1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Accessing IOC on different subnet : solved
From: "Bhavna N. Merh via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: [email protected]
Date: Wed, 04 Dec 2019 09:03:11 +0530
Thank you for the suggestions.
Finally it could be solved by following :
It was the epics.sh file in etc/profile.d folder file that had the content like this:
#!/bin/bash
export EPICS_BASE="/usr/lib/epics"
export EPICS_HOST_ARCH=`${EPICS_BASE}/startup/EpicsHostArch`
export EPICS_CA_AUTO_ADDR_LIST=NO
export EPICS_CA_ADDR_LIST=localhost
export EPICS_CAS_INTF_ADDR_LIST=localhost
It was not changed at all.
Only the  .bashrc was edited to look like this:
and now it works.
One very imp thing the centos PC has  base 3.15  and windows has base 3.14.12.
-bhavna
On 29-11-2019 09:21, Johnson, Andrew N. wrote:
You must be using an older version of Base, try running casr with increasing numbers until you get output that includes some IP addresses. Unfortunately the older versions were less helpful for this kind of information.
- Andrew
Sent from my iPad
On Nov 28, 2019, at 5:52 AM, Bhavna N. Merh <[email protected]> wrote:
The reply to casr 1 is:
Channel Access Server V4.13
No clients connected.
Nothing beyond that.
-Bhavna
On 28-11-2019 00:01, Johnson, Andrew N. wrote:
On 11/27/19 3:59 AM, Bhavna N. Merh via Tech-talk wrote:
For windows PC-
EPICS_CA_ADDR_LIST=192.168.1.25
Is the IP address of the Windows PC 192.168.1.25 or 192.168.1.23? Your earlier email said:
B and C are on another subnet (IP addr: 192.168.1.23 and 192.168.1.25)
which I take to mean that B is 192.168.1.23 and C is 192.168.1.25. If that is the case, setting EPICS_CA_ADDR_LIST=192.168.1.25 on C tells it "only look for PVs on IOCs that are running on this PC". If the addresses of B and C on that subnet are actually the other way around, my addresses below are similarly wrong.
For CentOS PC-
EPICS_CA_ADDR_LIST: localhost
EPICS_CA_AUTO_ADDR_LIST: NO
EPICS_CAS_INTF_ADDR_LIST: localhost
EPICS_CAS_IGNORE_ADDR_LIST is undefined
An IOC running on the CentOS PC ("B") that has EPICS_CAS_INTF_ADDR_LIST set to localhost will only listen to CA clients also running on localhost (i.e. on the same machine). You can run the following command on the IOC to see what addresses the server is using. Your output probably looks like this, which is what I get by copying your setting:
epics> casr 1
CAS-TCP server on 127.0.0.1:5064 with
    CAS-UDP unicast name server on 127.0.0.1:5064
    CAS-UDP broadcast name server on 127.0.0.1:5064
Sending CAS-beacons to 1 address:
    127.0.0.1:5065
That shows the CA server is only listening for PV searches on the internal-only network interface.
For the IOC to be accessible from other machines, it would need to look like this (by setting EPICS_CAS_INTF_ADDR_LIST="192.168.1.23"):
epics> casr 1
CAS-TCP server on 192.168.1.23:5064 with
    CAS-UDP unicast name server on 192.168.1.23:5064
    CAS-UDP broadcast name server on 192.168.1.255:5064
    192.168.1.255:5065
or this (by setting EPICS_CAS_INTF_ADDR_LIST="localhost 192.168.1.23"):
epics> casr 1
Sending CAS-beacons to 2 addresses:
    127.0.0.1:5065
    192.168.1.255:5065
but with the simplest configuration (don't set EPICS_CAS_INTF_ADDR_LIST at all) it would look like this:
epics> casr 1
CAS-TCP server on 0.0.0.0:5064 with
    CAS-UDP name server on 0.0.0.0:5064
    192.168.1.255:5065
    192.168.0.255:5065
In this case it will listen for connections from every subnet that B has an interface to and will accept connections from clients running on any other machine in any of those subnets, as long as those clients actually send it search requests.
The simplest way to configure your client machines is to not set any of the EPICS_CA environment variables at all, in which case they will be able to connect to any IOC on their own subnet. If they need to connect to an IOC that is in a different subnet you would have to set EPICS_CA_ADDR_LIST to the IP address of that IOC, but I don't recommend setting EPICS_CA_AUTO_ADDR_LIST=NO as this prevents the Channel Access client library from using its interface discovery mechanism to find IOCs on the local subnets. You're telling it "I know exactly how my network is configured, follow my instructions exactly and don't try to be smart." If you don't really understand how to configure the settings properly it's much better to not set anything, just let the discovery mechanism work them out for you.
- Andrew
-Bhavna
On 27-11-2019 10:27, Mark Rivers wrote:
Hi Bhavna,
It seems to me that the setup you describe should work without setting
the EPICS environment variables at all. The IOC on B should make its
PVs available on both subnets.
At the IOC prompt on B type epicsPrtEnvParams and send the output. On
C type "set" and send the results for any environment variables
starting with EPICS.
Are the subnet masks all set correctly? It looks like they should be
255.255.255.0.
Sent from my iPhone
On Nov 26, 2019, at 9:22 PM, Bhavna N. Merh via Tech-talk <[email protected]> wrote:
I have a device (say A) and 2 PCs (B and C)
B a CentOS 7 PC  has 2 NICs. C is a windows 10 PC.
A and B are  on one subnet (IP addr of both respectively: 192.168.0.2 and 192.168.0.1)
The IOC runs on B and gathers data from device A.
I am unable to access the PVs from C. caget says channel connection timeout. (All firewalls are disabled)
Suggest what to write in EPICS_CA_ADDR_LIST and where.
Bhavna N. Merh
Scientific Officer, Accelerator Control Systems Division
Raja Ramanna Centre for Advanced Technology
Indore, Madhya Pradesh, India -452013
Ph:(0731)248-8055
"Complexity comes for free, Simplicity you have to work for."
Accessing IOC on different subnet Bhavna N. Merh via Tech-talk
Re: Accessing IOC on different subnet Mark Rivers via Tech-talk
Re: Accessing IOC on different subnet Bhavna N. Merh via Tech-talk
Re: Accessing IOC on different subnet Johnson, Andrew N. via Tech-talk
Prev: Re: MySQL statement in caMonitor code Aaron Brown via Tech-talk
Next: MySQL Statement Doesn't Work Aaron Brown via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: Accessing IOC on different subnet Johnson, Andrew N. via Tech-talk
Next: Getting TOD Stefen Paul via Tech-talk
ANJ, 04 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
