1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pscdrv fftwrap compile error for the Debian/ x64
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Ha, Kiman" <[email protected]>
Date: Mon, 23 Dec 2019 15:34:00 -0800
Hi Kiman,
It's been some time since I built the fftw part.  Trying now,
I see the same error.  The issue arises from the different representations of
complex numbers in c/c++.  Part is described in part in the FFTW docs:
http://www.fftw.org/fftw3_doc/Complex-numbers.html#Complex-numbers
I'll discuss in depth as a similar issue recently came up with isnan() and
friends from 'math.h' via 'epicsMath.h'.
The source of the problem is the "overlay" version of many of the C standard headers
(<complex.h> among them) which GCC installs.  eg. "/usr/include/c++/8/complex.h"
which is earlier in the implied search path than "/usr/include/complex.h".
This has long been the case, and can work through the gcc specific "#include_next"
directive to also include the real header.  The recent (circa gcc 6) change is to skip
the "#include_next" when compiling c++.  This hides the C99 standard complex types,
and breaks the magic which FFTW uses to decide whether to use the C99 complex type,
or the older 'double[2]' array type.
I originally wrote the pscdrv code to use C99 complex types on the assumption that
was the future-proof way to go.  However, this is clearly not how things have turned out.
Thankfully, I don't seem to have used more than creal() and cimag(),
so the simplest change is to avoid complex.h altogether.
https://github.com/mdavidsaver/pscdrv/commit/b6dcdf7deecee95499dfb9f03786f5297e123307
This compiles for me, however I have __not__ run tested the result.
On 12/23/19 10:13 AM, Ha, Kiman wrote:
> Hi Michael,
> The psdrv softIOC module is running stably since 2015 with Debian-7/32-bit for the NSLS-II BPMs.
> Now it is time to update Debian9 and 64 bit OS.
> http://irfu.cea.fr/Meetings/epics/presentations/Thursday/pscdrv-201410.pdf
> I was trying to compile the pscdrv module for the Debian-9 x64 environment and found some errors from the fftwrap module.
> Can you advice what happened?
> Environment:
> Debian GNU/Linux 9
> gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)
> ~/pscdrv/sigApp$ make
> make -C ./src install
> make[1]: Entering directory '/home/kha/pscdrv/sigApp/src'
> make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
>     T_A=linux-x86_64 install
> make[2]: Entering directory '/home/kha/pscdrv/sigApp/src/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -Wdate-time -D_FORTIFY_SOURCE=2    -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall    -fdebug-prefix-map=/build/epics-base-3.15.6=. -fstack-protector-strong -Wformat -Werror=format-security   -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include        -c ../fftwrap.cpp
> ../fftwrap.cpp: In member function ‘void PSDCalc::calculate()’:
> ../fftwrap.cpp:182:42: error: array must be initialized with a brace-enclosed initializer
>                  fftw_complex temp = mid[j];
> ../fftwrap.cpp:184:39: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double creal(__complex__ double)’
>                  out[j-1] += creal(temp)*creal(temp) + cimag(temp)*cimag(temp);
> ../fftwrap.cpp:184:51: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double creal(__complex__ double)’
> ../fftwrap.cpp:184:65: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double cimag(__complex__ double)’
> ../fftwrap.cpp:184:77: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double cimag(__complex__ double)’
> In file included from ../fftwrap.cpp:17:0:
> ../fftwrap.h: In instantiation of ‘void FFTWAllocator<T>::destroy(FFTWAllocator<T>::pointer) [with T = double [2]; FFTWAllocator<T>::pointer = double (*)[2]]’:
> /usr/include/c++/6/bits/alloc_traits.h:256:4:   required from ‘static decltype (__a.destroy(__p)) std::allocator_traits<_Alloc>::_S_destroy(_Alloc2&, _Tp*, int) [with _Alloc2 = FFTWAllocator<double [2]>; _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; decltype (__a.destroy(__p)) = void]’
