1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Periodic scan rate less than 20 msec
From: Michael Davidsaver via Tech-talk <[email protected]>
To: dmnr infn <[email protected]>
Cc: [email protected]
Date: Mon, 16 Dec 2019 09:35:11 -0800
On 12/16/19 1:08 AM, dmnr infn via Tech-talk wrote:
> Hello everybody,
> I want to scan a variable with a polling time less than 20 msec (for example 10 msec) and I added a row inside the file menuScan.dbd but I received this error when I run my IOC:
> initPeriodic: Scan rate '.01 second' is not achievable.
> It seems that the max scan rate in my system with CentOS 7 is 20 msec. What can I do to reach a lower scan rate?
This message is in actuality a warning that a scan rate _may_ not be achievable.
It is still attempted.
https://github.com/epics-base/epics-base/blob/370b38e4c99057b579db94123071eaf69ac52445/modules/database/src/ioc/db/dbScan.c#L903-L907
A different message is seen when a scan thread actually isn't keeping up
for some reason.
https://github.com/epics-base/epics-base/blob/370b38e4c99057b579db94123071eaf69ac52445/modules/database/src/ioc/db/dbScan.c#L820-L825
The warning exists because software delays for such small intervals are not always
reliable.  Especially on a general purpose OS like Linux.
Can you talk about your motivating use case?
Also which version of EPICS Base is involved?
Re: Periodic scan rate less than 20 msec dmnr infn via Tech-talk
Prev: Re: Pfeiffer mass spectrometer Florian Feldbauer via Tech-talk
Next: Re: Periodic scan rate less than 20 msec dmnr infn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Periodic scan rate less than 20 msec dmnr infn via Tech-talk
ANJ, 16 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
