1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: caQtDM
From: "Mezger Anton Christian \(PSI\) via Tech-talk" <[email protected]>
Date: Fri, 20 Dec 2019 13:48:21 +0000
caQtDM got now also the possibility to read adl and edl files by converting them on the fly. You do not necessarily convert your files before. However if you need to modify them in case the conversion is not perfect, you will still need adl2ui or edl2ui.
You will find the source code in a new branch of git: caQtDM feature amp
Have fun
Anton Mezger
Envoyé de mon iPhone
Prev: Re: processing pva records Michael Davidsaver via Tech-talk
Next: ca-gateway 2.1.2 compilation error Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: stream output not as I thoutght Christoph Schroeder via Tech-talk
ANJ, 20 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