> /usr/include/c++/6/bits/alloc_traits.h:356:14:   required from ‘static void std::allocator_traits<_Alloc>::destroy(_Alloc&, _Tp*) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>]’
> /usr/include/c++/6/bits/stl_construct.h:143:19:   required from ‘void std::_Destroy(_ForwardIterator, _ForwardIterator, _Allocator&) [with _ForwardIterator = double (*)[2]; _Allocator = FFTWAllocator<double [2]>]’
> /usr/include/c++/6/bits/vector.tcc:571:18:   required from ‘void std::vector<_Tp, _Alloc>::_M_default_append(std::vector<_Tp, _Alloc>::size_type) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; std::vector<_Tp, _Alloc>::size_type = long unsigned int]’
> /usr/include/c++/6/bits/stl_vector.h:677:21:   required from ‘void std::vector<_Tp, _Alloc>::resize(std::vector<_Tp, _Alloc>::size_type) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; std::vector<_Tp, _Alloc>::size_type = long unsigned int]’
> ../fftwrap.cpp:143:35:   required from here
> ../fftwrap.h:72:10: error: request for member ‘~double [2]’ in ‘* p’, which is of non-class type ‘double [2]’
>      {p->~T();}
> ../fftwrap.h: In instantiation of ‘void FFTWAllocator<T>::construct(FFTWAllocator<T>::pointer, FFTWAllocator<T>::const_reference&) [with T = double [2]; FFTWAllocator<T>::pointer = double (*)[2]; FFTWAllocator<T>::const_reference = const double (&)[2]]’:
> /usr/include/c++/6/bits/alloc_traits.h:243:4:   required from ‘static std::_Require<typename std::allocator_traits<_Alloc>::__construct_helper<_Tp, _Args>::type> std::allocator_traits<_Alloc>::_S_construct(_Alloc&, _Tp*, _Args&& ...) [with _Tp = double [2]; _Args = {double [2]}; _Alloc = FFTWAllocator<double [2]>; std::_Require<typename std::allocator_traits<_Alloc>::__construct_helper<_Tp, _Args>::type> = void]’
> /usr/include/c++/6/bits/alloc_traits.h:344:16:   required from ‘static decltype (std::allocator_traits<_Alloc>::_S_construct(__a, __p, (forward<_Args>)(std::allocator_traits::construct::__args)...)) std::allocator_traits<_Alloc>::construct(_Alloc&, _Tp*, _Args&& ...) [with _Tp = double [2]; _Args = {double [2]}; _Alloc = FFTWAllocator<double [2]>; decltype (std::allocator_traits<_Alloc>::_S_construct(__a, __p, (forward<_Args>)(std::allocator_traits::construct::__args)...)) = void]’
> /usr/include/c++/6/bits/stl_uninitialized.h:267:25:   required from ‘_ForwardIterator std::__uninitialized_copy_a(_InputIterator, _InputIterator, _ForwardIterator, _Allocator&) [with _InputIterator = std::move_iterator<double (*)[2]>; _ForwardIterator = double (*)[2]; _Allocator = FFTWAllocator<double [2]>]’
> /usr/include/c++/6/bits/stl_uninitialized.h:303:2:   required from ‘_ForwardIterator std::__uninitialized_move_if_noexcept_a(_InputIterator, _InputIterator, _ForwardIterator, _Allocator&) [with _InputIterator = double (*)[2]; _ForwardIterator = double (*)[2]; _Allocator = FFTWAllocator<double [2]>]’
> /usr/include/c++/6/bits/vector.tcc:563:7:   required from ‘void std::vector<_Tp, _Alloc>::_M_default_append(std::vector<_Tp, _Alloc>::size_type) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; std::vector<_Tp, _Alloc>::size_type = long unsigned int]’
> ../fftwrap.h:69:6: error: parenthesized initializer in array new [-fpermissive]
>      {::new((void*)p) T(val);}
> /etc/epics/configure/RULES_BUILD:239: recipe for target 'fftwrap.o' failed
> make[2]: *** [fftwrap.o] Error 1
> make[2]: Leaving directory '/home/kha/pscdrv/sigApp/src/O.linux-x86_64'
> /etc/epics/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
> make[1]: *** [install.linux-x86_64] Error 2
> make[1]: Leaving directory '/home/kha/pscdrv/sigApp/src'
> /etc/epics/configure/RULES_DIRS:84: recipe for target 'src.install' failed
> make: *** [src.install] Error 2
RE: pscdrv fftwrap compile error for the Debian/ x64 Ha, Kiman via Tech-talk
Prev: Re: Ethernet question Michael Davidsaver via Tech-talk
Next: Ethernet to RS-232 Danfysik supply connection issues Marissa Kranz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: pscdrv fftwrap compile error for the Debian/ x64 Ha, Kiman via Tech-talk
Next: RE: pscdrv fftwrap compile error for the Debian/ x64 Ha, Kiman via Tech-talk
ANJ, 24 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
