1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: stream output not as I thoutght
From: Christoph Schroeder via Tech-talk <[email protected]>
To: <[email protected]>
Date: Thu, 19 Dec 2019 15:28:02 +0100
sounds like a misconfiguration of the baud rate. The whole configuration in your startup script may look like this (adapt to your device):
drvAsynSerialPortConfigure("TESTPORT","/dev/ttyS0",0,0,0)
asynSetOption("TESTPORT", -1, "baud", "9600")
asynSetOption("TESTPORT", -1, "bits", "8")
asynSetOption("TESTPORT", -1, "parity", "none")
asynSetOption("TESTPORT", -1, "stop", "1")
asynSetOption("TESTPORT", -1, "clocal", "Y")
asynSetOption("TESTPORT", -1, "crtscts", "N")
If you are communicating between two hosts, make sure to use a null modem adapter / cable.
Best regards,
Christoph
On 12/19/19 3:09 PM, 网易邮件中心 via Tech-talk wrote:
Hi all,
    I intend to output "FA02AF" using stream.
    The IOC worked well but no effect. I checked the output using serial assistant in Win7.
    I got a indescribable string, not the FA02AF.  Actually when I echo FA02AF >/dev/ttyS0, it seems well.
    I have no idea about these. Could someone give me some advice.
mydev.proto:
_________________
Terminator=CR;
AS{
      out "FA02AF"
mydev.db:
__________________
record(ao,"AS")
    field(SCAN, "Passive")
    field(DTYP, "stream")
    field(OUT, "@mydev.proto AS $(PORT)")
Li xing
(bb|[^b]{2})
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
stream output not as I thoutght 网易邮件中心 via Tech-talk
Prev: stream output not as I thoutght 网易邮件中心 via Tech-talk
Next: Re: processing pva records Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: caQtDM Mezger Anton Christian (PSI) via Tech-talk
ANJ, 20 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
