost certainly not needed, because it will search that library by default.
You can probably also remove pthread and m from caMonitor_SYS_LIBS because EPICS base uses those by default.
So, here is what I have changed my Makefile to:
TOP=..
Now the error I am getting is:
"cannot find -l-I/usr/include/mysql" even though that is what running mysql_config --cflags returns. Did I do this correctly?
Your Makefile should be changed to
caMonitor _SYS_LIBS += all your libraries without the -l in front of each.
The -L is probably not needed but it would go in
USR_LDFLAGS += -L ...
Sent from my iPhone
On Dec 3, 2019, at 8:58 AM, Aaron Brown <[email protected]<mailto:[email protected]>> wrote:
This is what my make file looks like:
TOP=..
PROD_HOST += caExample
MYSQLCFLAGS += -I/usr/include/mysql
MYSQLLIBS += -L/usr/lib64/mysql -lmysqlclient -lpthread -lz -lm -ldl -lssl -lcrypto
I have highlighted my additions in yellow. I got the library paths from running mysql_config --cflags --libs.
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 3, 2019 8:39 AM
To: Aaron Brown <[email protected]<mailto:[email protected]>>
Cc: tech-talk <[email protected]<mailto:[email protected]>>
Subject: [EXTERNAL] Re: MySQL statement in caMonitor code
Please send the Makefile.
From: Aaron Brown <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 3, 2019 7:18 AM
To: Mark Rivers
Cc: tech-talk
Subject: Re: MySQL statement in caMonitor code
Hi Mark,
I tried that, but everything I did returned some sort of "missing separator" error.
I tried typing the paths to the libraries at the end of the Makefile and at the beginning.
I even tried this:
MYSQLLIBS += <path to libraries>
I keep getting the same "missing separator" error.
Aaron Brown
Detector Support Group
Jefferson Lab
Sent: Tuesday, December 3, 2019 8:10 AM
> I think this means there is a linker issue, but am not sure how to fix this.
Did you modify the Makefile to add the MySQL libraries to those that should be linked with?
From: Tech-talk <[email protected]<mailto:[email protected]>> on behalf of Aaron Brown via Tech-talk <[email protected]<mailto:[email protected]>>
Sent: Tuesday, December 3, 2019 6:50 AM
To: [email protected]<mailto:[email protected]>
Subject: MySQL statement in caMonitor code
Hello all,
I have embedded a MySQL statement in the caMonitor example code. I have included all the necessary header files, I think, but when I compile it complains of undefined references:
caMonitor.o: In function `eventCallback':
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:74: undefined reference to `mysql_init'
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:75: undefined reference to `mysql_real_connect'
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:92: undefined reference to `mysql_query'
/home/ambrown/3rdTest/3rdTestApp/O.linux-x86_64/../caMonitor.c:93: undefined reference to `mysql_close'
collect2: error: ld returned 1 exit status
Any ideas?
Thanks
Aaron Brown
Jefferson Lab
