1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Custom asyn input EOS
From: "Hudson, Lee \(DLSLtd,RAL,LSCI\) via Tech-talk" <[email protected]>
Date: Tue, 10 Dec 2019 14:24:32 +0000
Hi Mark
Thanks for the information. Unfortunately I cannot predict the response length, I can predict the XML structure but not what is in the XML elements. I am using drvAsynIP so I can try that noProcessEos approach you mentioned. I'll take a look at that Newport driver.
Thanks again
Lee
-----Original Message-----
Sent: 10 December 2019 14:05
To: Hudson, Lee (DLSLtd,RAL,LSCI) <[email protected]>
Subject: Re: Custom asyn input EOS
Hi Lee,
You are correct that that asyn EOS handling is limited to 2 characters.
There are potentially a couple of ways to handle this.
Can you predict the number of characters that the device will send back?  If so then if you request exactly this number of characters in your call to asynOctet->read() it will not timeout it will just return that many characters as soon as they are available.
If the number of characters to be returned cannot be predicted then there is another potential solution.  What asyn driver are you using, drvAsynIP?  If so then create the port with the final noProcessEos argument set to 1.  This will also prevent timeouts, it will simply send you the number of characters available immediately when you call asynOctet->read().  Your driver then needs to loop reading until you find the desired terminator.  If you want an example of this look at the asynOctwtSocket.cpp code in the motor Newport directory.  The XPS sends ",EndOfAPI" as its terminator, and this code loops searching for that.
From: Tech-talk <[email protected]> on behalf of Hudson, Lee (DLSLtd,RAL,LSCI) via Tech-talk <[email protected]>
Sent: Tuesday, December 10, 2019 2:55 AM
To: [email protected]
Subject: Custom asyn input EOS
I have a motion controller I'm writing a driver for and it communicates by sending XML with no line terminators. This is proving to be a pain as any asyn reads time out. Luckily I know exactly what XML structure I expect back as the controller only uses this mechanism to respond to requests and it will always respond using the same structure the request was sent in. I would like to be able to set the input eos to the last element in the XML structure, eg, </sequencer_prog>. I tried to use the method asynOctetSyncIO->setInputEos() as this has an EOS string and length as parameters but looking at the implementation in asynInterposeEos.c I can see that the length of the EOS given is used in a switch statement and anything greater than 2 is invalid. Is there any way to specify a custom EOS of any length?
Thanks
Lee
Custom asyn input EOS Hudson, Lee (DLSLtd,RAL,LSCI) via Tech-talk
Re: Custom asyn input EOS Mark Rivers via Tech-talk
Prev: Re: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Next: P4P release 3.4.1, now with gateway Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Custom asyn input EOS Mark Rivers via Tech-talk
Next: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
ANJ, 10 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
