1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Ethernet question
Date: Mon, 23 Dec 2019 22:46:59 +0000
Folks,
I am having a strange problem which I am wondering if someone might shed some light on.
I have some old Ethernet data acquisition devices, the Canberra AIM MCAs.  These are not TCP/IP, but rather use the IEEE 802.2 Extended SNAP protocol.  I have been talking to these devices for many years from vxWorks, Windows (using WinPCAP) and Linux (using libnet and libpcap).  I recently found that I was not able to talk to them from a number of my Linux systems.  It partly works: I can build a list of the devices on the network, I can take “ownership” of the device, and I can read what auxiliary Instrument Control Bus devices are connected to it (ADCs, amplifiers, HVPS, etc.).  However, some messages I send to the device never get answered.  When I look with Wireshark and compare the packet sent with a Windows machine and the non-functioning Linux machine the packets look the same.  But the Windows machine gets a reply and Linux does not.
On further investigation I found that the problem only occurs when using 10 Gbit Ethernet adapters.  When using a 1 Gbit adapter it works fine.  I was able to see this in a single machine that has both 10 Gbit and 1 Gbit adapters.  If I use the 1 Gbit adapter it works fine, if I use the 10 Gbit adapter it fails (but kind of works as described above).  On 3 separate systems 1 Gbit works, and 3 other systems 10 Gbit fails.
This does not make sense to me.  The Canberra device itself is 10 Mbit Ethernet.  It is plugged into a 1 Gbit switch.  The packets are all “slowed-down” in the switch to 10 Mbit, so I don’t understand why it matters if the network card is 1 Gbit or 10 Gbit.
I also used ethtool to lower the speed/duplex of the 10000T interface to 1000/Full and then to 100/Full and that did not help.  I could still see the module, but much functionality does not work.  So a 1 Gbit adapter works, but a 10 Gbit adapter slowed down to 1 Gbit or even 100 Mbit does not work.
Any ideas what can cause these symptoms?
Re: Ethernet question Michael Davidsaver via Tech-talk
Re: Ethernet question Heinz Junkes via Tech-talk
Prev: Re: OAGTclTk for rhel8 rpm Ernesto Paiser via Tech-talk
Next: Re: Ethernet question Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 24 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
